Sofirn C8F host. 21700 C8F Available
1360 posts / 0 new
Yourrid
Yourrid's picture
Last seen: 7 hours 31 min ago
Probably the only manufacturer that sells hosts along side their own lights from day 1.
I’m super excited to buy more from Sofirn!
JasonWW
JasonWW's picture
Last seen: 4 hours 45 min ago
Dude, I didn’t even realize post #1 had been updated. That’s some nice pictures.
KSGER STM32 2.1S Soldering Station Videos - Review Soon
Convoy L6 thread with XHP70.2, Texas Avenger FET driver, Narsil v1.2 ramping firmware (old), lighted side switch, SMO reflector.
Supfire L5-S thread with XHP70.2, Texas Avenger FET driver, NarsilM v1.0 ramping firmware, 2 x 26350 cells, lighted side switch. My mini L6!
Thorfire S70S with MTN FET driver, RampingIOS (D4) and custom lighted side switch.
10 NarsilM user videos for BLF Q8, GT, GT70, GT Mini, Astrolux S43 and ROT66
Texas_Ace BLF Calibrated Lumen tube
Maukka Calibration Lights for DIY Lumen Measuring Devices - Headlight List with prices, specs and features
Jaxmnve M1 Stainless 10180 Keychain light Review  - Lumintop ODF30 Review - Sofirn C8F 21700 Teardown and Review, Sofirn SP33 v2 XHP50.2 Review - My Sofirn Q8 Results - Astrolux S43S 219C Test Results - Lumintop GT Mini Test Results
ZozzV6
ZozzV6's picture
Last seen: 10 hours 3 min ago
I update the OP every time I got something new. Also put it in here as a new post.
JasonWW
JasonWW's picture
I also didn’t realize this was your thread. Geez, I’m slippin. Sick
ZozzV6
ZozzV6's picture
Me too. I’m in night shift. Just building a Convoy L2 SST40 to a friend with a FET driver. Shorted the positive led wire soldering to the MCPCB screw. with driver hanging out and testing with power supply no problem. But when I assembled and the body get negative from batt and positive from the led wire…… just a flash and nothing… then I wasn’t able to click the switch. I know something is really bad so fast untwisted the tailcap. Got the magic smell but not smoke. Big Smile Fully charged Liitokala 26650 was warm. Driver spring collapsed fully with bypass so it acted as a fuse. Also the switch got stuck so I think the switch internal also melted and collapsed. I need a little break but an Eagle Eye X6 still waiting for build tonight.
teacher
teacher's picture
Last seen: 37 min 7 sec ago
Dang…. Sad .. Glad all you got was “the magic smell”. Thumbs Up
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
ZozzV6
ZozzV6's picture
Everything else survived. Big Smile Me, driver, led, battery. Just the switch and one spring gone.
People make mistakes. Even after a few hundred mods. That is why we need to design safe lights even if they are hotrods. To make sure a newbie wont harm him/her….self.
DB Custom
DB Custom's picture
Last seen: 4 hours 34 min ago
The Sofirn C8F is a unique light, I’d forgotten that the MCPCB is also screwed to the reflector with a single screw… this serves to keep the reflector from rotating on the MCPCB when the bezel is snugged down. There is a thin spacer that goes between the reflector and MCPCB but still, you can’t overtighten this screw or it will tilt the board and cause issues. Again, this one makes you do things differently, you have to put the wires on the MCPCB first, leave them long enough to attach to the driver then mount the driver. It’s all pretty tight, and tonight my fresh built Anduril driver didn’t like the switch. So I put in a new e-switch and this one has a little shorter actuation post, always something.
But I have it working, candlelight and everything looks good. Used the Samsung LH351D 5000K 80 CRI , an Nichia 219C 5000K 90 CRI and one Cree XP-L HI V3 3A. Beam looks good, color looks good, all in all pretty dang sweet. Smile
Definitely a challenge compared to , say, an Eagle Eye X6. Wink
Reduced exposure to show hot spot, it’s actually even a bit smaller than shows here but this was my iPhone 8 with manual settings…
And more proper exposure in a lower mode to show color…
Moon is 0.276 lumens
Default ramp ceiling in Anduril is 1376.55 lumens
Turbo is 2590.95 lumens
Not bad at all with the 22 ga leads and a small CaroBronze spring on the driver. I Like It! Big Smile
DB Custom
DB Custom's picture
The D1s that I took the Samsung emitter out of got my last Cree XP-L HD W2 1A emitter (W2 is rare) It’s “only” making 1346 lumens and I don’t know why, not going to look into it further tonight though. lol
DB Custom
DB Custom's picture
On the lowest setting, i8 at 40ISO, f/1.8 aperture, 1/873 sec exposure…
SKV89
Last seen: 1 hour 32 min ago
What is that yellow/greenish emitter on the top? The beam looks beautiful, no green at all!
DB Custom
DB Custom's picture
On top, the Cree XP-L HI V3 3A, bottom right is the Nichia 219C 5000K 90 CRI and bottom left is the Samsung LH351D 5000K 80 CRI.
This is looking at the emitters barely lit, combined output is just over 1/4 of a lumen, so the tint is not what you might would expect from a given emitter. Current to each one at this level is ridiculously low, barely enough to excite the phosphor.
The Cree is an HI, factory domeless… the other two have domes on.
I can take a shot with a much faster shutter of the emitters under more power but it shows the electronic shutter… I’ll see what I can do…
DB Custom
DB Custom's picture
Perhaps their truer colors, this shot taken with my Apple i8 using manual camera controls, ISO 20 at f/1.8 with an amazing 1/50,000 of a second shutter speed! Light is on the full 7135 chip, a default “On” setting in Anduril after a cell change. This is approximately 130 lumens, no filters…
DB Custom
DB Custom's picture
Ironically, these also cover 70, 80 and 90 CRI. Big Smile
SKV89
Thanks for the pic! Very helpful! I’m surprised the 3A tint is more yellow than the other two since 3A should be at or below the BBL. I’m surprised the 219C has less yellow than the Samsung because most of the 219c are a bit above the bbl.
adam7027
Last seen: 13 hours 58 min ago
Probably because this specific sample of Samsung LH351D is 80CRI, which means less medium blue, cyan, and bluish green is emitted compared to the 90CRI 219C.
Indeed, a lower CRI emitter can be seen as more yellowish (and same time, more purple) because of the cyan deficit. In these cases, being way under the BBL strengthens the purple look, closing in to the BBL or going above it strengthens the yellow look (but this is also dependent of the equivalent CCT).
The_Driver
The_Driver's picture
Last seen: 9 hours 52 sec ago
Will the 21700 battery tube have the same threads as the 18650 C8 tube? Probably not, but I want to make sure anyway.
ZozzV6
ZozzV6's picture
No. The head’s lower part also made bigger.
the4ds9
Last seen: 5 days 16 hours ago
This will be a cool flashlight to welcome and celebrate the year 2020. We are less than a year and a half from there. Star Wars IX is coming out on Dec. 20, 2019. We’re almost there gang!
JasonWW
JasonWW's picture
2020? It could be out in a few weeks maybe. IDK for sure, but not too long.
Bombay says about July 20th, but that seems too soon. I will not complain if it’s true. I would just like it tested and working good instead of it rushing for a fast release.
zeremefico
zeremefico's picture
Last seen: 2 hours 33 sec ago
Hi, great light!
Are there any plans for 21700, side switch, single led setup?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
ZozzV6
ZozzV6's picture
zeremefico wrote:
Hi, great light!
I tried to convince them but no answer.
contactcr
Last seen: 4 hours 59 min ago
zeremefico wrote:
Hi, great light! Are there any plans for 21700, side switch, single led setup?
Except for the side switch “Nightwatch EC21” is just that
ZozzV6
ZozzV6's picture
The side switch what he wanted first place. Except for the side switch there are thousands of options with tail clicky single led flashlights.
contactcr
There are also things like the MiniGT, etc which have side switches. It’s more rare to find 21700 tubes.
ZozzV6
ZozzV6's picture
That is true. But if somebody want modding the mini GT driver is glued and special. in a sofirn you can build what you want so I will keep pushing that idea to them Wink
Yourrid
Yourrid's picture
I just got my C8F host in from Mountain Electronics, man this is a great looking light Love
I have a question for y’all though. This is my first time installing a driver into a light with a side switch, so I’m wondering where the leads get connected for the side switch. Reading around I think this is correct.
Under the green circle it says “OTC,” but it didn’t come with that resistor. Is this the correct place for the e-switch leads? I’ve read you can also connect the + to the MCU #2, and the – to any ground. But the OTC pads are supposedly better to use. I’m fairly confident that was what Richard was explaining over on his thread here: Comment #7944
Also, the driver didn’t come with any of the resistors under the yellow circle. I complicitly trust that Richard left them off for a reason. Just out of curiosity, what are they for?
DB Custom
DB Custom's picture
R1 and R2 are typically the low voltage protection circuit. If you have Guppydrv or something like that which doesn’t use low voltage protection there’s no point in having those on there.
I usually solder one of the e-switch leads to pin 2 on the MCU. (The MCU is marked with a triangle or recessed dot at pin 1 , the board has an asterisk there, numbered 1-2-3-4 on the left in your picture, going around the clock to the other side is 5-6-7-8 with 8 being up on the inside) There is no “+” and “-” by the way, you’re just interrupting the circuit. The best ground (as if it mattered here, is the outer 3 legs of the FET, lot of space there anyway for a ground point, you could also use leg 4 of the MCU, or that OTC leg closest to the ground ring, just check for continuity with your multi-meter for ground.
DB Custom
DB Custom's picture
FWIW, under the green circle OTC means Off Time Cap, the brown capacitor. Above it, the smaller black component is a resistor that is used to keep spikes down, this helps keep the light from flashing when entering the FET mode.
Yourrid
Yourrid's picture
Dale, thank you so much for the info man! I was hoping to get this C8F together tonight, but I seem to be out of 20awg wire. 18 gauge fits, but 22 gauge is too big for the center hole on the driver. I definitely want the least amount of resistance on this powerhouse so I’m going to assemble it tomorrow when I get some 20 gauge. Thumbs Up
Edit: Reverse the 18/22 gauge wires and it’ll make more sense Facepalm
