"Manta Ray C8.2" - Experiences?
37 posts / 0 new
L4M4
L4M4's picture
Last seen: 10 min 19 sec ago
Hi!
I stumbled across this nice looking light:
https://www.aliexpress.com/item/Self-Defense-Manta-Ray-C8-2-CREE-XHP50-2...
I love the looks of it and it seems to be well built (integrated pill, copper PCB, a lot of cooling-fins, a lot of material under the MCPCB) and doesn’t cost too much.
So – does anyone have this flashlight and can tell me if the beam is nice?
AgentSteel
AgentSteel's picture
Last seen: 57 min 7 sec ago
Interesting light! Looks like an improved C8, curious to see beamshots too Smile
Quidquid latine dictum sit, altum sonatur
bikenber73
bikenber73's picture
Last seen: 14 hours 53 min ago
Sweet!
That particular store has some interesting stuff.
If I was was still buying lights blindly, I would have made several purchases.
djozz
djozz's picture
Last seen: 28 min 3 sec ago
bikenber73 wrote:
Sweet!
Looks like old stock on lights that we played with 5 years ago. They even sell a 12×7135 driver with stacked chips Cool
bikenber73
Exactly but they seem to updated some “Oldies but Goodies”.
I wish people did more with the C12s adding some XHP 35/50/70 to then and see if those fins provided any better cooling.
kiriba-ru
kiriba-ru's picture
Last seen: 1 hour 59 min ago
Not necessary. They wont.
Need a vlogger for machine accessories reviews
alpg88
have to agree here, those fins are only good for cosmetic purposes
L4M4
L4M4's picture
Well, I just bought myself one…
djozz
djozz's picture
I’m not sure if the C12 finning is the best possible design, but I’m sure they do something, they are increased surface area and near the heatsource. And to me they look like they significantly add to the heat shedding to the air compared to a C8.
So why won’t they?
AgentSteel
Too bad there’s no neutral tint choice. Will be easy to swap emitter, but it does add some cost.
kiriba-ru
kiriba-ru's picture
djozz wrote:
So why won’t they?
No air flowing inside fins.
Any heatsink made to use without fan should have 5-8mm between ribs. Otherwise air flows same way as there is solid surface.
It is hard to explain. I hope somebody from forum have equipment to take thermal image – X6 is good example to show what I am saying.
kiriba-ru
kiriba-ru's picture
Also, usually people think that ribs surface is smth special and more important than solid flats and curves. This is not so, in most situations ribs surface have half less air flow. This means thay you need to take just half of ribs area to calculate heat spread increasing (i.e. 200sq.cm + 20sq.cm/2=5% increase, all numbers are random). In most situations you need hundreds % to feel difference (modern leds quad/triple light have 20-30w power with 5-10w host abilities).
alpg88
just look at any equipment that uses heatsinks with no fans, ribs are at least 3\8 apart, and up to an inch long, in some cases even longer.
Jerommel
Jerommel's picture
Last seen: 1 month 1 week ago
Why did they make that middle fin thicker than the others?? Sick
2Q19
L4M4
L4M4's picture
oooh, what a nice light!
It is very well built, I have to say.
- square threads
- anodised threads
- no sharp edges
- perfect Reflector (it’s C8 size, hence the name)
- big switch
- nice driver
- LED on copper
- flawless beam – no hole, just a tiny bit of yellow corona
- driver UI is very useable (no flash like the KD driver at low mode)
- Standard-C8 Lens, so the Convoy AR coated will fit (already ordered :P)
- Convoy C8 bezel fits – but it’s a tiny little bit too small – you feel an edge between them – but it also looks kinda silly…
oneo minor flaw:
- The LED is glued in
- as Jerommel stated, one of the fins is bigger as all the others which does look pretty weird
All in all – this light is even better than the ““KDIY K5”:https://www.aliexpress.com/store/product/KDIY-K5-Cree-XHP50-2-White-6500... – even the beam poattern is much nicer (better hotspot – but it’s also OP vs. SMO)
WhiskeyTangoFoxtrot
WhiskeyTangoFoxtrot's picture
Last seen: 1 year 1 month ago
Glad to read this as ordered one last week from a different source…cause I need yet another light! LOL
Can’t wait till I get it! (Slow boat from China.)
Jay C. - Christian, husband, dad, Marine, engineer, business owner, flashaho...er, enthusiast.
SD75, R50 Pro (XHP75), S-Mini CU, i3E CU, Mi1C, Tiny 26650 3th, TD16 - 6.4amps, AA/AAA Tool, SD20, Prince Mini, BLF A6, BLF X5, E14, C8Mini, Litker C8.2 (XHP50), SP10B...and lots more.  Triples, quads, quints etc  Yeah, I might have a couple more lights than I need...but I can quit any time I want.  Yep, any time!
wstrachan
Last seen: 15 hours 24 min ago
Kaidomain has been offering a c8.2 xhp50 for a few months now. I have several and they are quire good! Aliexpress has been pretty bad for me.
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
beam0
beam0's picture
Last seen: 6 months 3 weeks ago
To avoid anyone’s confusion with what wstrachan wrote above, I wanted to point out that, although the name is the same, the KD C8.2 has the traditional C8 body style and looks nothing like this light, the Manta Ray C8.2 is a completely different looking light, and fits 26650 cell.
Somewhat similar to KD K5S but with knurling and no stainless bezel, there’s also an SST-40 version:
XHP-50.2, 4-mode, no blinkies, 3A High mode…$33.49
SST-40 Version, 3-mode, no blinkies, 5A High…$29.50
https://www.aliexpress.com/item/High-Bright-C8-2-Luminus-SST-40-LED
For anyone else who doesn’t like Aliexpress the Manta Ray C8.2 is available on ebay (only the complete light w/XHP50.2, not the host):
https://www.ebay.com/itm/Manta-Ray-C8-2-CREE-XHP50-2-5-Mode-2600-Lumen-L...
(All links are Non-Aff, I’m not affiliated with the seller in any way)
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
beam0
beam0's picture
HOST AVAILABLE…choice of OP or SMO reflector…$21.65
https://www.aliexpress.com/item/Manta-ray-C8-2-black-flashlight-host
beam0
beam0's picture
Feedback for Manta Ray storefront on Aliexpress…
(New thread just posted): http://budgetlightforum.com/node/59007
Dioda
Last seen: 3 hours 49 min ago
Seems that getting a decent budget oriented XHP50.2 1×26650 light is not an easy task. Would like to see a comparison between the KD K5S and the Manta Ray 8.2. Both have precisely the format Im looking for (C8 size reflector and 1×26650) but both have kind of deal-breakers for me.
The K5S offers steel bezel, OP or SMO reflector and also your choice of tint. However I find it really ugly, especially when compared to such classic designs like the Convoy M2. Not to mention the cheesy looking red O rings, green tailcap and smooth body with no manufacturer engravings.
The stock Manta Ray C8.2. has only SMO reflector by default, no choice of tints, but it looks better in my opinion. For some weird reason the manufacturer had to make one of the cooling fins thicker than the rest, ruining the looks somewhat.
Does anybody know how they differ performance wise, and which one dumps heat better? Manta ray says it has integrated design, does also K5S have it that way? Which one comes with better driver?
beam0
beam0's picture
It seems you and I both have been around the forum lately looking for input on the Manta Ray C8.2 and so far we haven’t found much, probably just going to have to take a chance on it. I also like the looks of the Manta Ray better for the same reasons, but that one thicker fin doesn’t bother me, in fact I never even noticed it until I saw it pointed out in this thread.
I’m surprised you find the K5S ugly compared to the M2, to me the K5S looks like an M2 that takes a 26650 cell. Personally I don’t like either too much because of no knurling. Also the green tail switch boot is just a small cheap rubber part that can easily be swapped out with a black one, but you would have to remove the switch from the tail cap to do that.
The only things I’d like to see on the Manta Ray is a SS bezel and NW & WW tints, L4M4 pointed out in this thread (post #15) that a convoy bezel will fit, so when I get it I’ll try the convoy SS bezel, but it does look good all black too. It wouldn’t be difficult to swap the LED with a different tint if you can solder.
I’m probably going to get the host version and build it my way. L4M4 also noted it has square threads, which I’m happy about, and it I see the tail threads on the tube are anodized, so mechanical lockout will be possible. I recently ordered an F13 for a host but now I’m kind of sorry I didn’t get this host instead.
By the way the Manta Ray is available with OP reflector: (Chioce of either SMO or OP):
https://www.aliexpress.com/store/product/2017-New-LED-Flashlight-High-Qu...
(There’s another C8.2 listing that only shows a SMO)
K5S does have integrated shelf design, as shown in this overview: http://budgetlightforum.com/node/58812
One difference in drivers was pointed out in this thread by L4M4 (also post #15), that it doesn’t have a flash going into Low that caused some complaints for the KD: “Driver UI is very useable (no flash like the KD driver at low mode)”
Here’s some info on the drivers, I suspect they’re pretty close to the same, maybe someone that knows drivers better will chime in and let us know more.
__________________________________________________________________________________________________________________________________________
Drivers:
KD K5S uses the KD H1-A
I believe the Manta Ray C8.2 uses Manta Ray LC-15 because it’s the only driver they sell that matches up with that light/specs.
Here are the two drivers with links to compare:
KD H1-A 3A (20mm):
Very Lo(5%) > Lo(35%) > Med(65%) > Hi(100%) Hidden Strobe: Double Click
Memory function : ( > 3 secs)
MantaRay LC-15 3A (22mm):
Very Low(20mA) > Low (300mA) > Medium (1000mA) > High(3000mA) Hidden Strobe: Double Click
Memory function : ( > 2 secs)
curtisfong
Last seen: 1 month 3 days ago
I’m in the same boat; I am also looking for a 26650, and noticed the K5S and the C8.2. I wish the K5S had a host version available. I just impulse clicked the Acebeam EC50 gen III on Amazon as I wanted to try a XHP70.2 light. Thanks to this forum, I have purchased my first 4 LED lights in the last month!
beam0
beam0's picture
Thrunite TC20 back in stock and shipping now, smaller size/lower cost than EC50 II.
I think the discount code is still active (not sure though) http://budgetlightforum.com/node/58040
KevinZA1988
KevinZA1988's picture
Last seen: 22 hours 27 min ago
Can anyone confirm what the maximum driver size is on the C8.2 and the C12?
I have a spare XHP35 HD on a 20mm pcb that I want to pair with an OP reflector.
Thanks
Acebeam L16, Acebeam EC50 GEN III, BLF Q8 (modded), BLF A6 (modded), Convoy L2 (modded), Convoy S3 (custom), Emisar D4, Skilhunt S3 Pro, Jaxman E2L (custom), Olight S1R Baton II Etarnal - Spring - Autumn - Summer - Winter, Olight S2R Baton II, Nitecore HC65.
BlueSwordM
BlueSwordM's picture
Last seen: 7 hours 23 min ago
C8.2?
If it is the XHP35HI/XHP50.2 version, it should be 20-21mm.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
L4M4
L4M4's picture
The C8.2 linked in first post has this 22mm driver in it: https://www.aliexpress.com/store/product/22mm-3A-3000mA-1-cell-5Mode-Boo...?
1stein
1stein's picture
Last seen: 4 hours 52 min ago
I've been playing with the C8.2 host recently. Very nice host, capable of taking a lot of heat. First I used it with XHP50.2 - nice, but I didn't like the tint shift at corona edges. Then I swapped the emiter to XHP35. O yeah - this is it. Very nice throw with on OP ref, led driven at 1,5A/12V makes the host barely warm after 10 minutes.
Manta Ray C8.2 OP ref XHP 35 @1,5A
The picture shows Manta Ray C8.2 with SMO ref and XHP35 driven @ 1,5A (4000K, 80CRI)
KevinZA1988
Nice! I’m interested in this host. Can you confirm what the driver bay size is? 20mm or 22mm??
1stein
1stein's picture
The driver bay is 22mm. I put there 2 various 22mm drivers and none required filing or using sandpaper.
My only concern is the front glass. To me it looks like without AR layers.
KevinZA1988
Thanks for the feedback. I will just order a proper AR coated lens elsewhere. Otherwise, I’m definitely getting this host.
