XM-L vs XP-L
23 posts / 0 new
mercrazy
XM-L vs XP-L
why would cree xml be chosen over xpl?
appears xpl is better in price and equal or better in performance?
am i missing something?
better cooling for xml?
thanks
mercrazy
hIKARInoob
hIKARInoob's picture
Last seen: 3 hours 14 min ago
XML was released about 7 years ago or so? Then came XML2, and then XPL (couple of years ago). Now you also have XPL2. I only see XML in budget lights these days. XPL is much more efficient than XML, and I can only think of lower price for the XML why they are still being used.
djozz
djozz's picture
Last seen: 6 hours 34 min ago
Their efficiency is very close.
hIKARInoob
Really? I’ll be danged.
Ronin42
Ronin42's picture
Last seen: 1 day 2 hours ago
I might very be wrong or partially wrong.
When I looked things up my conclusion was:
a larger hot spot/floodier/lower driven amperage, the XML2 was on paper “better” (V8)
The
XPL2
more of a small spot/throwier/better performing if pushing hard, on paper “better” (V6 with a turbo)
mainly similure output but “feel” different
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
CRX
CRX's picture
Last seen: 4 hours 55 min ago
XM-L/2 looks better Smile
mercrazy
i love V8s, i don’t like V6s, but mainly due to sound.
if they both do the same work with no sound, would i know the difference?
how do XMLs look better? please explain to a novice.
thanks
mercrazy
Jack Kellar
Jack Kellar's picture
Last seen: 1 hour 43 min ago
And from what I hear, the XP-L line has horrible tint shifts.
Lexel
Lexel's picture
Last seen: 2 hours 2 min ago
XML2 has the same tint shift, XPL2 worse
CRX
CRX's picture
mercrazy wrote:
how do XMLs look better? please explain to a novice. thanks
Just a personal preference Big Smile
MascaratumB
MascaratumB's picture
Last seen: 1 hour 20 min ago
Does the tint shifts also apply to the XPL-HI? I have only one with XPL-HI (doesn’t shift that much, as far as I perceive) and another on the way, and I’m curious to know if they shift as much as the others!
Thanks in advance Thumbs Up
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 ///
 Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7   TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
 MY GIVEAWAY (FW3A)
Persechini
Persechini's picture
Last seen: 2 weeks 3 days ago
An SMO reflector can mess up tint so much I guess the LED choice wouldn’t even matter that much in this aspect
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
Lexel
Lexel's picture
XPL HI has very little tintshift
MascaratumB
Is it due to be “dedomed”?
 MY GIVEAWAY (FW3A)
CRX
CRX's picture
Haven’t noticed much with the XP-L HI but tried an XP-L2 in a reflector and hated it.
mercrazy
again, complete newb here, but i don’t understand cri, tint shift and so on.
for my project i only care about illumination to navigate. is cri. etc. something i should be concerned about? i’ve noticed on the flashlight forums, cri gets more attention than anything.
thanks
mercrazy
djozz
djozz's picture
thanks
If illumination for navigation is the goal, neither tint shift or CRI is something to be concerned about. There is a discussion that neutral white is easier for the eyes than cool white light, but even that is a matter of preference.
So in your case just ignore the bunch of tint snobs around here (me being one of them Innocent )
CRX
CRX's picture
mercrazy wrote:
for my project i only care about illumination to navigate. is cri. etc. something i should be concerned about? i’ve noticed on the flashlight forums, cri gets more attention than anything. thanks
Depends what you’re navigating through, woods, rocky terrain, snow, outdoor uneven natural surfaces you would appreciate a high CRI neutral tint for better perception of depth etc. I’ve found myself in electrical cupboards on a few occasions with just a 6500K 1A tint feeling like I’m in some action movie unable to distinguish which wire is what colour LOL
Jack Kellar
Hah, same here Big Smile
Rule of thumb is: those yellow streetlights have very low CRI, so everything seems like the same yellow color. CFL lamps are cool white with mediocre CRI, so it bleaches everything pale but lets you tell your reds from your yellows and your blues from your greens. Daylight, on the other end of the comparison, is when you see the TRUE colors of whatever you’re looking at – it has the highest CRI in the scale.
Biker1-
Biker1-'s picture
Last seen: 1 year 1 month ago
Found myself in the same situation in telephone closets.
Wasn’t good at all distinguishing those pairs, being washed out and all. I had another light with better CRI and issue was resolved. Huge difference in this instance.
Persechini
CRI is how well color gets reflected, LEDs come usually from 70s to 80s, but high CRI options are not uncommon (CRI over 90). The higher, the more vivid, but it’s a matter of personal preference how much weight you give to CRI when selecting an emitter.
Tint shift is the difference in tint from the center of the beam to the outer edge of the spill, and this changes with LED, reflector/optics type and material, weather the emitter was dedomed or not, if the front glass has anti-reflective coating or not. If the hotspot is blueish, the corona gets yellow and the spill gets green, for example, it will be an ugly light, so ideally you get the tint you prefer with little shift as possible
In my Tree
Firelight2
Firelight2's picture
Last seen: 3 min 56 sec ago
In my experience, CRI matters very little. I suppose its helpful if you’re viewing art or are a photography, but in most cases its irrelevant.
On the other hand, Tint makes a much bigger difference. Cool tints make outdoor terrain look flat and are harsh on the eyes. Neutral tints look much more pleasant and make it easier to resolve objects you’re looking at. Warm tints are also very pleasant outdoors, but look too orange indoors.
Lexel
Lexel's picture
you ever saw greenish pale skin on a NW CRI70 LED compared to a decent CRI80 or CRI90 LED with more red
