Brass replacement screws for the blf q8
Hi was reading that folks were replacing the standard screws out for brass screws and in doing so getting a increase in lumes. Does any one know wee I might get the screws or what size they are .mine is in the post so I can’t check. Oh and also can a little bit of normal multi purpose oil be used on the tread of the torch head or does it have to be speachiel grease? Thanks
Anybody know? Or is this a silly typical newb question…i think I’ve placed it in the correct section
all the info about screws is in the Q8 modding thread
Its now a 45 page thread so use the search for Brass.
Thanks
So I’ve spent some time searching and I’m still unclear the exact screws that u replace with brass ones and the size. If anyone knows please let me know so I can get them orders. Thanks
M2 M2.5 M3 Brass Phillips Pan Round Head Cap Bolts Screws
tail board screws are what make biggest difference
M2.5X5mm
THREAD DISCUSSION:
EBAY VENDOR:
https://www.ebay.com/itm/M2-M2-5-M3-Brass-Phillips-Pan-Round-Head-Cap-Bolts-Screws/232018831618?ssPageName=STRK%3AMEBIDX%3AIT&var=531211953181&\_trksid=p2057872.m2749.l2648
I may have read you only need to replace the tail board screws for a benefit…(four M2.5 x 5 mm)
info for 2nd batch lights:
Ok, so second batch is:
driver: M2.5×4mm *2
tail pcb: M2.5×5mm *4
reflector: M4×10mm *1
mcpcb: M2.5×10mm *2
Thanks a lot pal much appreciated
Not sure where your located, but any good hardware store should have them. Possibly Home Depot also…
