CRX DQG Flashlight Mods
11 posts / 0 new
CRX
CRX's picture
Last seen: 3 hours 8 min ago
Some of my mods to the small DQG flashlight range.
CRX CuTi Laser Osram PLTB450B 450nm 1600mW - OFBD 1.6A - 10280 - Mo Button & Twisty Tail Sw - 1600mW.CRX CuTi Laser Osram PLTB450B 450nm 1600mW - OFBD 1.6A - 10280 - Mo Button & Twisty Tail Sw - 1600mW.Made from a DQG Titanium pill capsule with Ti extensions & hand made copper parts, a little pocket monster Big Smile
Osram PLTB450B 1600mW 450nm 5.6mm TO56 Diode
3-Element collimating glass lens assembly
9.5mm x 0.7mm ARC protective glass
Copper diode housing & heatsink
Head twist focusable
Upgraded focusing spring
Silicone compression focus O-ring
0-1600mA adjustable potted single cell boost driver
Brass lined body parts
Magnetic momentary tail switch button
Lock-out able
Blue GITD glow inserts
Magnetic tail & keyring holder
Max - 1600mW, 1.6A (Around 1120mW OTF with 70% efficient 3-E Lens)
Length - 79mm
Width - 12.7mm
Weight - 35g (With 10280 cell)CRX CuTi Laser Osram PLTB450B 450nm 1600mW - OFBD 1.6A - 10280 - Mo Button & Twisty Tail Sw - 1600mW.The centre glow part in the tail is the magnetic momentary button, surrounded by an 8mm x 4mm neo ring magnetwhich fits into a magnetic keyring holder.CRX CuTi Laser Osram PLTB450B 450nm 1600mW - OFBD 1.6A - 10280 - Mo Button & Twisty Tail Sw - 1600mW.
CRX CuTi Laser Burning Matches  CRX CuTi Laser Burning Balloons
CRX DQG Titanium 10180, 10280, 10440 Pocket Charger/ Spare cell carrier.CRX Titanium 10180, 10280, 10440 Pocket Charger..
This titanium spare cell/ pocket charger, being modular can carry and charge 10180, 10280 and 10440 cells.
It has a 100mA charge rate.
Made from a DQG titanium pill capsule & extension pieces plus a charger unit from a 10180 rechargeable flashlight.
The section with the brass rings can be removed & used to extend the laser to use a 10440 cell and the remaining sections will still house the other 10280 cell that the laser normally uses.
This is made to accompany my:
CRX CuTi Osram PLTB450B 450nm 1600mW - OFBD 1.6A - 10280 - Mo Tail Sw - 1600mW Laser.
10280 cell version:CRX CuTi Laser Osram PLTB450B 450nm 1600mW - OFBD 1.6A - 10280 - Mo Tail Sw - 1600mW.....
10440 cell version:CRX CuTi Laser Osram PLTB450B 450nm 1600mW - OFBD 1.6A - 10440 - Mo Tail Sw - 1600mW.
DQG Hobi Ti+ Seoul Viosys 365nm UV & Petrol Lighter - ZWB2 - DD - 10250 - Twisty Sw - RechargeableDQG Hobi Ti+365nm UV & Petrol Lighter - R1 - 10280 - Twisty Sw - Rechargeable.A torch in both senses Wink
Seoul Viosys Z5 series, 365nm UV LED, CUN66A1B
10mm sinkpad soldered to brass pill
Ground down 11mm ZWB2 filter
Direct drive, single mode
10250 cell
2 x 6mm x 1.5mm green tritium vials
Magnetic detachable tail unit
USB rechargeable
DQG petrol lighter
Max current 500mADQG Hobi Ti+365nm UV & Petrol Lighter - 10280 - Twisty Sw - Rechargeable.
Seoul Viosys UV on some currencydjozz UV Emitter Tests
CRX Utility Keyring - CRX CuTi Atom, Ti Hobi+ 365nm UV & Petrol Lighter, Ti Pen & Toothpick, CuTi 1.6W 450nm Laser.CRX Utility Keyring - CRX CuTi Atom Nichia 219C, DQG Hobi+ 365nm UV & Petrol Lighter, 1.6W 450nm Blue Laser.
DQG Hobi Ti 532nm Green Laser - 10250 - Mo, Twisty Magnetic Tail Sw.DQG Hobi Ti 532nm Green Laser - 10250 - Mo, Twisty Magnetic Tail Sw.Powered by a 10250 cell and has a magnetic mometary/ twisty tail switch, this is made from a DQG pill capsule and three extension pieces.
The beam is extremely visible at night but can be seen in daytime too with the aid of some smoke blown on as shown below.DQG Hobi Ti 532nm Green Laser - 10250 - Mo, Twisty Magnetic Tail Sw.
DQG Fairy Brass XP-E Red - SD - 10180 - Twisty Sw - 140RlmDQG Fairy Brass XP-E Red - SD - 10180 - Twisty Sw - 140Rlm
CRX Brass DQG 10180,10250,10280 Charger - 70mA - 200mACRX Brass 10180,10250,10280 Charger - 70mA - 200mA.
DQG Hobi Ti Seoul Viosys 365nm UV - DD - 10180 - Twisty SwDQG Hobi Ti Seoul Viosys 365nm UV - DD - 10180 - Twisty Sw.DQG Hobi Ti Seoul Viosys 365nm UV - DD - 10180 - Fw Clicky Keyring Tail Sw - AnodisedDQG Hobi Ti Seoul Viosys 365nm UV - DD - 10180 - Fw Clicky Keyring Tail Sw - Anodised
CRX DQG PCL - XP-L HI v2 1A - Hobi+ Driver - 10180 - Twisty, Mo Magnetic Sw - 90lmCRX DQG PCL - XP-L HI v2 1A - Hobi+ Driver - 10180 - Twisty, Mo  Magnetic Sw - 90lm.
DQG Hobi Ti & Brass Aspheric XP-G2 - DD - 10250 - Tail Charger ModuleDQG Hobi Ti & Brass Aspheric XP-G2 - DD - 10250 - Tail Charger ModuleDQG Hobi Ti XHP50 J4 3C - FET 10 - 2x10250 - Mo Side Sw, Tail Twisty - 1600lmDQG Hobi Ti XHP50 J4 3C - FET 10 - 2x10250 - Mo Side Sw, Tail Twisty - 1600lmDQG Hobi Ti & Cu XHP50 J4 3C - FET 10 - 2x10250 - Twisty Sw - 1600lmDQG Hobi Ti & Cu XHP50 J4 3C - FET 10 - 2x10250 - Twisty Sw - 1600lmDQG Hobi Ti SST-40 - QTC/ DD - 10440 - Twisty Sw - 1300lmDQG Hobi Ti SST-40 - QTC/ DD - 10440 - Twisty Sw - 1300lmDQG Spy Ti XP-G2 NW - SD - 10180 - Twisty Sw - 100lm - NeckChainDQG Spy Ti XP-G2 90 CRI - SD - 10180 - Twisty Sw - 120lm - NeckChain
DQG Spy Ti runtime graph:
DQG Spy Ti Runtime Graph
DQG Hobi Ti Dual XP-L HI & XP-E2 Amber - SD - 2x10250 - Twisty Sw - 120lm With XP-L HI v2 1A and XP-E2 Amber emitters. 2 x MBI 10250 cells.
DQG Hobi Ti Nichia 219C 5000K - SD - 10180 - Fw Clicky Magnetic Tail Sw - 110lmDQG Hobi Ti Nichia 219C, magnetic forward clicky tail switch. Can work by tail switch or twisty, starts on low or high mode.
Switch construction.
10440 version.
DQG AAA Clicky Samsung LH351D 4000K 90 CRI - SD - 10440/AAA - Fw Clicky Sw - 174lm
DQG AA Ti XP-L HI v2 1A - FET 10 - 14250 - Fw Clicky Tail Sw - 924lm - RechargeableXP-L HI v2 1A on 16mm Noctigon
Narrow spot TIR
FET 10 driver
Potted
Graphite aesthetics
Forward clicky magnetic tail switch
Green 6mm x 2mm tritium vial
Micro USB charging port (300mA)
ME4056 charging board
Max - 924lm OTF
69mm x 18mm
Weight - 45g with 14250 cellUnscrew the head to reveal the micro USB charger port.Forward tail clicky soldered into brass tube and fixed to tail cap with brass contact ring. Brass contact points in head unit.
Charging unit is potted inside a copper housing.A 300mAh 14250 cell is used with this light.To charge, remove flashlight head, turn on the clicky switch and connect USB lead.
Red indicator for charging and green for charge complete.
The charge current is 300mA maximum, around 1C for this 300mAh 14250 cell, charge time about 1hr:10m
DQG Slim SS Seoul Viosys 365nm UV - ZWB2 - 3x7135 - 14250 - White RV Clicky SwSeoul Viosys Z5 series, 365nm UV LED, CUN66A1B
Noctigon MCPCB
Hand made copper pill
Ground down 15mm ZWB2 filter
3x7135 driver, single mode
Reflectored
14250 Cell
Lighted reverse clicky switch
Max current 1000mA
DQG Slim Ti Samsung LH351D 4000K 90 CRI - FET 15 - 14250 - Rv Clicky Sw - 924lmDQG Slim Ti Samsung LH351D 4000K 90 CRI - FET 15 - 14250 - Rv Clicky Sw - 924lm.
14500 version
DQG Slim Ti SST-40 - FET 15 - 14250 - Rv Clicky Sw - 1500lm
14500 version
DQG Slim Ti SST-40 - FET 15 - 14500 - Rv Clicky Tritium Sw - 1500lm - USB Rechargeable
I made an optional charging module for my DQG titanium extension tube light.
Made from copper, brass and carbon fibre tube this has a micro USB charging port supplying a tiny ME4056 charger board modified to supply 350mA charging current. Red & green charging indicators.
Remove the flashlight head to reveal the charging unit, click the tail switch on and plug in USB lead to charge.Luminus SST-40 on 14mm Noctigon
MTN 15mm FET driver with GuppyDrv3 firmware
Cyan GITD LED surround
Hand made copper pill, charging unit & switch housing
Reverse clicky tail switch with green Tritium Vial
Magnetic tail
Length - 104mm
Width - 17mm
Weight - 62g with 14500 cell
Max around - 1500lm OTFDQG Slim Ti SST-40 - FET 15 - 14500 - Rv Clicky Sw - 1500lm - Rechargeable...
Edited by: CRX on 01/18/2020 - 10:40
Agro
Agro's picture
Last seen: 2 min 12 sec ago
Oslon Black and a nice TIR? Or maybe aspheric? Smile
CRX
CRX's picture
Hadn’t thought about the black Thumbs Up
DavidEF
DavidEF's picture
Last seen: 2 days 8 hours ago
Mini thrower? Find a way to use multiple stacked lenses to tighten the beam. I don’t know if it would work or not, but I thought that it could be done with one lens (might take two) to focus the “beam” from the LED down, then another lens to straighten it out at the smaller size. Other people have done it at larger sizes, but if you could do it at the tiny size of a DQG Hobi, that would be cool. Maybe it would require use of some Fresnel lenses in order to take up less space.
- The YKK Philosophy
The Miller
The Miller's picture
Nice!
Love the title Big Smile
Dig the brass rings.
Just dang impressive!
ven
ven's picture
Last seen: 1 week 6 days ago
Genius, crazy, ridiculous…………whats not to love! Big Smile
CRX
CRX's picture
Thanks guys, and a couple of good ideas to keep me thinking Thumbs Up
CRX
CRX's picture
I made the thrower today, more details in the OP.
DavidEF
DavidEF's picture
Wow! Nice work, CRX! The smallest pocket thrower ever made? Crown
CRX
CRX's picture
Thanks Dave, yeah it's even a wee bit smaller than the carbon fibre zoomie Smile
Here's a couple of small lenses if you were interested in trying your own
http://kaidomain.com/p/S022173.12_5mm-LED-Glass-Lens-1-Piece
http://kaidomain.com/p/S022174.10_7mm-LED-Glass-Lens-1-Piece
DavidEF
DavidEF's picture
Thanks for the links!
