Test/review of Tronsmart C24 Dual USB compact car charger
1 post / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 12 min ago
DSC_1928
Official specifications:
  • Input: 12-24V DC
  • Output (Each port): 5V 2.4A (VoltiQ).
  • Each port functions independently
I got it from a reader
DSC_1927
DSC_1926
I got this charger in a cardboard box, it only contained the charger.
DSC_1931DSC_1932
DSC_1929
DSC_1930
Measurements
  • Power consumption when idle is 0.03 watt (2.5mA) at 12V and 0.06 watt (2.4mA) at 24V
  • Usb ports is auto coding with Apple 2.4A as max.
  • The two ports are rotated 180° to each other.
  • Weight: 13.7g
  • Length: 41.3mm
  • Front: 21.4 × 26.0mm
Load%20sweep%2011.6V%201
Load%20sweep%2014.6V%201
Output voltage will increase slightly when loaded, the overload protection kicks in at about 2.8A
Load%20sweep%2011.6V%202
Load%20sweep%2014.6V%202
The second output looks similar.
Due to small voltage differences between the two outputs, the first one handles current up to near overload and then get supplemented by the second channel. Total current is 5.5A
Load%20sweep%2024.0V
Total output current is a bit lower at 24V
No%20load%20voltage%20sweep
The charger needs a few mA for idle current.
Voltage%20sweep%204.8A%20input%20current
The normal usb output needs about 2.2A at 12V to supply 2×2.4A on usb output.
And the output will be stable down to 7 volt input.
Load%20test%204.8A
There was no problem running 1 hour with full load.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp4705
M1: 59,6°C, HS1: 69,9°C
Temp4706
M1: 52,4°C, HS1: 79,9°C
10ohm
The noise at 0.5A is 51mV rms and 179mVpp
5ohm
The noise at 1A is 57mV rms and 221mVpp
2ohm
The noise at 2.5A is 74mV rms and 247mVpp.
Tear down
DSC_2688
It was fairly easy to pop the lid on it.
DSC_2689
And then I could remove the electronic.
DSC_2690
It has a lid on some of the electronic
DSC_2698
The lid could be removed with a solder iron, it was the connection for the minus springs. There is only a inductor and a diode visible on this side.
DSC_2699
And nothing is hidden under the inductor.
DSC_2691
This side also contains an inductor, each output has its own switcher.
Notice the green fuse at the input.
DSC_2696
A look under the inductor shows two chips, one for each output. I cannot see any high power diode, this means it must be inside the chips with a synchronous rectification.
DSC_2692
DSC_2693 DSC_2695
DSC_2694
DSC_2697
DSC_2700 DSC_2701
I was missing the auto coding chip, I even checked under the usb connectors, but did not find any, this means the chips must be specially designed for this with build-in auto coding for usb.
Being a 12V device there is no need to test with high voltages.
Conclusion
This is a very compact universal usb car charger and it will charge nearly anything at maximum speed. With two separate circuits it does also have overload protection on each port. This type of short model can be a bit difficult to remove from the car socket.
Notes
The usb charger was supplied by a reader for a review.
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
