an Idea for using DTP Boards with OSRAM LEDs
Since Osram LEDs have the anode and the center pad connected together , it is not easy to use them with DTP Boards in a flashlight
so I though of making a driver for Osram leds where the polarities are reversed , The outer ring of the driver is positive and the center of the driver is negative
(the battery needs to be inserted in the flashlight upside down)
by doing that the body of the flashlight will become postive and that will enable using Direct Thermal path with osram leds
then you can push the led harder and get MORE power while keeping the LED cool
What do you think my friends ? :smiley:
Seems like a great idea. Many handheld laser units are positive to the body. I don't know why flashlights went negative to the body. Maybe it was for safety. Cells seem to all have negative charged cases. If the body is positive and there is a short from the cell case to the flashlight body, the cell will be direct shorted when the switch is clicked on.
You would need to rewire the full driver, the AMCs dont like positive on the ground fin
But using kapton tape on the bottom of the star should be enough
Or a host with anodized shelf
In fact with protected cell the risk of a short to the battery gets lower, as the thin metal strip from the minus gets on most to the top
Unprotected cells I double or triple heat shrink so they fit better
https://oshpark.com/shared_projects/MscpbYDW
Hey, that is really nice, Lexel :sunglasses: , this type of board could make me use the Black Flat again. Is an inverted BLF-A6 driver possible as well?, and if a LFPAK56-FET does not fit, a LFPAK33-FET may? (only if you like doing it of course).
I am not sure if the 6 AMCs on back side will fit a pills retaining wing, maybe some grinding is needed or soldering the driver to it
I did it as Triple channel Bistro/Narsil
LFPAK33 driver
https://oshpark.com/shared_projects/QqGEvoTS
That is very quick Lexel, thanks! Are all 8 7135 chips in parallel or is this a triple channel driver with one 7135 with its own channel? It is relevant because I would like to simply transfer the components (except the FET) of a BLF-A6 driver to this board and make that work directly (I can not do anything related to flashing firmware myself).
I made the board for Tripledown layout
the first I posted had the pins not as the A6
Ok, then I will have to find me someone to add firmware.
Thank you Soooo much Lexel, you saved me alot of time and effort because I was learning to use Eagle in the past 2 days
so far this is my progress :person_facepalming: :cry:
I have many Nanjg 105D Drivers, like this one
Can I install their Components on your Driver ?
if not, Could you share the Needed Components for the Driver Please, or even a Nanjg 105D .sch file would be Greatly Appreciated
Thanks :slight_smile:
I’m subbin’ this one! :crown: :+1:
105D driver should work with Tripledown layout, same pin for the 7x AMCs
R5, C1 and C2 are to filter voltage spikes from the MCU, at least R5 you have to bridge or equip with 4.7Ohm resistor
I made a Fet+ n 7135 one, should be pin compatible to A6
Pin 4 FET pin 5 AMCs
https://oshpark.com/shared_projects/MSr9VRbY
That is wonderful Lexel, if built up one-sided I can even use 2 chips and have up to 700mA regulated (mode spacing with A6-firmware should not be too bad)! I ordered 3, will check them out, and report here.
I’m not sure if I’m a rare exception: can solder very well but can’t do computer stuff. For this board I can just rob all components off a common BLF-A6 board (or BLF X5/X6 board) and that is all there is to it. :slight_smile:
I just realized that the Fet +n has wrong pinout compared to A6
it happens .
we will wait your fixed Version
Thanks for the Updates Lexel
I fixed the Fet+ n 7135 one, should be pin compatible to A6 now
Pin 6 FET pin 5 AMCs
Many thanks lexel, helpful as always :+1: :slight_smile:
Good that you noticed the mistake, ordered again :slight_smile:
Luckily Oshpark is dead cheap for these little boards…
will the OSRAM 4715AS handle a reversed BLF a6 Driver (Like lexel’s) on a DTP Board ?
Not sure, I guess it is safer to go for the 8x7135 version above without FET.
