I wanted to buy a convoy S2+ or and S3 and couple it with a diffuser and use it as a lantern to use during power outages.
I wanted models with lanyard holes on the Tail part to be facing each other directly opposite so that I can tie the lanyard through them and hang them down exactly perpendicular to the ceiling.
The problem I face now is that Convoy has updated these models and now they sell with either a single lanyard hole or with two of then next to each other.
This creates a center of gravity problem which makes the flashlight hang down at an unwanted angle.
So is there any workaround to get the new models to hand down perpendicularly? lanyard tricks maybe? or is it possible to buy the old Tail separately?
Just checked, all my newer Convoys only have the holes on one side, so 2 and 4 (o’clock). the picture above is slightly misleading because it assumes 4 holes and not 2.
With only 2 holes on one side you can’t hang them as intended by OP
edit: the only solution might be using a longer string and somehow construct a solution around the entire tailcap, maybe?
Take some small diameter flexible PVC . Cut a piece 4 or 5 inches long . Dremel a hook into one end and split the other end in order to slide it onto the tailcap . With heat , bend the hook enough to make the flashlight hang perpendicularly .
Use a heat source to heat up the hook part of the contraption and let it cool in a position that will allow it to hang straight .
Heat it , bend it , let it cool , try it , adjust it as needed .
If you have a deep carry clip, you may be able to position the clip opposite the lanyard holes and thread a string through the holes and through the clip. Might not be perfect, but could be “good enough”.
edit: Or take one loop of string and put it around the clip, and then run another string through this loop and the lanyard holes.
Wouldn’t matter. Put the clip on the light so that it’s exactly in-line with where the string bends off the hole in the tailcap. Bend the clip outwards at a right-angle. Any weight on the end of the clip will pull that side downward, so that the lens-part of the light, instead of angling towards that string, will now tend to bend away from it.
Balance the weight so the light’s going to be aiming straight down. Then, it can spin ’round and ’round and it won’t make any difference; the light will be shining straight down.
