Manker E02 / E02H / E03H / U11 / MK34
163 posts / 0 new
Mankerlight
Mankerlight's picture
Last seen: 1 week 1 day ago
Please check http://www.mankerlight.com/clearance-sale/
Manker U23 2000 Lumens CREE XHP50.2 LED Flashlight With Rechargeable 26650 Battery
Specification & Features:
Emitter: CREE XHP-50.2
Maximum output:2000 lumens
Power by 1x 5000mAh 26650 battery (Batery included)
Type-C USB Charging function
Maximum beam intensity: 20000CD,
Maximum beam distance :282 meters.
Working voltage: 2.8V-4.35V (Over discharge protection)
Driver: Most efficiency constant current circuit
Material: Aircraft-grade aluminum body
Surface treatment: Premium Type III hard-anodized antiabrasive
finish
Lens: Toughened ultra-clear glass lens with anti-reflective
coating
Water proof: IPX-8 (2 meter under water)
Impact resistance: 1 meters
Tail stand
Length: 128mm
Diameter: 46mm
Weight: 189g (without battery)
Accessories: O-ring *1, Lanyard *1, Type C USB cable *1, Manker 5000mAh rechargeable 26650 battery *1
Brightness Levels & Runtime:
Moonlight: 1-5lm 1000hrs
Low: 50lm 66hrs
Medium: 400lm 8.5hrs
High: 980lm 2.8hrs
Turbo: 2000 - 980lm 3min - 2.6hrs
Strobe 2000 lm
Operation:
1.When the flashlight is off , one click ,access to moonlight mode (left part of the figure), one click to circle: moonlight-Low-Medium -High. Long press for off.
2.When the flashlight is off, long press to access to the mode your last use as in left part of the figure (Memory function), one click for circle. Long press for off.
3.When the flashlight is off, double click access to Turbo, one click for circle. Long press for off.
4.When the flashlight is on, double click to switch between the two groups(left and right part of the figure)
Side switch battery indicator:
1. Blue: More than 70%
2. Purple: 50%
3. Red: Less than 20%
Lock out:
One click-Double-Triple from any mode to lock out the flashlight.(Only the battery indicator works when lock out)
Engineering Mode(Choose output level for Moonlight mode):
Long press for off and still hold on, the side button battery indicator will turn on and then quick click for 4 times to get access to engineering mode. One click to check different level and long press to make your final choice
More info, welcome to http://www.mankerlight.com/manker-u23-2000-lumens-cree-xhp50-2-led-flashlight-with-rechargeable-26650-battery/
Manker EP02 Titanium TC4 Tactical Pen
Specification:
Material: Titanium TC4 Alloy (Pen body)
Tungsten steel (Pen Tip)
Diameter: 13mm
Length: 117mm
Package included
Tactical Pen
Schneider Gelion 39 refill
More info, welcome to http://www.mankerlight.com/manker-ep02-titanium-tc4-tactical-pen/
Manker PL11 120 Lumens CREE XPG3 / Nichia 219C LED Flashlight Pen Use 1x 10440 / 10180 Battery
Emitter: Cree XPG3 / Nichia 219C LED (CRI>90)
Maximum output: 120 lumens
Power by 1x 10440 or 10180 battery
Maximum beam intensity: 900cd,
maximum beam distance : 60 meters.
Working voltage: 2. 4 - 4. 2V
Surface treatment: Premium Type III hard-anodized anti-abrasive finish
Water proof: IPX-6
Length: 140mm
Weight: 39g (without battery)
Accessories: o-ring *1, refill *5, rechargeable 10180 battery *1
Low 10lm 6.5hrs,
High 120 lm 0.5hrs.
Operation:
ON/OFF: Easily twist the head to turn on/off the light, Tighten the head left (off-low-high), loose the head
right (high-low-off )
More info, welcome to http://www.mankerlight.com/manker-pl11-120-lumens-cree-xpg3-nichia-219c-led-flashlight-pen-use-1x-10440-10180-battery/
Manker T02 1500 lumens CREE XHP35 LED Flashlight Use 2x AA / 14500 Batteries
Emitter: CREE XHP35 HD
Maximum output:1500 lumens
Maximum beam intensity: 11200cd,
Maximum beam distance :211 meters.
Working voltage: 1. 5 - 3. 4V 5. 4 - 8.8V (over discharge protection)
Lens: Toughened ultra-clear glass lens with anti-reflective coating
Impact resistance: 2 meters
Tail stand
Length: 105mm
Weight: 107g (without battery)
Brightness levels & runtime: (Power By 2x AA batteries)
Moonlight: 2lm 76hrs,
Low: 50lm 13.5hrs,
Medium: 180lm 5hrs,
High: 325lm 3hrs,
Turbo: 800lm 2.8hrs,
Strobe: 800lm
Brightness levels & runtime: (Power By 2x IMR14500 batteries)
Moonlight: 3lm 75hrs,
Low: 153lm 5hrs,
Medium: 477lm 2hrs,
High: 850lm 1.2hrs,
Turbo: 1500lm 1hrs,
Strobe: 1500lm
Operation:
1. Blue: More than 75%
2. Purple: 50%
Lock out:
Long press for off and still hold on, the side button battery indicator will turn on and then quick click for 4 times to get access to engineering mode. One click to check different level and long press to make your final choice.
More info, welcome to http://www.mankerlight.com/manker-t02-1500-lumens-cree-xhp35-led-flashlight-use-2x-aa-14500-batteries/
Manker EP01 EDC Keychain Tactical Pen
Materials: Aluminum alloy
Size: 12mm x 81mm
Weight: 15g
Color option: Black, Red, Grey
More info, welcome to http://www.mankerlight.com/manker-edc-keychain-tactical-pen/
Manker E04 550 Lumens CREE XPL LED Flashlight With USB Rechargeable 16340 Battery
Emitter: Cree XPL HD LED
Power by 1x 16340 or 1x CR123 battery
Maximum output:550 lumens
120° uniform flooding
Maximum beam intensity: 200cd,
maximum beam distance: 30 meters
Working voltage: 2.2 - 4.4v
Waterproof: IPX-8,2M underwater
Impact resistance: 2Meters
Magenet Tailcap
Length: 55mm
Weight: 63.9g (with USB 16340 battery)
Accessories: O-ring *1, Lanyard *1, User manual *1, USB rechargeable 16340 battery *1
Moonlight: 1-30lm 7hrs,
Low 100lm 1.7hrs,
High 200lm 1.4hrs,
Turbo 550lm 1hrs,
Strobe 550lm
1.When the flashlight is off, one click, access to moonlight mode (left part of the figure), one click to circle: moonlight-Low-Medium -High. Long press
for off.
2. Purple: 50%
Lock out:
One click - Double - Triple from any mode to lock out the flashlight.(Only the battery indicator works when lock out)
More info, welcome to http://www.mankerlight.com/manker-e04-550-lumens-cree-xpl-led-flashlight-with-usb-rechargeable-16340-battery/
Manker MK39 Ranger 6000 Lumens 1100M Flood & Thrower CREE XHP35 HI + 8x CREE XHPG3 / 8x Nichia 219C LED Flashlight
Features:
Emitter:
- CW:1* Cree XHP35 HI+8* Cree XPG3
- NW:1* Cree XHP35 HI+8* Nichia 219C
Maximum output:6000 lumens
Power by 4x 18650 batteries (Battery Not Included)
Maximum beam intensity: 305000CD,
Maximum beam distance :1100 meters.
Working voltage: 11.2V-16.8V (Over discharge protection)
Tail stand
Dimensions: Length: 161mm
Weight: 720g (without battery)
Accessories: Spare O-ring, Shoulder strap
Throw Mode (Ramping Adjustment): 1-2000lm 48hrs - 3min + 2hrs
Flood Mode (Ramping Adjustment): 1 - 4000lm 48hrs - 3min +1.5hrs
Throw and Flood mode (Ramping Adjustment): 2 - 6000lm 24hrs - 3min+1hrs
Strobe Mode: 6000lm
Operation:
2. Purple: 50%
Lock out:
Quick click the switch 4 times from any mode to lock out the flashlight,you can also unlock flashlight in the same way. (Only the battery indicator works when lock out)
Note: We highly recommend you choose high drain 18650 batteries.
Beamshot:
Click image for larger version. Name:	MK39-beamshot.jpg Views:	0 Size:	78.3 KB ID:	7667
More details please visit:
http://www.mankerlight.com/manker-mk39-ranger-6000-lumens-cree-xhp35-hi-8x-cree-xhpg3-8x-nichia-219c-led-flashlight/
http://www.mankerlight.com/bundle-manker-mk39-ranger-4x-high-drain-2600mah-18650-batteries/
-----------------------------------------------------------------------------------------------------------------------------------------------------------Edit 20180528
Manker U22 1500 Lumens Pocket Thrower CREE XHP35 HI LED Flashlight
U22 was designed as a reliable utility for your daily use.
1. Smaller and lighter than U21, handy and compact, easy to carry .
2. Completely new driver design gives a full play to 21700 battery which will be the mainstream of Lithium batteries.
3. Optimized clicky side switch gives better feeling, smooth and soft.
4. 1500 lumens maximum output and 509 meters maximum beam distance with such a small body
Features
Emitter: CREE XHP35 HI LED
Maximum output: 1500 lumens
With Type-C USB Charging function
Power by 1x 21700 battery
Maximum beam intensity: 65000cd
Maximum beam distance: 509meters
Working voltage: 2.8v-4.35v (over discharge protection)
Surface treatment: Premium type III hard-anodized anti-abrasive finish
Waterproof: ipx-8 (2 meter under water)
Impact resistance: 2meters
Tail stand
Dimensions: 140mm in length x 51mm in diameter
Weight: 183g (without battery)
Accessories: o-ring *1, Lanyard *1, USB Type-C charging cable *1
Brightness levels &runtime:
- Moonlight 1-5lm 960hrs,
- Low 90lm 25hrs,
- Medium1 250lm 8.5hrs,
- High 630lm 4.2hrs,
- Turbo 1500-630lm 3min-4hrs
- Strobe 1500lm
Operation:
1. When the flashlight is off, one click, access to moonlight mode (left part of the figure), one click to circle: moonlight - low - medium 1 - medium 2 - High. Long press for off.
2. When the flashlight is off, long press to access to the mode your last use as in left part of the figure (Memory function), one click for circle. Long press for off.
3. When the flashlight is off, double click access to Turbo, one click for circle. Long press for off.
4. When the flashlight is on, double click to switch between the two groups (left and right part of the figure)
2. Purple: 50%
Lock out:
One click - double - triple from any mode to lock out the flashlight.(Only the battery indicator works when lock out)
Engineering Mode (Choose output level for Moonlight mode):
Long press for off and still hold on, the side button battery indicator will turn on and then quick click for 4 times to get access to enginering mode. One click to check diffferent level and long press to make your final choice.
More details please visit: http://www.mankerlight.com/manker-u2...ed-flashlight/
-----------------------------------------------------------------------------------------------------------------------------------------------------------Edit 20180321
Manker PL21 200 Lumens 2x AAA Penlight is releasing
Features & specifications:
Emitter: CREE XPG3 / Nichia 219C LED
Maximum 200 lumens output
Maximum beam intensity: 1000cd
Maximum beam distance:63meters
Working voltage: 1.8-3.2v
Power by 2x AAA batteries (Battery Not Included)
Aerospace grade aluminium alloy construction
Waterproof: IPX-8 (2 meter under water)
Size: 133mm length x 14mm head diameter
Weight: 29g (without battery)
Accessories: O-ring*1
Low 4lm, 47hrs
Mid 58lm 4.5hrs
High 200lm 40min
Strobe 200lm
Operation:
ON/OFF: with the light turned off, press the switch until a click is head to enter low output directly, press the switch again to turn the light off.
Brightness Adjustment: With the light turned on, turning the PL21 off and on within 0.5 seconds or simply press the switch halfway to down cycle brightness through "low-mid-high" the PL21 will turn on in "Low" by default after it is turned off for 0.5seconds.
More details please visit: http://www.mankerlight.com/manker-pl21-200-lumens-2x-aaa-penlight/
-------------------------------------------------------------------------------------------------------------------------------------------------Edit 20180226
Special Offer Mankerlight 3 Year Anniversary Edition (Manker T01s) is releasing
Features
Emitter: CREE XPL HI LED (CW and NW for your choices)
Maximum 420 lumens output, power by 1x AA battery
Maximum 800 lumens output, power by 1x 14500 battery
Driver: Most efficiency constant current circuit, maximum runtime up to 300 hours
Material: Aircraft-grad 7075 aluminum body
Clip: Titanium coated stainless steel clip
Reversible & removeable Stainless Steel Bezel
Forward Clicky Tail Switch
Dimensions: 105mm (length) x 35mm (Head diameter)
Weight: 45gram (without battery)
Accessories: o-ring *1, lanyard *1, pocket clip *1
Brightness levels & Runtime:
Powered by 1x 2500mAh AA NiMH battery
Working voltage: 0.8v-1.6v
Moonlight 0.5lm 300hrs,
Low 5lm 13hrs,
Middle 58lm 5.5hrs,
High 220lm 1.5hrs,
Turbo 420lm 1.3hrs.
Powered by 1x 3.7V 750mAh 14500 battery
Working voltage: 2.7v - 4.2v
Moonlight 7lm 90hrs,
Low 45lm 12hrs,
Middle 100lm 3.5hrs,
High 270lm 1hrs,
Turbo 800lm, 0.5hrs.
Operation:
Forward clicky tail switch,
On / Off: Click for on and off, 5 output mode in total.
Change modes: click within 0.64 second to change modes,
the light will memory your last mode if the time get over 0.64 second between two clicks.
http://www.mankerlight.com/mankerlight-3-year-anniversary-edition-manker-t01s/
Aliexpress:  https://www.aliexpress.com/store/product/Manker-T01s-800-Lumen-CREE-XP-L...
-------------------------------------------------------------------------------------------------------------------------Edit 20171213
Manker E02 Titanium Version Get Available Now.
More details please visit http://www.mankerlight.com/manker-e0...le-flashlight/
------------------------------------------------------------------------------------------------------ Edit 20171212
Manker U12 is releasing 20700 Battery XHP50.2 Type C Charge Port 2000 Lumens
Features:
Emitter: CREE XHP50 II
Maximum output: 2000 lumens
Maximum beam intensity: 6800cd
Maximum beamdistance:164meters
Working voltage: 2.8v -4.35v (overdischarge protection)
Waterproof: IPX-8 (2meter under water)
Tail stand
Dimensions: 112mm (length) x 31mm (Diameter)
Weight: 118g(without battery)
Accessories: O-ring *1, holster *1, Lanyard *1, USB Type C cable *1, pocket clip *1, 20700 rechargeable battery *1.
Specifications:
- Moonlight 1-5lm 1700hrs
- Low 130lm 16hrs
- Medium1 390lm 6.5hrs
- High 870lm 3hrs
- Turbo 2000lm-870lm 3min - 2.9hrs
- Strobe 2000lm
Max light intensity: 6800cd
Beam distance: 164M
Shockproof stand: 2M
Waterproof stand: IPX8
Operation:
More details please visit http://www.mankerlight.com/manker-u12-2000-lumen-cree-xph50-ii-led-flashlight-with-20700-battery/
Mail:sales@mankerlight.com
Web: www.mankerlight.com
Welcome to join Mankerlight Group in Facebook.
Edited by: Mankerlight on 12/19/2019 - 00:53
X0R
X0R's picture
Last seen: 3 months 3 days ago
20700, typeC, Wow!
Agro
Agro's picture
Last seen: 6 min 17 sec ago
Great move with USB type C. But have you thought about doing a 21700 variant?
I don’t see myself investing in 20700 batteries…
Anthon
Last seen: 5 hours 59 min ago
That long press for off is a deal breaker to me
Single click should be able to turn on and off the flashlight
agent80
Last seen: 7 hours 8 min ago
Hard to get battery. I vote for a NiMH / 14500 type battery.
djozz
djozz's picture
Last seen: 5 min 47 sec ago
I very much like the Manker UI, including the long-press for off, mind that Manker does their timings right: the long-press for off is still pretty fast, works very smooth.
Great flashlight, typeC charging is great, I hope it does make use of the higher power by charging at 2 amps. I do not like Manker’s exterior designs much though…
Mankerlight
U12 comes with a 4250 mah 20700 battery.
djozz
djozz's picture
Manker, what is the charging current of the U12 ?
Mankerlight
2A
djozz
djozz's picture
Mankerlight wrote:
2A
Thumbs Up
westcoast
Last seen: 8 months 1 week ago
Love battery life indicator with LED integrated into the switch. Kinda unsure about 20700 battery format so glad one will be included.
If I understand correctly and the charger is USB Type C in built where is the port located?
texas shooter
Last seen: 9 hours 26 min ago
I like the idea of more 20700 lights. No ****fires in that size, all quality Sanyo/Panasonics.
hIKARInoob
hIKARInoob's picture
Last seen: 5 min 35 sec ago
One click – double click – triple click for lockout is the same as previous Manker lights. However, is the firmware for this the same as well? I’ve got great trouble realising this sequence on my MK34, and other people have trouble with their lights as well. It feels like if I’m just 0.01 second off, then it does not work. It should be more forgiving.
Other than that, this new light seems like a champion! Cool
MascaratumB
MascaratumB's picture
Last seen: 57 min 38 sec ago
LOVE IT Love I want one of these!
Love the UI as well! Having that Double Click for turbo is top for me Cool
Knowing Manker quality (from my E11) this will be a great light! Is it available yet?
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
DoubleA
DoubleA's picture
Just wait till 20700 becomes mainstream and you’ll start seeing 12000mAh ****fires in that size. Crazy
and on the first day he said "Let there be light"...
Pete7874
Pete7874's picture
Last seen: 1 hour 10 min ago
They are already using single click to switch between output modes, so how can they also use it to switch the light off?
Pete7874
Pete7874's picture
Hello Manker,
Will a 21700 cell fit in this light?
Anthon
I don’t like the UI at all, I had one manker before and every time I wanted to quickly change between modes entered in strobe mode by accident.
MascaratumB
Well, on this U12, if I understood correctly the diagram, with a double click the least you can do is enter the second group, that starts on Turbo. So, double click from ON or OFF goes to turbo!
I have Manker E11 and rarely entered Strobe by clicking 2 times, unless I really wanted to get strobe. Their timing is really nice on that, I admit!!
OL Contest 2019
GIVEAWAY: 1 / 2
JamesB
Last seen: 2 hours 55 min ago
I find it much too easy to accidentally fall into the 2nd group while cycling through the 1st group, this double clic to change groups is very irritating in practice, i don’t use my Manker U11 and won’t buy another flashlight with the Maker UI because of that.
Clic and hold for 2 seconds would solve the problem.
eas
eas's picture
Last seen: 1 month 1 day ago
That would be a completely different light! Like an Manker E11, with the addition of USB-C charging.
Mankerlight
MascaratumB wrote:
LOVE IT Love I want one of these! Love the UI as well! Having that Double Click for turbo is top for me Cool Knowing Manker quality (from my  E11) this will be a great light! Is it available yet?
 Thanks! U12 is available now, you can check on www.mankerlight.com
MascaratumB
Thanks Manker.
Will there be any discount for BLF? Or any group buy?
OL Contest 2019
GIVEAWAY: 1 / 2
LumacSledding
I like the simple design. I like the battery indicator also. Should be a standard..then you dont need bat check in UI. What i dont like or understand is why programmung is taken away on the never models. And this time regulated step down..bummer. should be temp regulated.if you have the bat check in button you can estimate your usage time and run the lamp hard in cooler weather or something..
Lumac Sledding Equipment
Mankerlight
That should be the Dragon Breath mode.
mrheosuper
MascaratumB wrote:
Thanks Manker.
Last time i checked there is none group buy/coupon from manker
Forgot my pen
MascaratumB
mrheosuper wrote:
MascaratumB wrote:
Thanks Manker. Will there be any discount for BLF? Or any group buy?
Facepalm Wish there was one… with a nice price… Tired
OL Contest 2019
GIVEAWAY: 1 / 2
realista
realista's picture
Last seen: 1 month 1 week ago
still prefer 18650s……
vwpieces
vwpieces's picture
Last seen: 2 weeks 5 days ago
I think the discount code for the Manker E11 is UT01
any others?
mortuus
mortuus's picture
Last seen: 3 hours 5 min ago
will there be a brigther flooder then e14 2 that will run on 1 × 26650 maybe ?
...where Frugal meets with Flashlight!
Jerommel
Jerommel's picture
Pete7874 wrote:
Hello Manker,
Apparently not, since they avoided this question twice..
