Convoy L2 XHP50 Mod
35 posts / 0 new
Pentaprisma
Convoy L2 XHP50 Mod
Hi guys, I’m new in this flashlight modding world and eager to learn and enjoy. I have a Convoy L2 with an XPL HI NW emitter. I like the 1 cell form factor of the L2 but I’d like more output, so I would like to mod it to an XHP50 or XHP70 NW
Mi questions are: What emitter should I get so I can get 2500+lm? Will it work with L2 original driver? Will it work and give typical XHP50/70 output out of one Keeppower 5200mah?
I know that this questions might sound silly but I’m trying to learn. Any explanation on how to do this and suggested components would be much appreciated.
Thanks
agnelucio
agnelucio's picture
There are no single-cell emitters which will do 2500+lm in an L2.
To get output that high, you would need to use either an XHP70 or XHP50 and a 6V boost driver, or an XHP35 and a 12V boost driver.
In an L2, the XHP70 will not throw well, the 50 will sort of throw alright, and the 35 will start to throw well.
If you really want 2500lm+, and you still want it to throw well, I’d recommend getting an XHP50, dedoming it, and using a boost driver.
Pentaprisma
Thanks for your response. But getting a little confused here. Ive seen a few lights with a single 26650 battery running an XHP70 like the Klarus G20L for example that can put out 3000lm. Will this not be possible on an L2?
I know that the bigger the emitter more output but less throw. So that’s why I thought the XHP50 would be right in the middle.
Any suggestions on how to get more than 1000lm with a single 26650 on the L2? possibly the XHP35?
Thanks again Smile
the4ds9
Last seen: 13 hours 58 min ago
SkyLumen has a mod of the Convoy L2 with a Luminus SST40 emitter:
KawiBoy1428
KawiBoy1428's picture
Last seen: 5 hours 39 min ago
XHP70-50 is a 6v emitter, you would need a really good boost driver to run off 1 cell!
You could run a SST-40 at 8-9 amps with a FETDD driver and a High current 26650 and get 2500lumens and decent throw!
Dale (DB Customs) has a Q8 doing over 11,000 lumens with 4 SST-40s in his Q8!
http://budgetlightforum.com/node/55026?page=42 See Post 1288-1289
KB1428 “Live Life WOT”
the4ds9
Please see my post above regarding Sky Lumen. Thank you.
KawiBoy1428
Please see my bead blasted and polished L2 SST-40 at 8.8amps and it didn’t cost $100.00 bucks to do!
the4ds9
Thank you so much. Amazing.
KawiBoy1428
It’s running TK’s Cresendo push button ramping, I like it better, it’s pretty cool! Thumbs Up
Pentaprisma
So if I could run a 6V emitter out of a single cell, what would be that driver, could you name or link such driver..?
In the other hand, is XHP35 a 3V emitter? in that case, could it work for the L2 single cell config..!?
By the way, those two L6 and L2 look amazing..!
KawiBoy1428
XHP35 is a 12v emitter. Your best bet is to run the SST-40 FETDD driver for the out put you seek, 2500lms. I have another L2 running 2S 26650 and a XHP50 @ 9amps, that is really sweet! Nice blend of throw and flood and nice tint a XHP50 J4-1D.
Have you checked out the L2/L6 modding thread.might get some info that will help….http://budgetlightforum.com/node/50372
EagleShield
Kaidomain H2-C 22mm “12V” Boost driver if that fits.
For modding it, check This thread.
Pentaprisma
Thanks for your feedback, really appreciate it.
Dont quite know what a FETDD driver is or where to find it, could you please explain or link me one. Also, if you know a good place to buy leds on their PCBs or the SST-40 in Neutral white 4000-4500k would be amazing.
Thanks again for the info..! Smile
KawiBoy1428
Yep, one stop shopping here..http://www.mtnelectronics.com/
Also these very really smart members are working on something you might be interested in http://budgetlightforum.com/node/56016 might want to inquire there about a 20mm 6v single cell boost driver! Your L2 is the newer model with the 20mm driver correct?
KawiBoy1428
Oh nice, I was looking for that thread too, thanks!
Pentaprisma
Cool Thanks, Ill check the site..!!
Ok, so if XHP50 6V emitter cant run out of a single 26650, could you guys explain how Klarus G20L runs a XHP70 out of a single cell..? I don’t understand.
That was the example I took for my process of thought to convert the L2 at a higher output.
KawiBoy1428
Here ya go, check this out, it will explain a lot of things for you….
http://budgetlightforum.com/node/33820
http://budgetlightforum.com/node/42745
EagleShield
XHP70 have a 6V option too as the XHP50 depending on the Mcpcb (both have 12V option too).
But XHP35 and XHP35 Hi only comes in 12V option.
The xm-l, xm-l2, XP-l, XP-l hi, xp-l2, Sst-40 is a 3v emitter.
And whatever you choose you need the right driver to power them.
Not many drivers for 1 cell powered xhp35 and XHP35 hi tho.
One single cell driver is Kaidomain H2-C 22mm “12V” Boost driver.
It can power the xhp35 Hi, xhp50 (12V version), XHP70 (12V version) with a single battery. (If the driver fits the L2)
Link http://www.kaidomain.com/p/S026504.H2-C-22mm-1_5A-1-or-2-cell-5-Mode-Boost-Driver-Circuit-Board-for-Cree-XHP35-XHP50-12V
If you want a FET direct drive driver and add a de-domed/shawed Sst-40 or an XP-l Hi (I guess you want throw (long range)) you could use a 17mm BLF A6 A17DD-L FET+1 driver but I’m guessing you need a 17mm to 20mm driver adaptor.
Link https://m.banggood.com/Astrolux-S1-BLF-A6-A17DD-L-FET-1-2_8-4_35v-7-4-Modes-Flashlight-Driver-p-1009980.html
Link http://www.kaidomain.com/p/S023828.KD-17mm-Inner-to-20mm-External-Brass-Ring-Driver-Adapter-for-17mm-Circuit-Board-5-pcs
I don’t know where you live but mtnelectronics have a nice selection of drivers.
Link http://www.mtnelectronics.com/index.php?route=product/category&path=67
I’m guessing you want a long range flashlight. I think you should go for a Direct Drive FET driver with de-domed/shawed Sst-40 or a XP-L Hi or if you can find a good 12V driver that’s fits then go for a XHP35 Hi.
I don’t know what size of the driver the L2 have so just guessing here.
Pentaprisma
Hey Thanks, that was really explanatory…!!!
I live in the UK, and yeah, I’m looking for a thrower but I thought I could give it more output. The XPL HI works fine but could always do with more light isn’t it..?
Of course I could use the second battery on the L2 but for that matter I would have gotten the L6.. I like the small profile thrower..!!
Cool guys thanks for the output..!!
Thumbs Up
JIGHEADWORM
I have an L2 running a xhp35 hi with a mtn buck driver that gets 2480 lumens and 280 kcd with 4 26350 in it. I’ve been thinking about getting one of those kaidomain boost drivers in it and see how it does with 2 26350’s
EagleShield
Btw. If you are going for a DD FET driver make sure your emitter sits on a DTP (direct thermal path) Mcpcb and put on some good thermal paste under it like the Arctic Cooling MX-4 Thermal Compound so it can transfer the heat properly to the flashlight host.
Same if you use the xhp35 Hi.
johnkey68
Last seen: 2 hours 3 min ago
Convoy L2 + FX-6 + XHP50.2 J4-3A + tailcap reverse click switch
Pentaprisma
Hey johnkey68 nice set up…!!
Yeah, something like that is what Im after. Is that single cell light?
Do you know estimate output.. does it throw reasonably well..?
Thanks for sharing..!!
Pentaprisma
Hey interesting approach..!! would like to know how that turns out..!
johnkey68
2 × 26350 = O.K. !!!!
DSC_0417.jpg!
jetro
Last seen: 8 months 1 week ago
I’m thinking of the same setup.
Did the driver fit well? I found it in 22mm version
Wich spring did you use?
How do you experience the light/ trow/ flood? Do you have some beamshots?
finges
Last seen: 1 hour 35 min ago
I have my L2 running with one cell and a XHP50.2
I use this driver http://www.kaidomain.com/p/S026606.H1-A-20mm-3A-1-cell-5-Mode-Boost-Driv...
It is nice!
mountainair26
mountainair26's picture
Any beamshots of the 50.2 in your L2, johnkey68?
johnkey68
Convoy L2 + Cree XHP50.2 6500K
And for comparison : UltrraFire F13 + OP reflector + XHP50.2 6500K VS KDL C8.2 XHP50.2 5000K
mountainair26
Very nice, thanks for the beamshots and comparison. How do the tints of the new 50.2 compare to other leds Johnkey68? The photos make it seem like the 6500k is pretty warm and the 5000k looks really warm, but I know it’s pretty difficult to get accurate color temperature in most photos. Are they as warm as they look, or different in person? Thanks again, nice mod
Pentaprisma
Hey guys back to the thread.
I have looked at the options, and Kaidomain H1-A boost driver + XHP50.2 de-domed on the Convoy L2 seems like the most plausible option for what I'm looking for (higher output yet maintaining a decent throw in one cell config.)
Do any of you guys have this particular setup? could you share some more opinions, max lumen output and throw and some beamshots (thanks Johnkey68 for yous), please..?
I also noticed that KDLITKER C8.2 uses an XHP35 HI claiming 2000 lumens (dunno about that) using a 20mm own KD driver (I suspect)
http://www.kaidomain.com/p/S027411.KDLITKER-C8_2-Cree-XHP35-HI-Neutral-White-5000K-2000-Lumens-5-Mode-LED-Flashlight-Black
Do you guys know what driver that one is, and where to find it..? links, please Smile Thanks for your support..!
