I decided to try out a mod that I was going to do for my up and coming build. Replacing the stock spring on a tailcap clicky with a copper one. Here's some photos of the attempt and a little info with it.
First I needed to remove the switch from the cap. I did that with a handy Snap Ring tool. A needle nose pliers will work if it's jaws are fine like a jewler uses.
That was easy and here it is apart.The threaded ring that I took off holds the switch in place and it also grounds it to the tailcap.
Now I need to remove the spring from the board. I have another little tool that I just love to use. It's a butane torch that has a soldering tip adapter with it. It's great for larger pieces and it gets hot enough to work with silver solder if needed. (Came from Lowes).
So the spring is off and now I can work on making a copper one.
I have some solid copper wire that is bell wire and some copper wire from some Romex. The bell wire is about 16GA and the Romex wire is about 12GA.
I want to explain something about copper. It's very soft to work with, but if copper is "worked" it turns hard. The process of hammering, crunching, twisting or winding copper makes it harden. The more it is worked, the more it hardens.
I want this wire to be fairly stiff, so I just wind it around a socket.
So, to make the wire stiffer I wind it up, then I pull it off, then I wind it up and pull it off. I repeat this till I like how stiff the wire is. I only had to do this twice with the 12GA wire before it got stiff enough. Then I took a round punch and wound the wire around the tapered end of the punch. The diameter came out just about right.
I trimmed it off and then I flatened the ends by rubbing it across some snadpaper.
Now it's ready to tin
and solder onto the board where the other spring was.
Here is the finished product ready to go back on the light.
And it even worked!
Now, I am Not saying that anyone else should or needs to do this.
I just like doing stuff like this to pass the hours and to see if I can. I really think it is not necessary, but it is an alternative to the standard mod for a tailcap spring.
