Test/review of Keeppower 18350 1200mAh UH1835P (Black) 2017
28 posts / 0 new
HKJ
HKJ's picture
Last seen: 15 hours 4 min ago
DSC_2344
Official specifications:
  • Nominal capacity: 1200mAh
  • Nominal voltage: 3.7V
  • Charging method: CC-CV
  • Charging voltage: 4.20V
  • Std. charging current: 500mA
  • Discharge cut-off voltage: 2.00V
  • Max. constant discharge current: 10A
  • Max. pulse discharge current: 15A
  • Size: 18.3 × 35.0mm
Keeppower%2018350%201200mAh%20UH1835P%20(Black)%202017-info
A high current and high capacity 18350 cell from Keeppower
DSC_2342 DSC_2343
DSC_2345 DSC_2346
DSC_2347
DSC_2348
Keeppower%2018350%201200mAh%20UH1835P%20(Black)%202017-Capacity
The batteries has good discharge curves, they tracks fairly well and capacity only drops slowly with current. 10A works fine, 15A is too much.
Keeppower%2018350%201200mAh%20UH1835P%20(Black)%202017-Temp-7.0
Keeppower%2018350%201200mAh%20UH1835P%20(Black)%202017-Temp-10.0
Keeppower%2018350%201200mAh%20UH1835P%20(Black)%202017-Temp-15.0
Keeppower%2018350%201200mAh%20UH1835P%20(Black)%202017-CapacityTimeHours
Keeppower%2018350%201200mAh%20UH1835P%20(Black)%202017-Energy
Keeppower%2018350%201200mAh%20UH1835P%20(Black)%202017-PowerLoadTime
Keeppower%2018350%201200mAh%20UH1835P%20(Black)%202017-TripCurrent
Keeppower%2018350%201200mAh%20UH1835P%20(Black)%202017-Charge
Conclusion
This battery is from the new generation of smaller cell with much improved performance. This means that this battery is one of the best 18350 at the current time.
Notes and links
The batteries was supplied by Keeppower for review.
Comparison to other LiIon batteries
MRsDNF
MRsDNF's picture
Last seen: 3 weeks 9 hours ago
Thanks HKJ. This battery has been talked about for awhile now. Thumbs Up
saypat
saypat's picture
Last seen: 37 min 28 sec ago
where can one purchase these? Thanks!
djozz
djozz's picture
Last seen: 8 hours 1 min ago
I fear a bit that this battery goes the same route as the Aspire 18350 (since it may be the same one), I already see several sources under restocking.
richnpc
Last seen: 3 hours 44 min ago
Persechini
Persechini's picture
I hope this becomes available somewhere with international shipping, getting popular 18650s is already hard enough, with 18350s it’s even worse
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
freeme
freeme's picture
Last seen: 31 min 7 sec ago
Woohoo, 1200mah is back on sale!
©freemex1thedeals.com
djozz
djozz's picture
where?
MascaratumB
MascaratumB's picture
Last seen: 6 hours 37 min ago
djozz wrote:
where?
Protected:
https://www.aliexpress.com/item/High-Quality-2pcs-P1835C2-IMR18350-1200m...
Unprotected:
https://www.aliexpress.com/item/4PCS-LOT-Original-Keeppower-3-6V-18350-1200mAh-Continuous-10A-Pulse-15A-Li-ion-Battery/32846470334.html?spm=a2g0s.8937460.0.0.avjEbn
Wink And some other AliExpress stores have them Wink
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 /// KLARUS: XT1C
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8  TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
GIVEAWAY - 1
djozz
djozz's picture
…and the wink is because? Is there a group buy in the make?
MascaratumB
Eheh, no no – at least not that I know of! I just used the Wink because there are several stores with these 1200 (un)protected Keeppower, I keep them under sight in case I need more to replace or add to the Aspire IMR18350 1100mAh I bought when they were still produced!
And because I use a lot of smiles on my messages Facepalm
GIVEAWAY - 1
Barkuti
Barkuti's picture
Last seen: 3 hours 8 min ago
I believe these cells are still being produced by Shen Zhen Yong Deli, it's great to see KeepPower marketing them.
Cheers Smile
jon_slider
jon_slider's picture
Last seen: 4 hours 7 min ago
MascaratumB wrote:
Protected:
Unprotected:
thanks for the links and info
fwiw, protected 18350 are longer than unprotected.
For my PT-16, the unprotected work, the Protected are too long
also:
Can not deliver to United States”
MascaratumB
jon_slider wrote:
MascaratumB wrote:
Protected:
Unprotected:
also:
Thank jon_slider Wink Apart from 2 Panasonic 18650, I don’t have protected Li-Ion cells, but I am aware those are normally longer and thicker than the non protected Thumbs Up
Also, didn’t check the shipping from that store Facepalm But there are some other stores that have those and that probably ship to the US Wink
GIVEAWAY - 1
moderator007
moderator007's picture
Last seen: 1 hour 51 min ago
This appears to be the same cell under the wrapper as the Aspire 18350.
I’ll stick with the Aspire for now since I can get them in the US and cheaper.
https://liionwholesale.com/collections/batteries/products/aspire-18350-b...
Thanks for the review HKJ, very much appreciated. Thumbs Up
jon_slider
MascaratumB wrote:
I am aware those [protected] are normally longer and thicker than the non protected
surprisingly, to me, the 16340 protected and unprotected are the same length (in inches), or 0.25 mm longer for protected.
The 18350 difference is much greater (IF the linked specs are accurate)
Protected 18350:
https://www.batteryjunction.com/efest-3400-button.html
Height: 1.47” (37.36 mm)
UnProtected 18350
https://www.batteryjunction.com/efest-4084-opt.html
Height: 34.63 mm
Added length of protected 18350, 2.73 mm
Protected 16340
https://www.batteryjunction.com/efest-3540-button.html
Height: 1.33” (33.98mm)
Unprotected 16340
https://www.batteryjunction.com/efest-3277-button-700mah.html
Height: 1.34” (33.98mm)
Added length of protected 16340, 0.25 mm
Persechini
This store is currently shipping the Keeppower UH1835P to Brazil and I imagine other countries where shipping is often unavailable, I’ve bought keeppwers from them before (currently unwrapped and returned to unprotected panny-B state)
https://www.aliexpress.com/store/918105
In my Tree
Imp
Imp's picture
These cells are now in stock from nkon.nl, a highly reputable European vendor (no affiliation).
They do however state that the cells are 39 mm long. Which makes me wonder if they’ll fit properly in my Emisar D4?
The springs should have enough play, but I’ll hold my order until I at least get home and try to cram a measured battery with a spacer in there!
Or can anyone verify that these cells will work in a D4?
HKJ states 35 mm though, and “highly reputable” is the least of his accolades. But different batches, different specs? Fake cells? Or just misspelled on nkon?
I’ll be back with a solution to the conundrum when I have it, unless solved by another.
Of the somewhat autistic personality, who enjoys spending hours on end cross referencing numbers and data to find that perfect sweet spot and perhaps a percent of gain here or there.
But also old enough to have learned that numbers seldom tell the whole story...
HKJ
HKJ's picture
35mm is unprotected cell and it can be seen on my photo that the cell is unprotected.
39mm is a protected probably button top cell.
Nicolaas
Last seen: 6 days 15 hours ago
Nice cells, allowing small lights with multiple emitters to shine, the closely resemble the Vapcell 18350 purple.
Still, the Aspire cells were even better but extremely hard to gome by……..
Tnx for testing!
Cheers,
Nico
Jimmy_Chimichanga
Jimmy_Chimichanga's picture
Last seen: 2 weeks 2 days ago
I have the aspire 1100, keeppower 1200, and the vapcell 1100, pretty sure the only difference is the wrapper.
hunter1
hunter1's picture
Last seen: 2 weeks 3 days ago
Hei Imp..
My
Aspire 34.91 long (fit D4)
Keeppower 35.09 long (fit D4)
Ultrafire (protected button top) 38.78 long (do NOT fit D4)
So there you go..
Imp
Imp's picture
I received an answer from nkon. Despite the time being post 5 pm on a Friday!
Quote:
Hi Ted,
I’ve changed the height and the width. It was not correct.
Height: 34.76
Width: 17.91
I’m sorry for the inconvenience!
Kind regards / Met vriendelijke groeten,
Mithat Kamer
NKON
So it seems like they’re fine. Although Hunter’s post makes me curious as to the measurements and batches, if nothing else…
I’ll order a bunch anyhow!
hunter1
hunter1's picture
Hi Imp..
Yes it must be batch variations. Mine Keeppowers are 35.09 to 35.19 in length and 18.27 to 18.29 in width.
Otherwise, exactly the same battery as described.
RobertB
RobertB's picture
Last seen: 2 hours 18 min ago
Tnx for testing!
Cheers,
Nico
The Aspire, Vapcell, and this Keeppower are same cell, all made by the same factory. Yongdeli New Energy Battery. Tony, the owner of Aspire E-Cig is part owner in the battery factory. At least he was a year ago.
Imp
Imp's picture
I have now received my five batteries. They are indeed about 35 mm long.
The measurement of 39 mm corresponds to Keeppowers protected 18350 cells, so the error was probably made by looking at the wrong specs, but has since been corrected.
The cells arrived in retail boxes of two, including a case for two 18350 or 18500. With a bit of cutting they can be made to fit three 18350s though! (And the fifth cell came in another of the same case, even though I ordered several other cases, one of which was used to package the two HG2s I also bought).
Furthermore, the Keeppower case for one 18650, which is apparently made with protected cells in mind, can just about fit two of these cells, with a very thin insulator! With a little bit of cutting it should be possible to fit a somewhat thicker piece of plastic in between, making it a very compact case for the job! Smile
Barkuti
Barkuti's picture
Thanks for the info. With regards to the insulator thing, no need for it strictly speaking unless you aim to prevent any scuff marks, ?
Cheers Party
Imp
Imp's picture
Cheers Party
No, I’m more after a “spacer”, or something to hold the cells in place, as the case is on the large side and they will rattle and move if there’s only one in there. Yes, “insulator” may have been a bad choice of word, but it was natural in the circumstance.
