NITECORE TIP MODS?
34 posts / 0 new
GRAY LITNIN
Last seen: 3 months 4 weeks ago
NITECORE TIP MODS?
Anyone have any ideas, tips, or just want to share their mods for the TIP?
Mines got a concussion i need to fix, so while i got it apart ima have some fun!
Should my information be incorrect in the slightest please inform me as i am always learning as well and may not recollect everything properly. ALSO, ANYTHING I WRITE PLEASE TAKE WITH A THOUSAND GRAINS OF SALT AND YOUR OWN LIABILITY, AS YOU SHOULD WITH ALL INFORMATION.
zeremefico
zeremefico's picture
Last seen: 1 hour 13 min ago
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Jerommel
Jerommel's picture
Last seen: 6 hours 31 min ago
I popped in a nice 3500K CRI90 Nichia 219C in stead of the XP-G2 and added a black metal pocket clip from an SK68
PH_Oton
PH_Oton's picture
I’ve replaced XP-G2 s3 with 219C sw40 R9050. Also I added thermal paste instead of glue if I decide to disassemble it again which I already decided. Sice there is small gap between mcpcb and it’s plastic slot there is no much cooling for emitter. I will isolate back side with capton tape and in between mcpcb and it’s slot I will add copper tape and stretch it over whole body. That should improve cooling dramatically! Smile
vwpieces
vwpieces's picture
Last seen: 6 hours 58 min ago
I got a $10 TIP CRI.
Wasn’t happy with the Greyish tint, swapped a 219C 4500K that was sitting loose on the bench, doubt it is high CRI but I do find the light to be more practical for my purposes.
Never did take out the rest of the internals. Used fresh thermal plaster to hold the reflector back in.
Jerommel
Jerommel's picture
O yeah, i removed the LED gasket and stuck the reflector holder / head / bezel directly on the LED board with grey epoxy, so it has a better thermal path (with the gasket there was a minute gap between it and the LED board), and with some grease it transfers heat to the aluminium shell.
CRX
CRX's picture
Last seen: 1 hour 37 min ago
I know you’ve all probably seen this but I’ll add it here anyway.
Nichia 219C D320 5000K and Red LED with momentary switch.
Replaced glue with thermal paste, potted internals with silicone and copper tape on inside of casing from reflector down.
GRAY LITNIN
Yep, seen it, and glad you posted it, more mods we have in one area for a particular light the better!!!
Dont forget to mention the GITD epoxy/resin, can see it a little in 3rd photo
I would like potted internals when mods are done as well, does Permatex blue rtv silicone work well? Or should i pick up some clear stuff that is less acidic?
CRX
CRX's picture
Less acidic is better.
GRAY LITNIN
What are all the advantages to the copper tape? I know it helps heat transfer but is it better for extended time before stepdown? Just longer life in general because cool electrics is happy electrics? Runtimes?
I like it technical lol!!!
GRAY LITNIN
These are awesome guys!!! Keep’em coming, i don’t care if it’s just an idea, lets hear it!!!
GRAY LITNIN
SWEET! So what are you using, lol? I know if the $100 stuff but what’s best for budget?
CRX
CRX's picture
Most likely not much at all but there was space for it so I put it in Smile
I used this stuff but take no responsibility for anyone else using it Big Smile
Jerommel
Jerommel's picture
So here’s the TIP with a clip:
Much better than that chunk of plastic it comes with.
yclongthrow
Last seen: 49 min 31 sec ago
Mine flickers only on medium, any idea what it could be?
CRX
CRX's picture
Nicely done clip
GRAY LITNIN
CRX said-Most likely not much at all but there was space for it so I put it in Smile
Never hurts to ease the mind a little
CRX said- used this stuff but take no responsibility for anyone else using it
Thankee! And duly noted!!!
I dont have a sig line but was thinking of something to put down there that limits my liability lol!!!
GRAY LITNIN
Super job!!! Im def. gonna put a clip on it, mines first gen so didnt get a clip at all!
vwpieces
vwpieces's picture
I like that clip! My TIP plastic one went in the garbage on day one.
It matches my Leatherman PST. Clip came from a SK98, replaced where the lanyard loop was. EDC the PST for more than 25 years.
GRAY LITNIN
Good to know i ain’t missing anything with the new plastic clip lol! Nice Leatherman mod as well! Awesome to know the original leatherman PST is still goin strong after all these years! Love my Black Charge ALX, it’s used daily for one thing or another.
pc_light
Last seen: 1 hour 16 min ago
Jerommel – x3 great clip, will have to see if I can find something similar.
CRX – x3 I think your mod is the ultimate.
Gray – Even the CRI wasn’t warm enough for my taste, so I took a cool tint one I had and stuck in a 4000 XP-L HI. Now my TIP rivals many of my larger lights.
Like others I also found the thermal heatsinking wanting. Most of the internals are plastic and the primary path for heat from the emitter appears to be from the emitter/board -to the reflector -to the shell. So I Arctic Adhered all three areas, almost potting the reflector, to help with any possible heat issues.
Move towards the light.
GRAY LITNIN
Awesome info! Im either goin with highest cri i can get or the xpl-hi, not sure yet. I bet the HI in such a little light looks ridic!!
Whats the runtimes for the HI TIP now?
Are there different reflectors available somewhere that will fit the TIP (SMO, OP, TIR)?
pc_light
Are their different reflectors available somewhere that will fit the TIP (SMO, OP, TIR)?
I have both the original TIP CRI (neutral) and recently ordered a 2017 CRI in the hope that it would be warmer but it was similarly (cool-)neutral, which was the reason I swapped emitters. (The host for this swap was a cool TIP version, my CRIs remain as is.)
Runtime/battery life don’t appear to be affected by the swap from XP-G2 to XP-L HI. (Although I’ve never run my battery out before a weekly recharge.) FWIW, both emitters have similar V-fs with the XP-L putting out maybe 10+% more lumens for the same power.
As for throw, while there might be a marginal gain in a (slightly) tighter hot spot with the HI, the TIP is not a thrower because the reflector is simply too small and shallow. AFAIK there aren’t any retail replacement reflectors for the TIP; it’s smaller than those of any of the throwy AAA lights I own.
A TIR might be a good option but keep in mind that the thermal transfer path for the TIP involves the reflector, one would need to create a new thermal pathway for heat to escape from the emitter.
Looking forward to seeing more of your TIP journey.
GRAY LITNIN
Thnaks a bunch!! Answered my questions, then as my mind was thinking of new ones my eyes were already reading the answers lol. I figured there wasnt much gain in such a small package thats why i thought about reflectors and such. Might tinker with making one for it but my time is limited as it is. I’m still very much in the ideas and learning phase at the moment, so it will be some time before you see progress lol. But i will be more than happy to share. Thats what it’s all about!!!!
Might come to realize that it may be too much trouble to mess with and just fix the problems and put it back together the way it was. Still gonna pot the electrics though, can’t have poor little guy losing it’s marbles again!
But i’ll let ya know for sure!
That said whats the difference in the Artic Adhesives? Other than ceramique being non-conductive and the others slightly capacitive?
pc_light
GRAY LITNIN wrote:
… whats the difference in the Artic Adhesives? Other than ceramique being non-conductive and the others slightly capacitive?
I’m not an expert but that’s my basic understanding of the two Arctic adhesives as well. They really should be used as thermal adhesives rather than potting.
For that reason, I’ve been considering some proper potting compounds such as the DP stuff from 3M or MG Chemicals, for use in my P60 drop-ins. Generally this stuff is sold in such large containers that even the smallest containers would take me years to use up and I worry about shelf-life.
Litefighter
Litefighter's picture
Last seen: 2 weeks 3 days ago
Not a mod per se but I use these to protect the charging port.
https://www.ebay.com/itm/25-Pcs-Anti-Dust-Soft-Plastic-Dock-Cover-Micro-...
pc_light
What’ll they think of next. Maybe not a mod but definitely a help – ordered!
Arcadefreak43
Last seen: 10 months 1 week ago
I have the first gen tip and two screws fell out. Unfortunately it’s more than a year old. Nitecore’s advice is you can purchase replacement screws for them by paying to their paypal account.
Thought I would checkout this little guy as a replacement: https://www.mecarmyusa.com/products/mecarmy-sgn5-personal-alarm-flashlig...
GRAY LITNIN
Thanks, i figure the artic would help a little where you cant properly get a good thermal path with other means.
I’m interested in the proper potting compounds as well! When you find out what works well thats sold in decent size containers (im with ya on buying a gallon of stuff you only need a few ounces of) i would be grateful if you shared your experience!!
GRAY LITNIN
I was about to order these myself about a year ago but i took a piece of small bicycle innertube and slipped over it. Prolly not much but def. keeps the dust and pocket lint out! I wonder if adding one of these under it would make it more waterproof?
GRAY LITNIN
Same here. Im sure it didnt help that the two screws were missing when it bounced off the concrete!! I plan on gluing it all together when i get around to fixing it! Or making a whole new body would be cool!
I was interested in the sgn5 as well, seems like a great light!! I just worry that i’d set off the alarm at the wrong time, like when im getting ready in the morn while everyone sleeps (use my TIP alot for this!!!).
