7 X xm-l T6 bike led plate replacement
Hi guys. l burnt out my bike’s led emitter panel by giving it accidentally reverse contact. l checked the driver circuit board it is not damaged working with my other flashlight’s emitter. My question is, is it possible to replace this panel in some way ? if so how can i do it. Thanks.
Those fake Emitters are so bad they even have not the ESD and reverse voltage protection
Likely one emitter blew up and the rest are fine
3.5mm size
XPG2
https://www.fasttech.com/products/1609/10001905/1682200
5mm size
get some Cree XML2 with 5000K neutral white tint
https://www.fasttech.com/products/1609/10003889/3604901
Thank you for your help. ls it possible do diagnose which led has blew up and can l in some way bypass it so that l can still use it with the remaining ones ?
