Hi,
I write for the first time and hope it’s the right place.
Is there a SMO reflector suitable for BLF A6?
I would like the A6 to be more of a thrower.
Thanks, Nitzan.
I think this oe , but better someone confirm it : https://www.aliexpress.com/item/20-12mm-SMO-reflector-with-XPL-gasket-for-Convoy-S2-S3/32728224955.html
This , will just make the hotspot defined , will not make a dramatical difference . Maybe you should get a Convoy C8 with xp-l hi , a very good entry thrower .
Thanks, I have Astro Lux C8 and I believe it is quite similar to the C8 Convoy. The flashlight should be connected to a bicycle helmet and I would like a larger hot spot than the C8. One meter hot spot at a distance of 15 meters.
I’ve already tried some bicycle lights and some ordinary ones. I rode with the Haikelite MT01 on the head. A lot of light but a little heavy.
I am now at the thought stage of separating the head of the Haikelite MT01 from the batteries. Give it electricity from a battery pack like having on eBay.
But continues to look for a solution with a ready flashlight without work.
