[MOD] Armytek Prime C2 magnet USB
18 posts / 0 new
clemence
clemence's picture
Last seen: 5 days 14 hours ago
This is how I modified the Prime. Member The Driver asked me about how I do it, but I didn't take pictures of my earlier processes so I explained to him the steps via PM. You can see his modification in TLF (or in BLF if he already posted here).
Yesterday I modified three more Primes for another interior colour testing lights (these are the 9th Prime modifications so far). This time the newer regular version without stainless steel bezel.
 Perfect looks and form factor for any interior designer presentation tool
Heat evenly up 120C. More than this and the TIR will melt. I have no use for the original optics anyway, It casts one of the ugliest beam I've ever seen.
Thanks to DBCustom for the info about this baby Boa
Messy over applied thermal paste detected
Factory's best friend, BLF worst enemy - Red loctite
Critical tool! Invest your skill and time to forge a good quality puller like this. Start with a good base material such as true "hardened" screw driver or high quality tool steel. No water/oil quenching, only flame hardening at slow cooling rate followed by good tempering. File all the sharp edges to minimize damage to the bezel
Lightly punch the rivets down using straight 2,5mm steel rod with 30º tip to ease rivet removal. DON'T use drill, it will spin and destroy the MCPCB
Punched rivet (left) with raised edge, making removal so much easier without damaging the MCPCB
After prying all the lock edges, push the remaining down using blunt 2,5mm steel rod driver.
Too much thermal paste
This is a good technique from AT, unfortunately I couldn't rivet the MCPCB back unless I remove the potted driver first. After the mod, the MCPCB held down in place using common technique - pressed by the optic's base.
sm303, sm403, sm503 R9050 219Cs
These are not OEM TIR optics. I use generic faceted 15º MIC optics obtained from AE. But it looks like 20º to me. The beam produced is so much better and even than the OEM.
- Clemence
Edited by: clemence on 11/10/2017 - 07:45
MRsDNF
MRsDNF's picture
Last seen: 15 min 27 sec ago
What a nice mod that you have down pat clemence. It sounds like you have lots of happy customers. Beer
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
clemence
clemence's picture
Smile thanks MRsDNF! These are my idea so they don’t have to carry too many flashlights for their presentations. You can mix 3 (3000K, 4000K, and 5000K) colours to get 5 (extra 3500K and 4500K) colours. Very useful when working with hotel rooms.
- Clemence
The_Driver
The_Driver's picture
Last seen: 6 hours 53 min ago
Looks good!
I was able to do it with Clemence’s help.
I described my mod here German).
The optic used by Armytek does indeed produce a somewhat ugly beam inside, but outside it’s actually very good in practise! Armytek advertises it with “no tunnel vision” and I agree with this. The beam is very different from standard reflector lights. There is a very wide dim spill (so you always see the ground when walking) and then a very bright mix of corona and spill. The small hotspot in the middle is not as pronouced compared to reflector lights, but still allows for a suprising amount of throw.
zelee
zelee's picture
Last seen: 16 hours 10 min ago
well hey there clemence, never though that one of BLF came from bali.
so that makes us a neighbor then LOL
Don’t mistake my kindness for weakness.
I am kind to everyone, but when someone is unkind to me, weak is not what you are going to remember about me.
clemence
clemence's picture
zelee wrote:
well hey there clemence, never though that one of BLF came from bali. so that makes us a neighbor then LOL
Hi Jeli. The same island?
zelee
zelee's picture
if you live in bali then yes it is
clemence
clemence's picture
The_Driver wrote:
Looks good! I was able to do it with Clemence’s help. I described my mod here German). . The optic used by Armytek does indeed produce a somewhat ugly beam inside, but outside it’s actually very good in practise! Armytek advertises it with “no tunnel vision” and I agree with this. The beam is very different from standard reflector lights. There is a very wide dim spill (so you always see the ground when walking) and then a very bright mix of corona and spill. The small hotspot in the middle is not as pronouced compared to reflector lights, but still allows for a suprising amount of throw.
For outdoor uses, it’s OK. But for my client’s application, it’s totally useless. He needs to ceiling bounce in front of his clients most of the time. Those Primes are used simply to decide which CCT the final lighting will be for any rooms he designed..
- Clemence
clemence
clemence's picture
Ah….prepare a beamshot talks over coffee then. I’m in Nusa Dua, the calmer side of Bali
- Clemence
zelee
zelee's picture
- Clemence
great, when i got time i’ll visit nusa dua Big Smile
Bob_McBob
Last seen: 2 min 56 sec ago
How did you remove the bezel on the Prime Pro?
samyy
Last seen: 6 days 20 hours ago
Second that. How to remove the Prime pro bezel? Is there any tool for that?
clemence
clemence's picture
Check the OP again. There’s a clear picture about how I did it
- Clemence
samyy
clemence
clemence's picture
Ooops sorry. I sent some pictures to BobmcBob about the tool I made, via whatsapp I guess. Let me check it
- Clemence
The_Driver
Press it against the sole of a clean shoe and just turn it. This worked for me.
clemence
clemence's picture
Bob_McBob
I tried removing the bezel from my Prime with friction for several days before giving up and making the tool Clemence recommends, which worked perfectly. It’s a Prime C1 Pro magnet USB, and the bezel was cranked down very tight indeed. My bezel tool doesn’t look as pretty as Clemence’s, so go check out his photos Big Smile
