Mecarmy new Dual (Teeterboard) Switch, USB Rechargeable Compact Angle lights.
11 posts / 0 new
mecarmyflashlight
mecarmyflashlight's picture
Last seen: 10 months 5 days ago
Dual Switch (Teeterboard switch) USB Rechargeable Compact Flashlight
· Dual switch Compact flashlight with USB rechargeable function
· Uses CREE XPL-Hi V3 LED, lifespan up to 50,000 hours
· Momentary ON function
· Instant access to Turbo/ Strobe
· Quick charge in just 90 minutes
· Standard Micro USB Charging port, charges on any USB port
· Charging and fully charged indicators
· Magnetic tailcap provides versatile hands free operation
· Detachable clip
· Over-heat protection to avoid high-temperature of the surface
· Rugged pineapple texture for grip and anti-roll
· Constructed from aero grade HAIII hard-anodized aluminum alloy
· IPX-8 water resistance
LED: CREE XPL-Hi V3 LED
Dimensions:
FM16: Length 99.2mm x Head 29.2mmx Body 23.3mm
Length 3.905” x Head 1.149“x Body 0.917”
FM18: Length 133.2mm x Head 29.2mm x Body 23.3mm
Length 5.244” x Head 1.149“x Body 0.917”
Charging: Micro USB rechargeable, with red/green charging indicators
Accessories:
FM16: User manual, 1*16340 Battery, O-ring, lanyard, USB cable
FM18: User manual, 1*18650 Battery, O-ring, lanyard, USB cable
Notes: The 18350 battery here we mean traction battary like IMR, INR. Which will have higher output than normal 18650
Our international dealers will receive all new items around 15th-20th December.
www.mecarmy.com
Main products are Mini USB rechargeable flashlights,Tactical light, EDC knives, Tactical gear
Edited by: mecarmyflashlight on 12/04/2017 - 22:14
skinny_tie
skinny_tie's picture
Last seen: 11 hours 22 min ago
I’d really like to see a video showing how that switch works.
Paul321
Paul321's picture
Last seen: 8 hours 4 min ago
Will the cells be included?
Paul-
saypat
saypat's picture
Last seen: 29 min 48 sec ago
amazing ingenuity!
Lexel
Lexel's picture
Last seen: 6 min 12 sec ago
Lumens numbers seems not correct why less brightness with one 18650 than one 18350?
vwpieces
vwpieces's picture
Last seen: 15 hours 16 min ago
How bout offering the FM186 version with both tubes included in one light package?
At least offer the 18350 tube separately.
joechina
Last seen: 9 hours 46 min ago
Can I position the clip free around the tube or is it in a fixed position?
mecarmyflashlight
Yes you can
www.mecarmy.com
mecarmyflashlight
Hi Paul,
Accessories:
www.mecarmy.com
mecarmyflashlight
Sure
www.mecarmy.com
Searchdog23
Searchdog23's picture
Last seen: 8 months 3 weeks ago
I’ve had good experiences with the FM16 so far. I like the quick access to Turbo. I can carry the lamp in the insert jacket without taking away a lot of space. I have tried the operation with Thl-gloves, works in any case. The FM16 has a lot of power for her size. I could not say anything negative now.
There is even a magnet on the tailcap, but in my opinion it should be a little bit stronger. The rocker switch is easy to operate. I like the little part very well.
Christian
