I received this Astrolux S42 from banggood. I have fulfilled all specification requirements, but the lantern does not work. The battery is unprotected. I am familiar with the problem of using a protected battery. All parts are tight and the indicator lights up green.
Does anyone have any idea to remove the problem.
Video:
Astrolux S42 problem.
looklike the wire come to the switch pcb has broken, you can ask BG for refund
this can easily be fixed
You have definitely gotten a detective unit.
Ask for a refund and you should be good to go.
Thanks for the quick answers.
what battery are u using? try a different if u have? not sure if that light takes unrprotected or not, but i bet banggood will only offer u a partial refund - they suck!
The battery is unprotected. It works well with my Emisar D4.
BG promised me a new head. I guess they’ll be correct.
I have the same problem with my new Astrolux
I tried with an unprotected 18350 imr Flatthead.
I am in Contact with bangood.
sucks its not working, clearly a faulty light, i think a crappy batch they sent out ask for full refund, no 5-10$ back only the light clearly is not working. If they want proof make new video and show what battery before u insert so they will see for sure its kaputt…
Apparently this is a general problem. I’m still waiting to get my head. Try with long presses and alternating with quick clicks, this sometimes triggers the flashlight.
Мandatory ask to solve the problem from BG.
Thanks, i tried but nothing Helped.
I am still in Contact with bangood.
I Hope it will only an bad Batch and not an General problem
Is the optics cracked too? Looks like.
Mike
The little parts broken until i Open it, or did you meen inegve
I did not watch the whole bideo because it was buffering.
When i received my s42 and samsung 18650-30q from banggood the cell had a very thin invisible sticker over the negative battery end. Just in case you hadnt checked for that.
Thanks but the akku Work in my other Flashlight.
Bangood will send me also a new head.
Now ist Time to wait.
Ask BG to test the head before sending it to you. They process the order very slowly, I’ve waited 10 days before the they send the light head. Still waiting.
Ok i will, Thanks Ingeve, Hope the head arrive you soon
Hello Ingeve Please write when the head arrive and Work, i still wait.
Still waiting. When I arrive I will share impressions.
Today I got my head and the flashlight works finе.
