torch machining, new design
15 posts / 0 new
DrafterDan
DrafterDan's picture
Last seen: 1 week 5 days ago
I’m hoping this is the best sub-category for machining. I’m working on a new design, thought I’d share a bit here. Will be an XPL-hi triple, fed by an 16340 running a Mtn Elec FET driver and my fav Bistro firmware.
The drawing alone takes a few hours, and then after some time at the lathe, about an hour of revisions.
The external dimensions are not finalized, I usually sort of design on the fly as I finalize the torch body on the lathe.
Then on to making chips
It’s taken me about three weeks to get to this point. Not a lot of free time to go to the shop where the tooling is located.
I’ll update this post as it goes along.
~D
have light, will travel
MascaratumB
MascaratumB's picture
Last seen: 11 min 36 sec ago
Subscribed Wink
One question only: why the use of 16340 and not 18350 battery? Wink
Keep up the nice work!
REVIEWS : Amutorch S3 / AM S3 vs Neal 219c / Amutorch AM30 / Nitefox UT20 / Sofirn SF14 & SP10A / Sofirn SP32A / Sofirn SP10B / Odepro KL52 / Acebeam H20 / SS AAA / Wuben TO10R / BlitzWolf BW-ET1 / Odepro B018 / DQG Slim Ti / XTAR PB2 Charger / Nitefox ES10K / Nitefox K3 / Amutorch AX1 / Amutorch VG10 / Olight M2R Warrior / OTR M1 / Wuben E05
Mods and tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7   Convoy S2+ TIR Lenses: XML2 / XPL-HI   Others: Convoy S2+ Mini (Biscotti 3 & 1*7135)     Triple TIR & XP-G2
DB Custom said: "Hide your billfold, cut up your credit cards... you're a perfect candidate for full blown flashaholism and will soon need dedicated flashlight cabinets. [...] Have fun! Modding is next... :P"
MY GIVEAWAY (FW3A) = ACTIVE
DrafterDan
simply because using the 16mm cell allows for thicker walls at the battery tube, so I can do more details like knurling/ grooving whatnot. I want to keep this torch at less than 1” (25.4mm) OD
I’ve got plenty of barn-burners based on 18350
MascaratumB
Oh, nice Wink I just asked because of runtimes and eventually “power” to the light that the Aspire 1100mAh could bring, but your focus is more on the machining and size !
Good work on this and I’ll look forward to the evolution! Thumbs Up
MRsDNF
MRsDNF's picture
Last seen: 4 hours 9 min ago
Looks good DD. Looking forward to the next instalment. Beer
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 hours 41 min ago
Cool, I’ll be watching this build Cool
Just curious, how are you planning to retain the driver? No retaining ring was drawn.
Slayer1
Slayer1's picture
Last seen: 1 hour 58 min ago
Watching Thumbs Up
Henk4U2
Henk4U2's picture
Last seen: 33 sec ago
Spit-gluing.
I always think long and hard before I say something really stupid.
DrafterDan
The driver will be staked into place, and ground path ensured with some solder joints.
A bit more time at the lathe today. This is just the tester body, to make sure my dimensions work as I expect them to.
Next step is to make the pill and hold-down for the switch.
***edit*
That last image was uploaded from my phone, and way too big. This is a better shot of the final products, for the torch internals.
Plus, I remade the bezel. The internal threading did not turn out well, will try a new technique. I need to run the insert in at a 30° angle, makes for cleaner threads.
vwpieces
vwpieces's picture
Last seen: 2 days 13 hours ago
I like seeing things made. Thanks for sharing. Good work.
FPV
FPV's picture
Last seen: 1 month 1 week ago
really nice project, keep us updated. thanks for posting it.
DrafterDan
Fairly close to done. Waiting on the driver to come in from MtnElec, and still need to finalize the outside details. I feel the tail needs some refining.
Testing fit of the retaining ring
The tail view
The bezel view. Trying out a new optic.
MascaratumB
That’s a pretty light sir!!! Shocked
Waiting to see how it will perform Wink Good work!
pinkpanda3310
Cool! Looks like it’ll have an elliptical beam. Davie
DrafterDan
The beam should be pretty standard for a triple optic. Only difference is that this has a ‘louver’ design for a more even throw. If I don’t like it, would be a simple matter of swapping out to a different optic.
I’m cutting into the C954 now, the head is complete, save for whatever external design I decide to add.
