ReyLight Pineapple mini (copper) AAA/10440 flashlight (OP Updated)
191 posts / 0 new
alphazeta
alphazeta's picture
WWEFANS wrote:
On amazon now. Code: GL497KM4 https://www.amazon.com/dp/B076YDYTS5
Gr8! Just ordered. thx! Thumbs Up
MastyrOfPuppitz
Last seen: 2 months 6 days ago
Ordered 2!
pc_light
pc_light's picture
Last seen: 15 hours 51 min ago
Amazon ordered. Thanks.
Move towards the light.
WWEFANS
WWEFANS's picture
Last seen: 1 day 7 hours ago
Thank you. Your earlier message showed you want a new driver assembly.
Muto
Last seen: 5 min 35 sec ago
Ordered with Amazon Prime.
Thanks!
Keith
After the Apocalypse there will be only 2 things left alive Cockroaches and Keith Richards
alphazeta
alphazeta's picture
No, you must have been mistaken. I didn’t mention this.
In any case I wanted to see how this light behaves in person. If I find that it needs to be rectified I’ll send you a PM. So glad that we have you regularly churning out new lights for the community. I (& I’m sure many of us) wish you continual success in your endeavors! Thumbs Up
WWEFANS
WWEFANS's picture
I meant pc_light, quote: “Amazon + 1x Driver (correction) Assembly
Thanks.”
alphazeta
alphazeta's picture
My fault! Ughh Too early in the morning when I read this msg. Geez, you even explicitly quoted PC_light Facepalm Sorry Rey
Nguyen
Nguyen's picture
Last seen: 2 hours 48 min ago
Amazon ordered.
Thanks.
WWEFANS
WWEFANS's picture
I thought it was another account of yours.
rondohatten
Last seen: 2 hours 2 sec ago
i ordered one from amazon.
thanks for your hard work.
pc_light
pc_light's picture
LOL, just caught up on the threads. Funny.
Yes, I would still like Assembly.
Pls PM pmt details.
Thanks.
MastyrOfPuppitz
I take it the code is no longer applicable. Tried it and did not work.
WWEFANS
WWEFANS's picture
I will check it.
MastyrOfPuppitz
It still doesn’t work…don’t know if you tried to fix it. Just an FYI.
travis
Last seen: 17 hours 18 min ago
Ordered this BEAUTIFUL ! Light. Smile
BTW- the discount code worked for me
A well regulated Militia, being necessary to the security of a free State, the
right of the people to keep and bear Arms, shall not be infringed.
MastyrOfPuppitz
I made a purchase a couple days ago with the code and it worked. I try to make another purchase now and it won’t.
lumenzilla
lumenzilla's picture
Last seen: 4 hours 57 min ago
I was about to send paypal to Rey but I have to pay a blackfriday deal for flashlight which is in my wish list for long time Facepalm
Let’s collect mwoar money Crown
MastyrOfPuppitz
Ok I guess I wont buy another one.
jon_slider
jon_slider's picture
Last seen: 2 hours 7 min ago
the code GL497KM4 works for me.. maybe you have a typo?
How to hide signatures, and ignore someone, http://budgetlightforum.com/node/44835?page=3#comment-1438048
MastyrOfPuppitz
Via copy/paste, so…no.
somnambulism
Last seen: 1 year 1 day ago
Is the code limited to one use per account?
xdouang
Last seen: 2 weeks 5 days ago
Amazon
WWEFANS
WWEFANS's picture
Just checked, the code was for one use one account only. But fixed now.
rondohatten
hello:
i have received my light, and it is lovely looking and even teenier than i thought.
however, this is my first “twistie” flashlight, so i wonder if you could post a bit about how to operate most effectively.
i’ve pretty much figured it out, but would love to have simple step by step instructions.
for example: are folks able to operate this one handed? because the twisting action seems way
to “tight” to do this. or will the threads break in? another example: what is the best way to turn the light off?
so far, i always have to check and make sure i don’t leave it on moonlight.
i’m currently running a tenergy centura AAA; i assume this is good to go.
thanks, and again, this seems pretty cool.
jon_slider
Congrats on your new light, yes your batteries are a good choice.
Your light has 3 brightness levels. Starting from off, you twist on and get the first level.
a quick twist off and back on, and you get second level. Again quick twist off and on, you get third level. Again quick twist off and on, you get back to first level again… it continues the same, each quick off on, from On, gives next level..
to turn off untwist half a turn or so, until the light goes out.
here is a video:
yes it will become easier one handed once the Oring loosens up. You can test this by removing the Oring, just don’t put it under water without the Oring. It is OK not to use the Oring, if you like how easily it works one handed.. eventually it will work one handed with the Oring too.
It is OK to lubricate the Oring, but if you use too much, the light will become finicky and skip levels, because the oil will make contact unpredictably. So, don’t overlubricate..
when you twist for off, if you only twist less than 1/4 turn, the head can be pressed towards the body, or at an angle, and the light will turn on. this is not a good thing, because it can come on in your pocket, so after twisting off, do a test, push the head towards the body to make sure it is unscrewed far enough not to trigger the switch when the head is pressed.
enjoy!
WWEFANS
WWEFANS's picture
The oring is tight, yes. to prevent the head getting lost of falling off. After some using, it will become loose.
MastyrOfPuppitz
Thanks! I am going to order another one in a few days.
Rusty
Last seen: 1 hour 31 min ago
My two arrived today and they’re gorgeous, thank you Smile very bright using a AAA NiMH; on 10440 the output is amazing for the size but it doesn’t take long to get hot, so i will keep an eye on it (using an Efest IMR 10440).
The pre-flash in moon mode is absolutely not an issue at all, as you have already pointed out you really need to be looking for it to notice it.
I have a tritium vial coming soon, something which i’m new to; i wondered if superglue was appropriate to cement it into the slot in the light? I’ve done some searches and various products have been mentioned which are either prohibitively expensive for the single use that i need, or are difficult to get hold of in the UK, hence my fallback of superglue Smile
MastyrOfPuppitz
Pre-flash is highly noticeable using 10440’s with mine.
