HaikeLite MT07S-HI XHP35 thrower Released
HaikeLite MT07S-Hi is a real far-distance thrower from haikelite.
This light has the same flashlight host with MT07S. We specially designed a new reflector and new 35mm DTP copper PCB for 35 Hi emitter.
New flashlights are ready for dispatch on 11th December.
Specifications:
Emitter: CREE XHP35 Hi
Meterial: Aluminum Alloy , HAIII Anodising
Battery: 4x18650 (Recommend button top 18650s)
Reflector:SMO Aluminum Reflector
Lens: Double Side AR coating Glass Lens
Bezel: Stainless Steel
Waterproof: IPX8
Intergrated shelf thickness: 8mm (enhanced heat sinking ability)
Max Output: 3000 Lumens
Max Beam Distance: 1200 meters
Lux: 360 kcd
Max runtime: moonlight 3 lumens—30 days
Digital Current Regulation
Anti-reverse protection
Anti-discharge protection
Demension: 175mm x 66mm x50mm
Netweight: 510 gram
Accessories: landyard,O rings,Tripod Mounting Screw
Hi,
are you planning to hand out review samples?
Very nice spec and beautiful. But can you publish your test report for the spec? I think every brand should do that as standard product data. If Haikelite do that, Haikelite will definitely be standing out of the crowd of many brands.
3000 lumens :question: :person_facepalming: Maybe 2700.
one for me please :smiley:
How is the reflector different?
I want to see more of this light. Why no videos and beamshots all over the internet? The form-factor is so much better than the heavier (Astrolux/Mateminco) versions.
Why haven’t we seen them?
I had this light and a few words from me.
Good, solid and quite heavy. It’s better in your hand than BLF Q8 because it’s better balanced.
The button is a bit rubbery but works well. Of course, there are some drawbacks. Poor centering of the diode, I had to improve. Thermal paste of poor quality, because under the influence of temperature, the reflector begins to evaporate and dull. I had to clean everything and apply my own paste. The diode was supposed to be NW and it was almost there, only in low power. In the turbo the color shift is large and with 5700K it lands at 6400K. Fortunately, it is under the BBL line so the color is pure white. The turbo shines a long time because the thermal protection is not aggressive, but the flashlight can get hot.
Batteries connected in series, power consumption from one piece is 2.5A. In total, it gives 40W. I reached 2,200 lumens and 252,000 lux on fresh batteries.
One more disadvantage, but it’s probably my copy, it’s a battery drainage of 6mA. Generally, for a price with a coupon, quite an interesting proposition, but not without flaws.
thanx for sharing this info.
Can you say something about the user interface, Komeko?
surely
It’s a bit similar to Thrunite.
With OFF:
Click - on.
Double click - Turbo
Holding … - unless moon
With ON:
Click - off
Holding down is a change of modes low, medium, high (there are several levels)
With the turbo click back to the previous lighting mode.
In addition, the flashlight has the memory of the last mode, of course, except for turbo and moon.
nice deal on this Archive topic - Banggood & Fin17 - #413 by Fin17
Anyone else have any feedback ?
I also would like to see beamshots, preferable compared to Astrolux mf02.
Someone please post a beamshot of this light in turbo at night.
I do not have this flashlight anymore, but as I had compared it to Thrunite V6 and MT07S HI it shines on. It has a more tight beam and a little more lumens. It was already visible.
Thanks
So that 360k claim is spot-on?
Here are my measurements (TURBO):
Color (NW) 6399K (5710K in HIGH) under BBL (x:0,316 y:0,318)
2.5A from the cell, batteries connected in series, which gives us about 40W
2202 Lumens
252000 luxs
Range 1005m
After 6 minutes the temperature reaches 53 degrees Celsius and there is no descent down from the turbo.
Weight 740 grams with batteries
Dimensions 181x66mm
Thanks so much. I love the feeling of these in my hand. The other bigger contenders are too awkward-feeling.
I’m getting one, especially now that they are on sale!
It’s great in my hand.
