color LED?
16 posts / 0 new
mercrazy
Last seen: 2 years 4 weeks ago
color LED?
i need 2 different color LEDs.
what is the highest lumen LED in red or green? these are not 2 colors in 1 LED but 2 separate LEDs.
will 100 lumens of red appear the same brightness as 100 lumens of green?
thanks
mercrazy
Enderman
Enderman's picture
Last seen: 1 hour 44 min ago
10k+ lumens of green:
https://www.osram-os.com/osram_os/en/products/product-catalog/led-light-...
A few hundred lumens of red:
100lm of any colour should look about the same brightness, the problem is finding red LED that can output as many lumens as a green LED.
Lexel
Lexel's picture
Last seen: 3 days 5 hours ago
LE R Q8WP seems like a nice LED with XPL footprint
just stupid you have to order 2000 of those
mercrazy
wow, that green is unbelievable.
looks like red is the hard one. i guess i’ll get the brightest red and pick greens to match lumens.
where can i buy samples of those reds?
any idea on price?
thanks
mercrazy
Vegas LED Fan
Last seen: 6 days 12 hours ago
If you really want to do it the budget way, order some COBs from China for less than a dollar. The design of these chips is with white being 100 lumens so red ends up being 80 lumens since red LEDs give off less light than the comparable white ones. I’m not sure of green though. It says 80-100 lumens per COB. They are rated for 12V DC. Three amber ones made a really nice turn signal for my car. An alternative is to buy a bulb for a car. I tried that with red and was pleased with how bright they were. I didn’t end up using them for the stop light in the car but since they cost so little, it was worth the experiment.
The COBs go by the name “7 Color COB Chip” or “7 Color Boat COB
If you cut and paste the followingbold numbers into the Ebay search box you will see examples at the prices I listed
Bare chip (waterproof) $.78 282529971555
Encased in a plastic module $.98 302416489818
Higher power COB chips from 10 to 100W but these need a heat sink to keep from frying $.85 to $2.34 depending on wattage 252992793984
Auto bulb with a T10 base, 100 lumen 12 LED $.99 112574579558
DoubleA
DoubleA's picture
red is always dimmer when compared to green of the same wattage. Smile
Then there is the wave length issue which decides what color can be seen from the farthest.
and on the first day he said "Let there be light"...
MorePower
Last seen: 3 months 3 days ago
Phlatlight PT54 has a high output red LED.
https://www.ebay.com/itm/Phlatlight-PT-54-Red-625nm-700-Lumen-LED-With-Heatsink-Optics-/181552539969
Or buy it directly from DTR-LPF’s webstore instead of ebay: https://sites.google.com/site/dtrlpf/home/led-s
alpg88
Last seen: 15 hours 45 min ago
the way our eye sees it, depends a lot on wavelength, red will always be dimmer to our eyes than green, even if sphere sees same lumen number,
if you looking for bright red or green, cree has nothing to offer, xpe2 are about 100-150lm tops for colors. you need either luminus sst leds, or ledengin lz4.
Enderman
Enderman's picture
Uh, if white is 100lm then red would be more like 10-20…
I don’t think you realize how much less lumen output you get on the red spectrum.
Vegas LED Fan
It is true that red LEDs have a much lower output compared to natural white. As best I can figure out from the listings for COBs shown above it is around 400 lumens for red and 900 lumens for cool white if the table at this eBay listing is correct 131747229566. They list Green as 700 lumnes. It is complicated by the human eye seeing colors differently. Some sellers list “luminous intensity” as a way to compare lights of different colors rather than just lumens.
I own both a XML-T6 red and a XML-T6 white flashlight. The red one was rated 800 lumens which agrees perfectly with the CREE spec sheet for the output at 1500 mA. The white one is around 1000 lumens and I have seen the spec sheet for white listing it from 980 to 1070 lumens for the T-6 bin. Both are really bright. You don’t want to look directly at either one.
I DIY’d one of the red 1W, 3V boat shaped COBs into a rear bike light powered by a 18650 battery and with a flasher for strobe. It is plenty bright enough to be seen during the daytime.
Enderman
Enderman's picture
The reason red lumens are so low is because of the way the eye sees colours differently.
An integrating sphere measures the lumens with a luxmeter, and a luxmeter is calibrated to show the intensity the way the human eye sees it.
So for 1W of red vs 1W of green, the green will have a much higher reading, because that is how it would look to your eyes.
Basically, you can think of a luxmeter as an artificial eye, and that’s why red colours have far fewer lumens.
DoubleA
DoubleA's picture
you mean fewer luminous intensity? like this chart here shows about 5mm leds.
Enderman
Enderman's picture
Yes, lumens = luminous intensity = luminous flux.
DoubleA
DoubleA's picture
Facepalm . lumen is a measurement of luminous flux, or the total amount of light produced by a light source whereas luminous intensity(candela) tells you how bright the light source is, which shows how far away from an object you can be and while still being able to see it?
Example a laser pointer will have an extremely low lumen value but a very high candela rating.
lumens = luminous flux luminous intensity
Update:
A good way to remember the differences between terms is:
Lumens are how much light is given off
Lux is how bright your surface will be
Candela measures the visible intensity from the light source.
Sirius9
Sirius9's picture
Last seen: 5 days 14 hours ago
This are awesome, I have several, bought from DTR, they rock at 8A Big Smile
Enderman
Enderman's picture
Haha oops, did not read that one through.
Yes, you use an integrating sphere to turn the reading of intensity info flux, that’s what I meant.
They are proportional.
