Main Features:
Battery LED: CREE XP-G2 LED with a lifespan of 20+years of run time
Output and runtime: Firefly: 0.5Lm(125hrs), Mid: 35Lm(4.5h), High: 150Lm(30 mins), Strobe: 150Lm/10Hz
Powered by 1 AAA battery (NOT included)
Working voltage range: 0.9–1.5V
Beam Distance: 45M
Peak Beam Intensity: 513cd
Waterproof to IPX-8 standard(2M)
Impact Resistance:1.5M
Convenient twist switch for one hand operation
Dimension: 66mm(L)*14mm(D)
Weight:10g (excluding battery)
High-performance metal Orange Peel reflector, double-sided steel coated lenses
Material:aircraft-grade aluminum with premium type Ⅲ hard anodized anti-abrasive finish
Operation:
1. Turn On /Off
Easily twist the head to turn on / off the light. Tighten the head for on and loosen for off.
2. Continuous Lighting Operation-Change Modes
When the light is on,turn off the light and then turn on to change modes.(Middle→High→Low)
3. Hidden strobe When the light is on, twisting the head 2 times within 0.25 seconds to activate hidden strobe mode. It is available in any modes.
(Cycle the "Change modes" for 2 times to activate hidden strobe mode)
Package included
1x Bronte BT01 led flashlight
1x Aluminum Gift Box
1x Clip
1x Key-ring
2x spare O-ring
1x User Manual(English)
