MecArmy new release: Multifunctional Capsule Flashlight and Lighter Kit
8 posts / 0 new
mecarmyflashlight
mecarmyflashlight's picture
Hello buddies, new releasing again, let’s go
X7S: Multifunctional Capsule Flashlight and Lighter Kit
· Material: Stainless steel
· Patented EDC Capsule Flashlight and Lighter kit
· Mini and match flexibility allows you to create a keyring or penlight sized
flashlight; a mini or pocket sized lighter,and a single or double pill box/
battery capsule
· Flashlight utilizes CREE XP-G2 LED, max output up to 130 lumens
· Powered by 10180 Li-ion rechargeable battery
· Max runtime up to 6 hours
· High & Low lighting modes
· Head twist switch
· Micro USB recharging with indicator
· Tail stand capability with keyring attachment point
· Micro liquid fuel (gasoline/ petrol) lighter, with pocket clip
· Capsule can be used in one or two sized storage spaces
· Capsule for storage pills or 10180 battery
· CNC precision machining
· Anti-corrosion and high hardness
· IPX8 water resistant
NOTICE:
a: The Lighter excluding gasoline
b: To refill gasoline/ petrol (unscrew the lighter’s cap, pull up lighter’s
reservoir insert for refill)
c: Use only good quality lighter fuel and flints
Flashlight Specifications
· LED: CREE XP-G2 LED
· Output: max 130lm
· Battery: 10180 li-ion battery
· Charging way: flashlight with build-in micro USB port, can be recharged by micro USB cable
· Charging time: full charged in 1 hour
http://mecarmy.com/product/details/237/291
Go buy from our dealers if you like it Smile
www.mecarmy.com
Main products are Mini USB rechargeable flashlights,Tactical light, EDC knives, Tactical gear
Edited by: mecarmyflashlight on 12/05/2017 - 20:51
FPV
FPV's picture
Last seen: 2 days 10 hours ago
Interesting product!
Zulumoose
Zulumoose's picture
Last seen: 1 hour 27 min ago
Man that is one classy gift idea.
I wants it!
But…but….$99 ??????? !!!!!!!!!!!!
Beam me up!
CRX
CRX's picture
Last seen: 2 hours 16 min ago
Quite nice.
DavidEF
DavidEF's picture
Last seen: 15 hours 8 min ago
I wants it!
DQG has tiny flashlights that use 10180 cells, and matching extension tubes, capsules, and a kerosene lighter. All the parts are threaded the same, so there is a huge amount of extension and modification possible. To put a kit together like this (or even better) would be less than $99 as well.
EDIT: Oh, I just realized that this has all three ‘components’ and a box. I’m not sure you could get all this for $99 from DQG components without a special discount.
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
Zulumoose
Zulumoose's picture
I know about the DQG but not only are they expensive but I think some of the parts are discontinued
Beam me up!
mecarmyflashlight
International dealers will receive all new items around 15 December Smile
www.mecarmy.com
Woody
Woody's picture
Last seen: 5 hours 49 min ago
Nice video – great idea to be able to make up a penlight with a cigarette lighter at the other end.
