For sale two 502B lights with “budget light forum” written on the side. The bronze colored light has an SST-40 with dome on, the black light has a de-domed SST-40. Both lights have a BLF FET DD driver with four modes. Moonlight/very low, medium, high, turbo. Heavy wires and spring mods done. There is also a copper sleeve over the drop-in for better heat transfer and the Emitters are on Noctigons.
$40 for both with free shipping in the US of A
$35 and exact shipping for everyone else.
If you would like to buy one of the lights you can take your pick for $25
I don’t like to post Lumen/Lux because I really don’t trust my meter to be accurate enough. However, these emitters are capable of putting out a couple thousand lumens so long as you use good high amp batteries.
Hey mate i think you have it figured out now. When you want to post pics here from Flickr. Go to share photo on the bottom right when the image is full screen on the photo page. Share it as an (embed) embeded pic you can change your picture size there.
If you want to post on CPF you have to use BBcode and they only accept medium sized images i am not sure if you are on there any way.
Also there is a photo editor if you want to do light work on Flickr on the same page you use to share the image on the same bottom right corner there is a edit photo function you can crop images and change the brightness and contrast heaps of options like that.
Thanks for the info. I actually ended up using postimage.org it was the fastest and easiest site I have come across. I never did figure out Flickr but with this new info I’ll probably try it again.
