The switch control code is already written. I mostly just need to adjust the ramp values to work on the GT’s driver, and check the calibration in general. I doubt it’ll take long. I could probably even do it without hardware, but I make no guarantees that it’ll actually work.
The method I’ve been using to control the switch light is:
When the light is in any operating mode, the switch light copies the main emitter. The button light stays on steady in regular modes, blinks in blinky modes, etc. Button brightness also imitates the main emitter, though it only has three states — off, low, high.
While in the “off” state, the button goes to the user’s configured brightness — off, low, or high.
While in the “lockout” state, the button goes to the user’s configured lockout brightness — off, low, or high.
It seems to work well on the Q8, but I hear the GT’s boot is a lot darker so I’m not sure the “low” brightness will be of any use.
I think that I would really like this on the Q8. The switch light is too bright at night when they are sitting on my bookshelf at night. I wake up at night and see these glowing eyes looking at me. I would love mine to be dim when turned off and when in use on low level and high when in use at >20%.
You will have to let me (all of us) know how to make this happen. An instructional video would work great for me.
An easy way to dim the Q8 light is to remove the switch cover and put a dot from a black marker on the leds. Or swap to a different switch cover.
Reflashing the GT driver requires pulling out the driver far enough to get a clip on its mcu. I don’t know if the led wires are long enough to do that. If not, then you might have to unsolder the leds wires from the mcpcb, reflash the driver, then reattach them. I’m sure someone here can tell us if the stock GT led wires are long enough or not.
Edit: the wires are long enough. No soldering needed.
Moon light is always an extra add on. If you choose mode 4, you actually get 5 levels due to moon light being turned on. Mode sets in general are not that fleshed out. It’s mainly meant to be used in ramping mode.
Another user, WaylonJennings, has mentioned that when set to mode set 7, if he removes battery power then reconnects, the light jumps back to the default ramping mode.
I don’t have my light with me to check, but can someone see if this is a bug in v1.2 or just a one off fluke?
Definitely not a 1.2 bug. Just tried it again now to be sure (several iterations, each with different timing).
There is a (very) small chance that the MCU browns out during power-up or power-down, messing up the settings memory in the process. But that should be a once-shot deal and the light is more likely to temporarily lock up than change settings.
Yes, MOON doesn’t count to the numbers of modes. Nice, that you found it out by yourself.
(The same user questions like with the Q8. )
The Notes section on the cheat sheet is derived from user feedback with the Q8.
If you have a problem with the UI of NarsilM, there is a good chance that it’s mentioned there.
LOVE this thread! Very very well laid out. Thank you guys so much for all your work on this!
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not. http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
Is anyone able to tell a difference in light output between normal high and turbo? I can’t but I figure it would be more apparent at long distance vs the small room I am checking in.
The output difference is very minor and hard to notice unless you go directly from the top of the ramp to turbo.
If your batteries are low, then the driver will have dropped out of regulation and there will in fact be no difference in output.
Gun control is not about guns; it's about control.
I can tell a difference when it’s sitting on the end of my lumen tube
I just noticed something. In the modes group if I set moon mode to the lowest setting it doesn’t work. It basically makes the light be a double click to turn on. Was this on purpose?
I believe your talking about the moon level 1 to 7?
Level 1 is not guaranteed to work. It depends on the particular emitter whether it will light up or not. This was also true of the Q8. It’s also why level 3 was set as default as it should be more likely to light up, yet still be fairly dim.
I think you will find that your light will also not light up in moon mode in the ramping setting.
The only way to access moon mode in ramping is to turn the light on by a press and hold and then quickly release the button before it starts to ramp up.
BTW, ramping only goes down to the equivalent of level 3 moon mode.
Cool, that actually makes sense. I will mention that in my vid. Thanks again!
Your vids are hilarious, especially that opening scene in the vid in the OP (some acting skillz!). Always appreciated. Am looking forward to your XHP70.2 mod vid. May want to get a second one for that purpose
Thanks Team btw. What an amazing effort, from inception to development, and now support. I’m honored to be part of this great community. (I signed up on BLF, after lurking for a while, just to get on the GT groupbuy [and many groupbuys later…ouch]).
GT-specific: BLF GT with NarsilM v1.2 – new strobe modes
Jason, I noticed @ 1:50 in your light make the same glass popping noise mine does.. About every ten minutes mine will do that LOL!
Hopefully Tom or TK can chime in.
I’m not sure if it affects NarsilM, but in RampingIOS one of the things I fixed was a race condition of some sort which could occasionally corrupt the eeprom. I don’t recall the details exactly, but the patch is in the repository. I think I changed it to A) use library functions instead of direct register access, B) disable interrupts while saving, and C) erase before writing instead of vice-versa. I haven’t heard any prior reports of anything like this for NarsilM though, so perhaps the issue was only in RampingIOS v1.
I would like to purchase the BLF GT Giggles as well as the Samsung batteries mentioned. Is there another waiting list available to be put on or is it available to purchase right away?
Hi and welcome joann. The group buy on this light has expired. Undoubtedly when the orders for the group buy are fulfilled the light will be available to purchase from re sellers.
djozz quotes, "it came with chinese lettering that is chinese to me".
Thank you in advance,
Joann
I’m sorry, but it is not available for sale right now. Existing orders are still being fulfilled. Once the light goes for sale to the public, Madmax might have a sale on them.
Joann
I’m in Plaistow nh if youd like to come check out my BLF GT.
Joann
Thank you that’s good to know, I will be looking forward to it!
Joann
Thanks for the offer, but I’m pretty much already sold on it.
Joann
gigbyt wrote:
joann wrote:
Hi there,
Joann
KSGER STM32 2.1S Soldering Station Videos - Review Soon
Convoy L6 thread with XHP70.2, TA FET driver, Narsil v1.2 ramping firmware (old), lighted side switch, SMO reflector.
Supfire L5-S thread with XHP70.2, TA FET driver, NarsilM v1.0 ramping UI, 2 x 26350 cells, lighted side switch. My mini L6!
Thorfire S70S with MTN FET driver, RampingIOS (D4) and custom lighted side switch.
10 NarsilM user videos for BLF Q8, GT, GT70, GT Mini, Astrolux S43 and ROT66
Texas_Ace BLF Calibrated Lumen tube and Maukka Calibration Lights for DIY Lumen Measuring Devices
Headlight List with prices, specs and features - Jaxmnve M1 Stainless 10180 Keychain light Review - Lumintop ODF30 Review - Sofirn C8F 21700 Teardown and Review, Sofirn SP33 v2 XHP50.2 Review - My Sofirn Q8 Results - Astrolux S43S 219C Test Results - Lumintop GT Mini Test Results
I can’t seem to get into Mode set 7: 100%
I can get into Mode set 6: 1 5 15 32 60 100
I can get into Mode set 8: 25 100
Any tips?
Going to keep trying in the mean time.
EDIT:
I figured it out, all my fault
Disable moonlight, if want Mode set 7: 100%
With Mode Set 7 you have moonlight first then 100% if you don’t disable moonlight.
Which I think is kind of not well thought out. If i select a mode set with only ONE mode, It should only be ONE mode. No?
My OSH-Park boards
Hi,
does anyone know, if Sanyo NCR20700B does fit into battery carrier and GT Tube?
Thanks a lot.
No, they are too big.
Texas Avenger Driver Series
My LED Test series - XP-L2 V5 - Nichia 219C 90+ CRI - Latticebright "XM-L" - XHP35 & PWM efficiency - XHP50 - XP-L V5 - XM-L2 U2 - XP-G3 S5 - XP-L HI V2 - Oslon Square & direct comparison to Djozz tests - Nichia 319A - Nichia 219B 9080 CRI - Nichia 219C D320 - Nichia 229AT - XHP70.2 P2 - XHP50.2 J4 - Samsung LH351D
Easy comparison tool for all my LED tests
“Keep On Luxing” and “May The Lux Be With You” © (by my very self)
"Keep On Luxing" © and "May The Lumin Be With You" © (by my very self)
This link would be usefull under
• Why is my luxmeter …
- readings at different distances:
http://budgetlightforum.com/comment/1258213#comment-1258213
Great video also Jason, thank you! It answered in a simple to understand way what I was trying to figure out in the blinking modes.
A huge help…….
.................................. "Slow is Smooth, Smooth is Fast" ...................................
Texas Lumens Flashlights / M4D M4X Deals : sign up - save $$$$
Rudeness Level _ mΩ _ {width:70%} _ LightWiki _ LED Tint Chart
Xlamp size chart _ BatteryU _ Flashaholic? Need Professional Help??? TheOriginal _ TAB _ LightSearch _ BatterySearch _ 14500's _ DiCal
Here is my take on the UI
https://www.youtube.com/watch?v=Lc_Widc9uqk
A lowe case fits the GT
http://budgetlightforum.com/comment/1259616#comment-1259616
https://store.lowepro.com/lens-case-13-x-32cm
Great video! Added to the OP.
Hi there,
Joann
Joann
You can send him a PM, personal message, and ask if he will notify you when he puts them up for sale.
http://budgetlightforum.com/messages/new/11225?destination=user/11225
It may be a couple of months, though.
I GOT NOTHING
Thank you for the info, I will try sending a PM.
Joann
Joann
Joann
Joann
Joann
Joann
