[MOD] Armytek Wizard Pro XHP50 to 4x Nichia E21A
60 posts / 0 new
clemence
clemence's picture
Last seen: 1 week 1 day ago
Agro wrote:
I’d like to understand why did you gain that 27%, but I fail so far… How did you modify the optics? Do I understand correctly that the emitting surface doesn’t fully fit in the lens opening? I guess opening is what you call aperture? Assuming yes…there are just a fairly small corners that are under the flats. Even if light from them went straight through the optics without any loss…that doesn’t seem to be 27% of LES…and the OEM TIR doesn’t black it out, it should pass most of it forward as well.
I’m also wondering how this is happening. Unless my TASI 632A light meter messed up with the reading. Member Bob_mcbob got the same improvement much earlier than me. He got whooping increase too using the same optic I used on his Tiara and Wizard. But his gain was not as dramatic as these E21A.
Measured many times and got consistent results.
Yes the LES doesn’t fit inside the lens opening (aperture). The optic sits at 0,025mm above the LEDs. The other logical answer is the narrower emission angle of E21A.
- Clemence
SKV89
Last seen: 3 sec ago
Clemence, that Armytek Wizard Pro w/ 4xE21A beam looks fantastic! Can you sell them modded?
clemence
clemence's picture
Currently (several hours ago) I only have three of them, but they’re all sold out before even hit the store. I have incoming Tiaras waiting at the custom.
- Clemence
nobeltnium
nobeltnium's picture
Last seen: 1 year 3 months ago
I wonder how the non-pro perform. I don’t know why there aren’t the normal version review and mods
Why are you looking at this? It's nothing here!
The_Driver
The_Driver's picture
Last seen: 2 hours 40 min ago
I just recently modded a non-pro Wizard because I want to use 3V LEDs. The process of modding it is the same.
The biggest difference are the missing LEDs under the button cap. This lead to them using the main LED for the low-voltage warning which I find dangerous when you are using it for running for example (it starts to blink on and off a few times).
The other difference is the U.I. It doesn’t have the two mode groups in addition to the turbo, only one.
nobeltnium
The_Driver wrote:
I just recently modded a non-pro Wizard because I want to use 3V LEDs. The process of modding it it the same.
I am too using the non-pro version so i know it characteristic, but i want to know does it have pot in the inside, the real lumen, does it stand true for what the company say it is. How is its efficiency, ….things like that. Will you share your modding work pics on the wizard noob :D?
The_Driver
The driver is potted. This is the same for all Wizards. I don’t know the efficiency, but it’s probably fine. Only the the XHP50 Wizard is inefficient when using a 12V LED.
Here are the pics of my Wizard XHP50 mod. The only difference to the non-pro Wizard is the LED (text is in German). Everythink else looks identical.
nobeltnium
I already saw this and didn’t reconise it was you :). Still a little upset for not seing the nonpro version mod making process.
Everything is identical like the driver, the thermal sensor and so on? So because the nonpro version use the 3V LED so the efficiency is ok right? God what a relief
Ich freue mich sehr dass ich nicht die pro version gekauft habe Party
clemence
clemence's picture
The older (non pro, non ribbed) version driver is the same as the newer Tiara except for the UI. It’s more efficient than the XHP50 version especially in Turbo mode but not as bright. The real output is in 700ish lumens for the older XPL.
- Clemence
nobeltnium
- Clemence
Are we looking at 700ish lumens peak or average number?
clemence
clemence's picture
nobeltnium wrote:
- Clemence
http://budgetlightforum.com/comment/1361467#comment-1361467
nobeltnium
clemence wrote:
nobeltnium wrote:
- Clemence
Thanks man. Oh one more thing, does any one notice how the nonpro version will blink everytime you bump the taipcap (e.g stick the magnet tail onto a metal object). I believe this happen because the light use only 1 spring in the battery compartment, but why don’t this happen to the pro one?
clemence
clemence's picture
Its easy to fix. Pull the spring a little to make it longer.
nobeltnium
I did, no help. I also tried protected cell wich is longer and still can’t fix it. I also tried 6 different tail cap with thesame result. And this happen to every nonpro light but not the pro version
The_Driver
See here . No reason do be upset anymore. Wink
nobeltnium
Super gei Big Smile Big Smile Big Smile Big Smile
virencelights
virencelights's picture
Last seen: 3 days 1 hour ago
so is turbo OTF 1200 Lumens?.
E21A x 4. 6500
thanks.
Virence ArmyTek Viking Pro Quadtrix 9080 E21A 5700, Virence Skilhunt H04 Quadtrix 9080 E21A 5000k, Virence Jetbeam AAA 9080 E21A 5000k,
Virence Jetbeam AAA Nichia HCRI Red Led.
clientequator
clientequator's picture
Last seen: 5 days 15 hours ago
How did you modify your optic to make such more light output? Did you drill it to make more space?
Also I notice you use different led piece for your flashlight, use 4000k and 5000k of two each; why do you do that and does it make better overall tint and CRI? but does it make light color look odd (diagonal different color) or is it not possible to see after use optic to diffuse?
Ryzbor
Ryzbor's picture
Last seen: 10 hours 2 min ago
What are the dimensions of the glass lens of the Wizard?
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K R9080 (needs more 219B), super rosy 3000K E21A mix Skilhunt H04 on it's way
clemence
clemence's picture
I did that because there wasn’t 4500K pure CCT. It works fine and many of our friends like it too. Now we know that mixing CCTs can also move the tint above/below BBL to fine tune your preferred tint (not CCT). If you want to see how a mixed CCTs looks like you can check Steel_1024, SKV89, Texas_Ace, Ryzbor, and many other’s beam shots.
19,8mm x 1mm. Get it cheap via Kaidomain
E21A x 4. 6500
thanks.
A bit more than that. Ask Bob_McBob, he just built another 6500K E21A Wizard Pro. I have none left to test
[Clemence]
virencelights
so what driver is in Clemence’s Wizard Pro’s E21A’s that were Built?.
Boost?.
thanks.
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 19 min ago
Boost.
virencelights
thank you great Sword!.
BlueSwordM wrote:
Boost.
KevinZA1988
KevinZA1988's picture
Last seen: 2 hours 19 min ago
Clemence, was the stock MCPCB easy to remove? I tried removing the MCPCB on my Prime C2 Pro. It doesn’t have retaining screws like the Wizard Pro, instead the positive and negative wires from the driver come through the screw holes. I got it tot move slightly but it just didn’t want to come out.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
clemence
clemence's picture
http://budgetlightforum.com/node/57224
[Clemence]
KevinZA1988
Thank you!
KevinZA1988
In the Wizard Pro, does the optic sit in a centering ring? Or does the lip around the top of the optic rest on the head? My Prime C2 Pro has a centering ring for the optic. A straight Yajiamei optic swap was possible and the result is a much better beam.
My Tiara C1 Pro is on the way and I will try out a VR16SP4m E17A mod. If the results are good, I will order a Wizard Pro and try a VR16SP4 v2 E21A mod. It all depends on the optic sits in the Wizard Pro.
clemence
clemence's picture
In Wizard/Tiara, the lens hanging and centered by the head, not the LED/MCPCB. Modify the optic to fit 4x E21A. Shown in the thread below:
http://budgetlightforum.com/comment/1318830#comment-1318830
You have to make at least 0,2mm clearance above quadtrix E21A because the hole/cavity in the lens (be it OEM or Yajiamei) is not large enough to encase all those E21A. The lens will also compressed a little after you put the stainless steel bezel back, risking to crush the fragile LED beneath..
[Clemence]
KevinZA1988
What about this optic?
| LED Lens CREE XML T5/T6/U2 Lenses Diameter 20mm 20,38,60 deg Bead surface 5050 lens, XLamp XM-L Lamp lens
https://a.aliexpress.com/0UxdItAG3
It is made for a 5050 LED and according to VR16SP4M v2 schematics the quad array is 4.4×4.4mm. The legs on these optics are 1mm long and can be modified slightly to sit even closer to the LED’s.
