Charger Zanflare C4 vs Opus BT-C3100
19 posts / 0 new
ledoman
Last seen: 13 hours 57 min ago
I’ve got free charger Zanflare C4 for review purposes. Then I started to digg at BLF and found there are already four reviews:
http://budgetlightforum.com/node/55185
http://budgetlightforum.com/node/55720
http://budgetlightforum.com/node/55609
http://budgetlightforum.com/node/55835
“Dammn”, what to do now. Then I’ve got an idea to say few words about some differencies I could observed comparing with well known Opus BT-C3100 (C3100 in short). There is a lot of quite good chargers out there but not so many with analyzing features. Will try to concentrate on that feature.
Main difference between the two is the power they can use during charge and discharge. Since C3100 is using more power it has to use fan to cool down eletronics. Most of us has some sort of problems with C3100 fans. I have already to replace it. Fan is pretty loud and can be anoying if you want to run it in living room, specialy when you want to monitor behavior.
On the other hand C4 has no fan so it is completly quiet. Of course the power used has to be lower, specilay during discharge. Otherwise resistors would be burned quite quickly. So if you are satisfied with slower dischage C4 is good choice.
On discharge/test features I’ve noticed both chargers gives to high readings. Wanted to know why. I’ve studied HKJs reviews and hopefuly found out the reason for this. It might be obvious for some but most people probbaly won’t know. Discharge is not using constant current and it stops for short time to check the voltage. This time is not extracted from the capacity calculation. Longer is the pause higher is the capacity reading.
For test I’ve used brand new Samsung 26L M cells discharged/tested at 0.5A and got C4 on left, C3100 on right
Capacity readings for some LSD AA cells
Looks like C4 has to have longer period of pauses during discharge but it is more consistent. Will see how they are doing with internal resistance.
What do you think? Can we get some percentage to correct capacity readings?
Edit: discharged testing Samsung 2600 cells and got 2573mAh at 0.5A on iCharger 106B+ which is pretty accurate. Both chargers should show about this number.
Edited by: ledoman on 10/31/2017 - 16:41
djozz
djozz's picture
Last seen: 2 min 38 sec ago
Keep on comparing! I just started using the Zanflare C4 because I do not like the noise of my Opus BC3100. I would like to know if it can do everything the Opus does.
Sofar I understand that capacity tests take longer and that it reads even higher capacity than the Opus. Thanks for that information. I can not really help much because I’m technical enough about this stuff.
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
ledoman
Will try to add some other things and ask HKJ to explain if I’m right about those to high readings.
CharlesS
Last seen: 7 months 2 weeks ago
If you run capacity tests on high-capacity NiMH batteries such as Eneloop XX, do you see the problem I described in this thread?
http://budgetlightforum.com/node/57043
ledoman
Unfortunately I don’t own such baterires to test.
ledoman
I forgot to tell I like it being quiet, too. It is true it takes longer time, but you can put charger everywhere and not disturb anyone. For example I took it to my job and do some discharge tests in our office. It would be different if analyzing chargers would have some sort of internal logging feature so you could just read data when you get chance, but then it’s very likely they would be much more expensive.
Regarding capacity I’ll try to check real capacity with my hobby charger iCharger 106b+ which is considered quite accurate. Then we can make some sort of correction factor.
flydiver
Last seen: 17 hours 53 min ago
I have found the IR tests on the C4 to be reasonably close to the C3100, for GOOD batteries. As the batteries age, IR goes up, readings become higher and more ‘unstable’. I find the readings for ‘bad’ batteries in the C3100 can be way different in different slots or even the same slot on multiple tests. The better the battery, the lower the reading, and generally the more consistent it is.
In general I find IR reading for the C4 to be more consistent. I can pull a battery, put it back in the same slot or a different slot, and get a nearly identical reading.
OTOH, I find the SAME battery tested a month later may have a considerably different IR reading…..now that is with not so good batteries. I don’t know if the IR is unstable in old NiMh.
As I’ve noted a number of times, the IR for the Lii-500 is not accurate at all. I’ve tested 3 different chargers, they all act the same giving very low and almost identical readings on just about any battery, even some I know are quite poor and have very high IR readings in the other 2 chargers.
wolfdog1226
wolfdog1226's picture
Last seen: 3 days 14 hours ago
My Opus BT- C3100 NEVER had a noisy fan. I changed it to a DELTA fan which made my capacity readings even more accurate along w/ better cooling. Wink
http://budgetlightforum.com/node/54728
Solitude breeds contemplation which creates clarity. 7.3.2017
Environment molds a person. Perseverance changes them. 3.4.2001
        WOLFDOG
ledoman
Good for you. Unfortunately not all people can get those fans (or are to expensive shipped from USA) and not all can do replacement. But idea is good, thanks for that.
flydiver
It’s quite easy to lube the fan bearing. It won’t stop the inherent noise but will make it function (not stick), and some of the grinding noises. The longer you wait, the more the bearing wears, the worse the final result.
wolfdog1226
The replacement is SIMPLE! Take 4 screws off the back and detach/Unplug the fan, put new fan in!
There is a place in China that sells them.
2 for $11
https://www.ebay.com/itm/2pcs-DELTA-12V-0-12A-cooling-fan-AFB02512HHA-25...
        WOLFDOG
wolfdog1226
One other thing. If you did get the fan save the connector from your old fan because you may have to splice it like I did.
        WOLFDOG
ledoman
Copied from other thread.
2 for $11
Thanks for link. Quite expensive (at least for me). I can see cheaper ones but they have 3 wires. Do you possibly know what is 3rd wire for?
wolfdog1226
2 for $11
My guess would be a ground wire?I do not know for sure. The link I sent you has Two wires and is ONLY $1.50 more/$3.00 total for Two of them.
        WOLFDOG
flydiver
3rd wire is probably a signal wire (PWM) for speed control for devices that can do that. You can ignore it.
ledoman
Thanks both of you.
In mean time Ive discharged testing Samsung 2600 cells and got 2573mAh at 0.5A down to 2.8V which is pretty accurate result. Voltage on the picture is for two cells in series after some time resting, so not the one just after discharge.
wolfdog1226
Nice.
Here are brand new VTC5A discharged at 1Amp.
HKJ Got 2480mAh at 1amp. My 2 slot median is 2530mAh which is 1.94% higher than HKJ
I have had several tests where I was b/w 0.1% and 0.5% within HKJ’S numbers.
        WOLFDOG
mrbombadil
mrbombadil's picture
Since your post, do you have any additional thoughts comparing the two chargers? Are you still preferring the Zanflare C4?
I am leaning towards the Opus, but the fan noise concerns me. I do intend to test/rehabilitate a number of NiMH cells and the automatic triple cycle of the Opus (as well as twice the discharge speed) does appeal to me.
Thanks!
Thrunite TH20, Convoy C8
Xtar VC2 Plus, Nitecore F1, Opus BT C-3100
tatasal
Last seen: 3 min 4 sec ago
lf you’re familiar with the sound of a pc’s cooling fan noise on start-up, the Opus’ fan doesn’t sound much different nor louder than that.
