Bond wires / SST-40 dedome
18 posts / 0 new
gchart
gchart's picture
Last seen: 27 min 16 sec ago
I tried doing a combination of shave and hot gas dedome on an SST-40 this evening. I was stupidly in a bit of a rush and ripped off one of the wires (the one by itself). Just for S&G I hit it with the continuity test and the die lit up. Which leaves me with two questions…
  1. will this LED function properly?
  2. I figure two wires are for + and -, but what is the third wire for? It seems like a lot of LEDs have three, I just never thought too much about it
Schoki
Schoki's picture
The one on the side (which broke) is, well, was, for electrostatic discharge safety. It should work without it just as nice.
...don't tell me how electronic components work, i'm studying exactly that...
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 min 43 sec ago
Nice, what are you a surgeon? Nice blade work! Thumbs Up
KB1428 “Live Life WOT
gchart
gchart's picture
Haha, thanks KB. I sliced as close as I dared (with a blade for a safety razor), then dunked in boiling gas for 15 minutes to loosen the remaining dome from there phosphor, followed by another trim with the razor to clean things up.
I can’t wait to get this into my L2 host with Mtn FET+1 driver. Should be pretty sweet.
KawiBoy1428
That is actually brilliant, that bit of silicone protecting/supporting the bond wires!
Now can you do 5-6-10 more like that, send me your pay-pal address! Wink Thumbs Up
Yeah lets us know how it looks, wonder if it will show up in the beam a bit?
johny723
Last seen: 1 day 2 hours ago
You have been lucky it was the “unnecessary” wire. What is the throw and lumen output after dedoming?
gchart
gchart's picture
Haven’t had a chance to assemble the light yet, had to go back to “real life” for a while (taking care of my 4 kids). Play time will come soon enough though Wink
MRsDNF
MRsDNF's picture
Last seen: 6 hours 35 min ago
That is one clean shave. Nice work gchart. Thumbs Up
jlemond
Last seen: 2 years 3 weeks ago
Question for the OP. Are you using the FET + 7135 Driver – 17mm – MTN-17DDm Product Code: MTN17DDm-NUV? This is my favorit driver, but being direct drive for high mode that would make it capable of delivering 10amps. This led is only good to 9.5amps.
gchart
gchart's picture
Yup, the one and the same. The LED can handle the amps, but it may be beyond the optimum range. I haven’t had a problem with it, but you could always use weaker cells to limit the amperage.
Edit: well, since I was working with a Convoy L2 (updated model) technically I used the 20mm version but it’s the same components just on a bigger board.
ZozzV6
ZozzV6's picture
Last seen: 1 week 5 hours ago
I have an L2 with an SST40 with dome and I’m curious about your numbers with dedomed version.
gchart
gchart's picture
Great question, but I dunno really. I have a meter now, but it’s still sitting in the packaging. And I sold that L2 at Christmas, so I can’t measure it now. But I have the parts on my shelf to assemble two more just like it. Hopefully I’ll be able to build & measure them soon.
ZozzV6
ZozzV6's picture
I have some SST40 leds so maybe I will try the slice and polish dedome method and try it in mine.
gchart
gchart's picture
Good luck, let us know how it goes
ZozzV6
ZozzV6's picture
My friend has 8000 grit sandpaper. I will borrow some from him. Smile
Barkuti
Barkuti's picture
Last seen: 2 min 44 sec ago
Side note: polishing the dome remnants after slicing it can or will ruin the underlying bond wires.
Cheers Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
ZozzV6
ZozzV6's picture
The SST40 survived well. but the SST20 leds died.
Barkuti
Barkuti's picture
Problem is that rubbing the sliced dome against sandpaper rustles the underlying bond wires. I can see the effect with my bare eyes. Did it to a 5000K XHP50A, the bond wires got all messed up and it just died. On another 4000K XHP50A did it more gently, but still something went wrong and upon heating up half the dies started turning off, an indication of certain damage to some bond wires.
It is just not worth it, just shim the emitter properly and cut the dome at two (180°) or three (120°C) different angles, just that. Do not worry if it doesn't looks perfectly flat, the emitter will work well. Polish it, and you take an unnecessary risk. Of course, you can also try to polish it very slowly and gently. Good luck in any case. Smile
Cheers Party
