[Sale] Buck drivers 20, 21, 22, 24, 30mm L6, MF01, MF02/04(S), TN40S/42, BLF GT, Acebeam X45/65
215 posts / 0 new
Skuffe
Last seen: 2 years 3 months ago
Any news on modified PCB’s for the battery carrier? I would be interested in that for a more “OEM” solution.
Theodore41
Last seen: 5 days 10 hours ago
Lexel wrote:
JasonWW wrote:
ARsee wrote:
Lexel, bare with me. I’m out of my realm of knowledge.
I see you have boards for the TN42. What (over stock) are the advantages gained by using your configurations?
It’s mainly the different UI. NarsilM with ramping, blinking out battery voltage, etc… It is usually way better than the stock UI’s.
You can also adjust the power output if you want. Up to 3A at 12v. If the stock light only had 2A for instance, you could bump it up a little to 2.5A and get a bit more output.
2.5A GT makes a bump from 663 to 707kcd on a TN42 I modded
current over 2.5A makes no sense, 2.7-2.8 on a good cooler there may be a few % gain in throw but also this mainly starts getting the LED to turn over to get blue very quick
Main advantage is the UI you can change so many things like you want the UI for your purpose
…and the blinking strobe frequency goes to 18Hz as the Q8?
About the TN42 now.Is it difficult to open up this something like the GT?
Theodore41
Lexel wrote:
the TN42 was driven at about 2.25A
as I wrote 663 to 705kcd measured with 2.5A
of course I can do any output current as you wish
Hi Lexel.
What about the TN40S?Is it possible to upgrade this as well,and what will be the benefit?
LuxLumen R.G
LuxLumen R.G's picture
Quick question Lexel.
On the BlF GT driver for the MF02 there is one pad for the led on the driver for the switch but there are 2 leds on the switch.. So do I put both on the same pad or just pick the color I want to use and go with that one?? Thanks in advance.
Lexel
Lexel's picture
Last seen: 1 day 31 min ago
Hi Lexel.
I sold one 8A Buck driver for the TN40 that got modded with XHP35s
So the TN40S can be modded as well to 12V Emitters
I guess the carrier needs to be modified to 4S did not find information about it
I have let made 4S boards with last PCB order
LuxLumen R.G wrote:
Quick question Lexel. On the BlF GT driver for the MF02 there is one pad for the led on the driver for the switch but there are 2 leds on the switch.. So do I put both on the same pad or just pick the color I want to use and go with that one?? Thanks in advance.
You can choose 1 color on the board without modification
Green and red have different LED voltages so only red will light up if you add both
I made new 2×2 LED Boards
you can have 2 LEDs one on Power and one from MCU
LuxLumen R.G
Thank you Lexel keep up the great work my friend!
panagis
panagis's picture
Last seen: 5 months 4 weeks ago
Lexel i am interesting for the whole package for MF 02 with stock emmiter (NW)
I want driver for 2.5 amp, cutted battery pcbs (any posibility to send me the battery pcbs with buttons and good quality springs ???) and two color switch correctly wired to the driver)
thanks
Lexel
Lexel's picture
The MF02 carrier MCPCB and springs are pretty good quality
It is easy to mod those 2 in less than 5 Minutes
I measured on another Manufactor for the carrier rods diameter for the MCPCB holes and those do not fit the MF02 without drilling holes, but this is reducing the 4 main viases making electrical connection less good
WaylonJennings
I already have a MK35 and was wondering if you had a driver for that light?
ZozzV6
ZozzV6's picture
Last seen: 2 days 7 hours ago
Lexel do you have TA driver PCB for MF02? I want to put in an XHP70.2 in 6V setup with TA driver and Andúril firmware.
Lexel
Lexel's picture
I have Buck driver for it on 8.4 or 16.8V Battery configuration
I strongly recommend 12V LED configuration for 6-7A equal 12-14A on 6V
I modded one with 12V here also LED on 12V configuration
http://budgetlightforum.com/node/58925
Nicolicous
Nicolicous's picture
Last seen: 9 min 40 sec ago
I want one too
Nico -.-
WaylonJennings
ZozzV6
ZozzV6's picture
Lexel wrote:
I have Buck driver for it on 8.4 or 16.8V Battery configuration I strongly recommend 12V LED configuration for 6-7A equal 12-14A on 6V
Sure it is easier on the springs and wires with lower current. OK
Lexel
Lexel's picture
I never had a MK35 light so hard to say if it would fit without getting the driver out and take measurements
technically it is possible to get the brass ring and button on a 46mm MT07S board, but if te inductor and other stuff fits in the head idnk
reviews do not open driver section
KawiBoy1428
KawiBoy1428's picture
Last seen: 9 sec ago
Hey Lexel, just got around to putting the MF02 driver in, that lame MF02, kicks some ass now, very nice work on this great upgrade of a driver! Makes me want to possibly keep it…..
Maybe…..
KB1428 “Live Life WOT
td1042k
Definitely interested in the GT driver for my NW MF02! Let me know what I need to do to get this in my hands!
Ultrafire C12 XHP70 2S 18650 Mtn Elec 6V Zener mod driver (super donut beam!)
Ultrafire C12 XPL-HI BLF-A6 FET driver
Convoy L6 Mtn Elec D4 UI driver, XHP70.2
Utorch UT02 NW
BLF Q8
BLF A6 NW
BLF GT XHP35
BLF GT (GT70 CONVERSION CW(SOON))
Skilhunt H03 NW
Astrolux MF02 NW
Astrolux MF01 XP-G3
Sofirn SF14
Sofirn SP32A
Emisar D4 XP-L HI CW
SK68 knockoff
Mini Mag Lite 2X AAA
Convoy M1 build (4X XPL 3V MCPCB, Mnt Elec FET driver)
Redlyne22
Redlyne22's picture
Last seen: 1 week 3 days ago
KawiBoy1428 wrote:
Hey Lexel, just got around to putting the MF02 driver in, that lame MF02, kicks some ass now, very nice work on this great upgrade of a driver! Makes me want to possibly keep it….. Maybe…..
Kawiboy, you running a xhp 70.2 in the MF02? If so, are you running a 12V 20mm mcpcb or did you mod a 6v mcpcb to 12v?
I just fried my xhp 70.2 while reflowing it. Trying to decide what im going to do next.
Sometimes being a newb is the best part of a hobbie
Lexel
Lexel's picture
25-32mm MCPCBs fit with little modification
There are Maxtoch ones or Fasttech 25mm DTP boards available you can mod to 12V
The driver needs another resistor for switching frequency if you have a 12V configured driver and you want to go to 6V LED
current stays the same
KawiBoy1428
Naw just upgraded the driver in the MF02 to a 4S running a K70 4S carrier I had to shave down the diameter of the PCB’s to fit the battery tube of the MF02.
I have (way too) many 70.2’s,,, the 1-BLF GT, 2-Thrunite TN42’s, 2-Lumintop SD75’s, 3-Convoy L6’s, 1-Convoy L2, 2-Jaxman X6 Hunter’s, 2-Surefire M3 Combat Light’s, 1-Surefire 900A, 2-Surefire M3 Combat lights I custom made, 2-Surefire 962’s weapon lights, 1-Thrustfire T90-2, 1-Yezl Y3…just off the top of my head, got enough 70.2’s! Facepalm
FelixLighter
Last seen: 2 years 1 month ago
Interested
Lexel
Lexel's picture
FelixLighter wrote:
Interested
in which driver?
808Hi
Last seen: 7 hours 39 min ago
Interested in NiWalker BK-FA306 with 4S boards
FelixLighter
BK-FA30S
wheezy
wheezy's picture
Interested in driver for the MF02 XHP35 LED 2.5A
and carrier modification.
LEDtec
Last seen: 7 months 2 weeks ago
interested in one for GT+XHP70, if possible.
Thanks Lexel
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 30 min ago
@Lexel Do you have a working buck driver/sell the buck driver with NarsilM for a Haikelite MT09R?
JasonWW
JasonWW's picture
Last seen: 22 min 1 sec ago
Is it the xhp35 or xhp70.2?
BlueSwordM
The XHP70.2 version.
JasonWW
JasonWW's picture
Lexel will need to convert it to 12v. I think it can be done since the battery tubes use replacable pcb’s. Iirc, the mt09r has the same size driver as some of his other lights using the buck driver. I’m pretty sure he can do it. We’ll have to wait till he responds for more details.
Have you asked Texas_Ace? He is working on a bunch of mt09r’s right now and is closer in Texas. I don’t know if he has a buck driver made up, but he might. It’s worth asking.
