[Sale] Buck drivers 20, 21, 22, 24, 30mm L6, MF01, MF02/04(S), TN40S/42, BLF GT, Acebeam X45/65
215 posts / 0 new
Newlumen
Newlumen's picture
Last seen: 2 months 6 days ago
Hey blf, we are going to mod the astrolux mf-02 to the best.. of course xhp35 hi. Which parts do i need to order ?? Do i need a new sink pad? Thanks
Lexel
Lexel's picture
Last seen: 1 day 1 hour ago
You can use old Sinkpad it is pretty good
Just the LED seems not to be pretty good flux bin looks from my measurements like a D2 flux bin
You need just the driver, maybe also interested in my 2×2 LED board that supports up to 4 different LED colors
338LM
Last seen: 2 years 4 months ago
I have MF02 coming, would like to do this mod. I also have electrical school baground and soldering irons etc home.
Still bit unsure what will I need? Is this bolt-on mod requiring only battery serial modification for 12V supply with new driver?
arficus
Last seen: 3 weeks 1 day ago
interested
Lexel
Lexel's picture
Battery carrier needs mod as shown so from 7.4 to 14.8V
Then it is just replacing old with new driver
Lexel
Lexel's picture
new boards shipped
chooma
Last seen: 31 min ago
Big Smile yes they are…..thank you Lexel
Redlyne22
Redlyne22's picture
Last seen: 1 week 3 days ago
I’m in!!!!!for GT style driver..it should work just fine with my Mateminco MT35?
Sometimes being a newb is the best part of a hobbie
Lexel
Lexel's picture
Got today the 2. batch boards along with more light types, was some delay from DHL because the content was just described as “boards” so they did not how to declare for import taxes
I am very happy with the quality of the boards better than last Chineese manufactory I ordered and cheaper too, multiple sizes of stencils cheap too
Especially the silkscreen is way better than last one that did not supported such small letter size which messed it up
JasonWW
JasonWW's picture
Last seen: 1 hour 6 min ago
Yes, it’s pretty much exactly the same as the Astrolux MF02.
338LM
Im interested! But same time wondering how much 70.2 would improve actual throw…?
Lexel
Lexel's picture
70.2 would not improve throw at all, but with it it would become something similar to Acebeam K70 as allrounder with about 6500 Lumens
JasonWW
JasonWW's picture
Right.
Vinh at Skylumen built and tested this light with a 70.2 plus a different driver and measured 6,700 lumen, 235kcd and 970 meters throw.
With a sliced dome it had 5200 lumen, 330Kcd and 1149 meters throw.
Blazer296
Last seen: 3 weeks 3 days ago
Two quick questions on the MF-02 driver.
1) Switch wiring, is just a connect/disconnect so polarity doesnt matter for that part correct?
2) Where is a good spot to get power for the switch leds?
A wiring diagram for the MF-02 switch set-up would be awesome if someone has one.
Heading to my shop to get this mod done now. Hopefully it goes well.
Lexel
Lexel's picture
Switch shares a common ground with the LEds on the original, so wire this lead to G
S for switched ground from the siderswitch
The MF02 driver has one MCU controlled LED output (L) with resistor installed by default 33k
It is possible to add another LED with a resistor to the 5V Supply volatge
ARsee
ARsee's picture
Last seen: 3 days 21 hours ago
Lexel, bare with me. I’m out of my realm of knowledge.
I see you have boards for the TN42. What (over stock) are the advantages gained by using your configurations?
JasonWW
JasonWW's picture
It’s mainly the different UI. NarsilM with ramping, blinking out battery voltage, etc… It is usually way better than the stock UI’s.
You can also adjust the power output if you want. Up to 3A at 12v. If the stock light only had 2A for instance, you could bump it up a little to 2.5A and get a bit more output.
Lexel
Lexel's picture
2.5A GT makes a bump from 663 to 707kcd on a TN42 I modded
current over 2.5A makes no sense, 2.7-2.8 on a good cooler there may be a few % gain in throw but also this mainly starts getting the LED to turn over to get blue very quick
Main advantage is the UI you can change so many things like you want the UI for your purpose
ARsee
ARsee's picture
It sounds like the UI of the GT, which I like.
Assuming the board is plug/play, are the boards, electronics better quality? What type of output gain (reach/throw?) is .5A going to give?
Lexel
Lexel's picture
the TN42 was driven at about 2.25A
as I wrote 663 to 705kcd measured with 2.5A
of course I can do any output current as you wish
ARsee
ARsee's picture
That’s the barrier. I don’t know what output I wish because I have no knowledge.
My TN42 arrives Monday. I’ll compare it to others and maybe get a better idea and %‘s.
Thanks Lexel, Jason
iosala
Last seen: 4 days 16 hours ago
I want one please, as well as the switch with CW leds. Thank you!
Flying Luminosity
Flying Luminosity's picture
Last seen: 5 months 3 days ago
I’ve realised that I’d much prefer my MF-02’s in NW. Since I don’t dare to reflow the LED myself, I was wondering if there’s a star that will fit, with an XHP35 NW already mounted?
I’ve got two lights, one with a defective driver. So if I manage to replace the star in one, I’d be happy to do the same with the other, and replace the faulty driver with the one that uses Narsil.
JasonWW
JasonWW's picture
Really large diameter 12 volt Stars are very hard to find right now. Maybe you could find someone in the UK with the blf GT who wants to swap emitters or maybe there is a person who knows how to do reflows for you. I know Mountain Electronics is offering a Reflow service but he’s in the United States so I don’t know if it’s worth it due to the shipping costs.
Lexel
Lexel's picture
Maxtoch star will fit
https://de.aliexpress.com/item/MAXTOCH-Copper-MCPCB-Cree-XPG-XPG2-XPE-XPE2-XPL-XP-G-XP-G2-XP-E-XP/32680690200.html
If you send me the star and LED I can do a reflow on my regulated heat plate for 2€
Flying Luminosity
Superb, thanks – what’s a good place to get the emitters? Can get two of each (LED + star) sent to you – if you PM me details & price incl. one of your drivers, I can pay you via PP.
EDIT: Not sure if I was completely clear – both my MF-02 are in CW, so I’ve already got the stars. But if I can get the XHP35 NW LEDs sent to you, and the existing stars with CW LEDs, I guess the emitters can just be replaced. I’d be happy to let you keep the CW ones, as I’ve decided that I’ll only be getting NW lights in the future.
Lexel
Lexel's picture
sure reflowing on a used star is no problem
JasonWW
JasonWW's picture
Those are an option, but only if you convert them to 12v by cutting and adding a jumper wire.
Does the 26mm fit the MF02? I remember there was one light that it was too big for, but I cant remember which one. Lol
Lexel
Lexel's picture
I fitted the MF02 a no name DTP 25mm XHP70 star modded to 12V
XPL/XHP35 footprint is always 12V there are no 6V ones
I wish XHP would be sold as 6/12V would make so much more options
JasonWW
JasonWW's picture
That’s right, I was thinking of the people swapping in 12v xhp70, like into the GT and this light with a driver swap. The xhp35 is wired internally for 12v only.
