I'm studying the Battery Comparator graphs for AA/AAA batteries http://lygte-info.dk/review/batteries2012/CommonAAcomparator.php
For common primary AAA versus Eneloop AAA (normal or lite) batteries,
at 0.1A current drain, the primary AAA (alkaline) might have a slightly higher capacity (mAh) than the Eneloop AAA.
but at 0.2A current drain, the alkaline AAA and Eneloop AAA will have nearly similar capacity, although the Eneloop would have a higher voltage for most part of the usable capacity.
at 0.5A current drain, the primary AAA will basically have half or less the capacity of an Eneloop AAA.
(Reason for this is I only have a handful of Eneloops, while we have many alkalines at home, so I'd like to know which lights would work OK with alkalines [ie. the light's current consumption is less than 0.2A]; also the lights may not be used that often, so using the cheaper alkalines would still be ok.)
So, what this means is that in most cases, an Eneloop AAA (or other comparable LSD NiMh) will be better choice.
I decide to check the current drain of some lights we have at home (using an uncalibrated Mastech MS8229 multi-meter to check tail current)
1) Energizer 3xAAA (4.5v) flashlight, using new alkaline AAA or Eneloop AAA, I measure the current at just around 0.11A (does this mean 0.11 divide by 3pcs AAA = .037A current drain for each AAA). In this case, since it has a very low current drain, an (3pcs) alkaline AAA would probably have longer runtime than the Eneloop AAA. <== Is this assumption correct?
2) COB LED flashlight: I purchased these lights (also uses 3xAAA) in 2 occasions from this AliExpress seller:
a) The earlier batch, I measured a current of around 0.36A (using freshly charged Eneloop AAA) for the COB LED light, and around 0.22A for the front light. (if I just subjectively [sorry, I don't have a good brightness-measuring equipment] compare the front light, it seems the 0.22A front light is about as bright as the 0.11A light of the Energizer 3xAAA flashlight)
b) However, for the 2nd batch, I measured a current of around 0.82A (freshly charged Eneloop AAA) for the COB LED light, and around 0.44A for the front light. (comparing the 0.44A front light to the Energizer 3xAAA flashlight, this is noticeably brighter, but not twice as bright -- considering it's using 4 times as much current).
For the 0.36A COB LED light (divide by 3xAAA), that means just 0.12A per AAA battery, so if using alkaline AAA should still yield good capacity. (and current drops as voltage drops)
For the 2nd batch 0.82A COB LED light (divide by 3xAAA), that gives 0.27A per AAA battery, now this is double the 1st batch (the 2nd batch' light output appears somewhat brighter, but not too significant), using Alkaline will probably not be that good anymore.
Is the above analysis correct?
3) COB LED headlamp (also uses 3xAAA):
- using the freshly charged Eneloop AAA (well, it's not that freshly charged anymore since I used it to test above, so voltage could have dropped very slightly), measure 0.46A on 'high' setting, and 0.11A on 'low' setting.
so on 'high' setting, 0.46A divide by 3 = around 0.15A per battery. Using alkaline is still OK compared to using Eneloops.
on 'low' setting, 0.11A divide by 3 = around 0.037A per battery, then alkaline will likely have longer runtime
4) 3+1modes LED headlamp (also uses 3xAAA):
- using (somewhat) freshly charged Eneloop AAA, the white light on 'high' gives around 0.35A current (divide by 3 = .12A per battery), so using alkalines would still be good.
- white light on 'low' setting uses around 0.10A; red light uses around 0.07A, so alkaline might have longer capacity.
5) 'generic' 3xAAA flashlight (similar size to the Energizer 3xAAA flashlight above):
- this is an older flashlight lying around at home, I measured its current to be around 0.30A, so that means around 0.10A per battery. Using alkalines would still be OK. This generic light seems to be almost as bright or only slightly brighter than the Energizer 3xAAA flashlight (which uses just 0.10A or 0.033A per battery). Seems like the Energizer 3xAAA flashlight is really designed much better..
in conclusion, only the COB LED flashlight that uses 0.82A would not fare well with alkalines, but the rest should still be OK. Also special mention to the Energizer 3xAAA which seems to use a comparatively low current (just around 0.10A) and outputting an adequate amount of light for close-up indoor needs [this flashlight is rated by manufacturer to have 'up to 45 lumens', which I'm unable to verify though])
