Test/review of Nitecore IMR18490 1100mAh (Black-Yellow)
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 23 min ago
DSC_8282
Official specifications:
  • Capacity: 1100mAh
  • Minimum capacity: 1070mAh
  • Nominal voltage: 3,6V – 3,7V
  • Charge voltage: 4,2V ± 0,05
  • Discharge cut-off: 2,75V
  • Pluspol: ButonTop
  • Max. continuous discharge current: 11A (10C)
  • Chemistry: IMR (LiMg)
  • Protection circuit: None
  • Charge algorithm: CC-CV
  • Diameter: 18,15mm ± 0,05
  • Height: 49,05mm ± 0,12
  • Weight: 32g±1
Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-info
A fairly high current 18490 (Basically same as 18500) cell from Nitecore.
DSC_8271 DSC_8273
DSC_8272
DSC_8283DSC_8284
DSC_8285
DSC_8286
DSC_8287
Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-Capacity
The two cells have different capacity and do not handle high current the same way. It looks like they can handle 10A
I got a fairly high internal resistance, because I measure it at high load.
Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-Temp-10.0
Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-Temp-15.0
Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-CapacityTimeHours
Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-Energy
Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-PowerLoadTime
Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-TripCurrent
Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-Charge
Conclusion
The performance is fairly average for 18490/18500 high current cells, but the bad matching means they cannot be used in series.
Notes and links
Compare to 18650 and other batteries
My website with reviews of many chargers and batteries (More than 1000): http://lygte-info.dk/
hIKARInoob
hIKARInoob's picture
Last seen: 5 min 20 sec ago
Two different capacities… From Nitecore… You pay premium price… Fail! Facepalm
