Maeerxu M8 26650 Flashlight Discussion Thread /// Green is Instock Now
171 posts / 0 new
freeme
freeme's picture
Last seen: 1 min 6 sec ago
©freedailydeals.org
Price: $29.99 ($36.99) Coupon:  FMXM8   (exclusive) / My link: Proceed to Store
Stepless Dimming
● In on status,Press 1 second to activate Stepless Dimming Mode
- From moon to turbo need 6 seconds,release the switch can memorize the brightness
- Tap to turn off the flashlight
Button dimming
● First clicky to get the moon mode,Tap once to turn off the flashlight
● Double clicky to get the Turbo mode,Tap once to turn off the flashlight
● Quicky clicky 3times to get the SOS mode,Tap once to turn off the flashlight
● Quicky clicky 4times to get the Mode2,will strobe 4times,then you hold press to keep light on,when you release will light off.Quicky clicky 4times again to out off the Mode2,will strobe 2times.
● Quicky clicky 6times to Lock out the flashlight,will strobe 4times,then the flashlight can not light on.Quicky clicky 6times again to unlock the flashlight,will strobe 2times.
● Quicky clicky 8times to get the Mode3,you will get a new strobe mode which has a different strobe frequency.Quicky clicky 8times again to out off the Mode3.
©freedailydeals.org
Features:
● Switch indicator light
- Charging light red,Full charging light blue
- When turn on the flashlight,the Voltage between 3.2v~4.2v light blue,lower than 3.2v light red strobe
● Low-voltage protection
- When the Voltage lower than 3.2v will enter moon mode automatic
- When the Voltage lower than 2.5v will turn off the flashlight automatic
Package included:
1 x Maeerxu M8 XPL 1200Lumens Stepless Dimming Long Range LED Flashlight
©freedailydeals.org
Single 26650 class flashlights with approximately 40mm head.
©freedailydeals.org
Are you able to spot the similarities?
©freedailydeals.org
M8 comes with built-in charging function which is pretty handy in my opinion.
©freedailydeals.org
First thing i have noticed was the weight of the head, and i did a quick measurement.
Weight
Head: 195g ( 6.88 oz),
Whole light: 255g (9 oz)
M8 with 5000mAh 26650: approximately 350g (12.4oz).
Edited by: freeme on 06/27/2018 - 14:46
freeme
freeme's picture
Reserved for quick review. cool
charles lin
charles lin's picture
Last seen: 1 month 5 days ago
Freeme, the code is not working! Question
-X3-
-X3-'s picture
Last seen: 1 hour 31 min ago
Wow 6 seconds from ML to Turbo ? That’s an insane long time to wait Shocked
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
freeme
freeme's picture
Have to wait till preorder promo ends (Nov 12).
charles lin wrote:
Freeme, the code is not working! :???:
Gj
Gj's picture
Last seen: 10 min 35 sec ago
Do they intend to carry the green one, too?
The Miller
The Miller's picture
Last seen: 10 months 2 weeks ago
Pre order so no ideas how good the internal charging is?
freeme
freeme's picture
Credit to cyp1350. From the buyers comment, M8 draws 5A on highest mode, follow by stepdown to 3.5A after 2mins. [To be confirmed after sample arrives.]
djozz
djozz's picture
Last seen: 51 min 14 sec ago
Hmm, a screwed-down Noctigon… If that implies that Hank is involved in this light I may be interested, provided the driver is high output direct drive type (edit: as I type, the 5A is added ^ , good enough for me Smile )
patmurris
patmurris's picture
Last seen: 6 days 1 hour ago
The UI seems quite complicated and slow… What are mod2 and mod3… 8 clicks!
I don’t understand how this works.
Parasitic drain?.. Tint options?
What’s that brand?
freeme
freeme's picture
Not my pic.
surasakkongtha
Last seen: 3 hours 2 min ago
Why not store has color green?
charles lin
I think M8 is made by same OEM manufacturer as Hank’s.
What’s that brand?
UI is quite simple, similar to D4 v2 Ramping UI.
one press ON, one press OFF
press & hold- RAMP
2x press- turbo
3X PRESS- SOS
4X PRESS- TURBO MOMENTARY
6X PRESS- LOCKOUT
8X PRESS- BEACON
sahala
Last seen: 1 year 1 month ago
I heard that the Noctigon MCPCB is only on the prototype, the stock one is with the regular MCPCB.
freeme
freeme's picture
Will check with its supplier.
sahala wrote:
djozz wrote:
Hmm, a screwed-down Noctigon... If that implies that Hank is involved in this light I may be interested, provided the driver is high output direct drive type (edit: as I type, the 5A is added ^ , good enough for me Smile )
g_sintornillos
g_sintornillos's picture
Last seen: 6 months 5 days ago
Subscribed
Sorry for my bad English (gogole transtorla)
PBWilson
Last seen: 48 min 8 sec ago
Looks interesting. Thanks for the info.
Tom E
Tom E's picture
Last seen: 57 min 10 sec ago
Coupon no longer works. I pre-ordered one for $32.99. Hope it's ATtiny85 based - sure sounds like Hank's, but in addition has USB charging.
Betta the 5A is only because of FET based output with Hank's springs, etc.
It's either a ripoff or official project of Hank's.
freeme
freeme's picture
Sample is on the way!
Tom E
Tom E's picture
Mine shipped today as well.
freeme
freeme's picture
©freedailydeals.org
ramptosd
Last seen: 3 weeks 16 hours ago
Does anyone have an idea of candela? looks impressive in the pictures.
freeme
freeme's picture
About 0.72 times of D1s lux value for my 3m test. Not going to supply the measured values as I suspect my readings are on the high side for my GM1020 meter.
Itsme
Last seen: 1 week 21 min ago
Interested
Tom E
Tom E's picture
BG's listing says 800 meters, which, doing the math, is 160 kcd. For a 54 mm head diam and true FET driver, I suppose this could be possible.
I got the M8, D1, and D1S all on the way, but may be a little while yet.
From the pic above, though the M8's head is wider, looks like the reflector I.D.'s might be about the same - the M8's bezel setup looks wasteful on reflector width.
As freeme measured, maybe the M8 is not a true FET, or is using thin LED wires and poorer performing springs, or could be just the difference between a XPL vs. a XPL HI. Hank's Emisar lights use the great performing Beryllium copper springs, here: http://intl-outdoor.com/gold-plated-beryllium-copper-spring-5-pcs-p-831.html, shown with djozz's spring test results.
M8 is XPL, D1S is XPL HI.
Itsme
should the preorder promo end date have been Dec. 12? Looks cool. I like the ramping since I got the Q8
Thanks
BOMBAY
Last seen: 25 min 56 sec ago
preorder? i see only alert me on arrival.
freeme
freeme's picture
BG has been suspended M8 preorder temporarily due to lack of stock. I will update once it is ready.
Jerommel
Jerommel's picture
Last seen: 1 month 1 week ago
subbed.
Nice looking light.
2Q19
Tom E
Tom E's picture
Received mine today - came on one of those green plastic padded cases, cheap but ok. Spare lens, USB cable, lanyard., o-rings.
it's a 4000K XPL HI LED - did not expect that...
I know it's a 4000K because today I also received a D1S from Neal with a XPL HI V2 5D 4000K and they match tint pretty much exactly.
The UI may be a V1 Emisar - last used level is not remembered, so from OFF, a single click always starts at lowest. The 3X click is battery voltage, not SOS as noted earlier.
The ramping is klunky - not consistent, and intensity of the hot spot is not as bright as the D1S, but it could be the battery I used.
The 26650 battery tube is too narrow - one LK 5000 cell I tried will not fit, but fits a Manker U21 perfectly. I popped in a EVVA protected I had laying around, fits but it's tight, but the length is another problem - partially crushed the + cap on the EVVA.
On the M8 there is a switch LED, blue, but it goes on when the light is ON, OFF when the light is OFF.
The M8 is a slightly smaller carry light than a U21, but quite a bit bigger than a D1S. Reflector ID appears to be bout the same as the D1S because the M8 has a wastefully wide bezel, though it's a nice chunk of SS.
giorgoskok
giorgoskok's picture
Last seen: 1 day 21 hours ago
Where did you get it from Tom ?
Thanks
Edit : I guess banggood had it in stock some time ago , i thought they hadn’t any stock at all
