Sofirn C8F host. 21700 C8F Available
1391 posts / 0 new
ZozzV6
ZozzV6's picture
Last seen: 52 min 38 sec ago
Jerommel wrote:
I suppose you could drill a hole for a switch in the C8F tail cap.
This is how it looks:
The tailcap bottom is 6mm thick so if you drill carefully you can fit a switch in there just need to keep a little ledge to fit the rubber button.
I think I will grind down the lanyard attachment thing and cut 3-4 mm ogg the bottom to make the whole light shorter about 9mm this way. Tha tailcap will be completely flat like an Emisar. maybe I will remove anodizing from tailcap and polish it and add stainless bezel in front
Jerommel
Jerommel's picture
Last seen: 14 hours 27 min ago
Look here for the SS bezels:
https://www.aliexpress.com/item/-/32843061651.html
2 pcs for €3.05 !!
ZozzV6
ZozzV6's picture
I made some more photos of the host. Uploaded it in a photo gallery. I will put it in the OP too.
My host doesn’t came with sofirn or C8F engraving. I don’t know if the others came with engraving or not.
The gallery has more. these are some teasing pics.
led4power
led4power's picture
Last seen: 7 hours 30 min ago
Reflector looks really nice and clean. Convoy/Simon should definitely make its own version of C8 triple.
ZozzV6
ZozzV6's picture
I’m happy with the sofirn quality so far. I don’t need to Convoy make the same thing.
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 hours 9 min ago
I got both of the Sofirn C8F’s and with the Led4Power LD-2 at 12amps, I am able to use both the push button and e-switch to (cycle) change modes, just added a lighted tail cap.
Maybe Simon could make it like this, It is really nice to be able to use both buttons, really more user friendly when you have both switches operable!
KB1428 “Live Life WOT
Keepitsharp
Last seen: 8 hours 33 min ago
I am expecting several of these hosts after liking my version 2 C8F from Sofirn. Have some XP-L2 5000k emitters and am looking, hopefully, for ramping drivers for this and, of course, a lighted switch would be very nice. Innocent
Any ideas or sources please? I am sure others would appreciate this as well. Have not seen driver options discussed here, though I may have missed it…
Thanks!
Jerommel
Jerommel's picture
I have no idea what i’m looking at here:
ZozzV6
ZozzV6's picture
I tried to show the rubber side button cover transparency. I putted on a flashlight lens and turned on. Wink
Jaded
Jaded's picture
Last seen: 10 months 1 week ago
Thanks. We appreciate the pictures, guys. My order is yet to arrive, so those close up shots are helpful. At least, they help us plan ahead and let us figure out the components we want.
Jerommel
Jerommel's picture
Aha, now i understand what i’m looking at. Smile
ZozzV6
ZozzV6's picture
And I’m ordered 2 of those cheap SS bezels. Smile Thanks for the link!
Jerommel
Jerommel's picture
Found these too:
https://www.aliexpress.com/item/-/32835936873.html
looks awesome with these:
https://www.fasttech.com/product/7989400
(especially in a Convoy C8 tailcap)
ZozzV6
ZozzV6's picture
A C8 is too heavy for this magnet to hold. Sofirn head even heavier because more mass in the shelf and reflector. I will measure weights later.
I like the stainless switch but I don’t have the equipment to make a nice hole in tailcap and good thread. If someone make it. It will be unique.
Jerommel
Jerommel's picture
Use some translucent rings and super glue. Wink
(should take a better picture…)
PS: Magnet is strong enough for this C8 with SS bezel.
Maybe not for the Sofirn triple.
ZozzV6
ZozzV6's picture
Nice job. Do you have some pics from assembly how everything fits?
Jerommel
Jerommel's picture
No, but i will make another one, i will take pics and post it.
ZozzV6
ZozzV6's picture
Thanks! I like the double lighted ring.
contactcr
Last seen: 5 hours 39 min ago
Well good news and bad news for me. Good news I have all the parts. Bad news is the Noctigon 32mm does not fit. It will not sit flush against the shelf. Bought the xp32 with LEDs already on so guess i’ll be learning to reflow LEDs on a triple Facepalm
Mike C
Mike C's picture
Last seen: 5 hours 58 min ago
I was wondering if them Noctigons would be a good fit or not. Now we know for sure. Thanks for the heads up.
gchart
gchart's picture
Last seen: 2 hours 31 min ago
That’s strange. Dale (DB Custom) used one in his (link) and I don’t recall him saying anything about machining the shelf. Granted, that was on one of the very first units before Sofirn changed emitters, used DTP, etc. Maybe they changed the shelf in the second batch.
DB Custom
DB Custom's picture
Last seen: 1 hour 1 min ago
I know I didn’t machine the shelf, I may have used a file to reduce the 32mm MCPCB slightly. Would have done that by hand, have done that kind of thing so many hundreds of times it wouldn’t be something I’d really remember doing.
I have a 12” double cut bastard file on my work table, I lay it on the edge of the table and run a round mcpcb (or whatever) vertically down the length of the file while giving it a bit of a turn, reset my finger hold and do it again, turning every time to maintain the circular profile. (Thumb and middle finger on the sides, index finger on top, pressing down… like a wheel but not rolling, just a slight turn every pass) Takes but a couple of minutes to turn a 32mm copper disc into a 31.7mm disc for an X6, for example. Also drill a hole through the center of the 32mm board, where the center XP pads are, to keep from getting the wires in a bind.
I used 18 ga leads and they fit in the cut-outs on the base of the reflector. As I recall I sealed them in Arctic Alumina Thermal Adhesive so they’d not short out.
Jerommel, that SS switch assembly lighted by blue is really nice! Smile
KawiBoy1428
I didn’t check the e-switch CF8 to see what it was, but the shelf on the Push Button CF8 is 30.5mm. But the reflector was almost a direct replacement for my Convoy C8 Triple SST-40 Optic build using “kiribu-ra’s” spacer…need to take 1.25mm off the back of the spacer, so the bezel closes up, otherwise NICE!
DB Custom
DB Custom's picture
Pretty racy looking Convoy you got there Scott! Wink
DB Custom
DB Custom's picture
Got a pair of C8F side switch hosts in the mail today. Cold and wet, they were! Must’ve been quite a trip getting here, the boxes had been wet inside the bubble wrap long enough to essentially disentegrate when I opened them to get the lights out. Nothing wrong with the lights, of course. Time to build one up and see how she be! Big Smile
DB Custom
DB Custom's picture
I had forgotten how tricky building one of these is! The copper MCPCB being screwed onto the reflector, then the reflector having the center screw to snug it down inside the head, with the side e-switch, a lot going on in a small space!
Used XP-L2 V6 5000K emitters, 22 ga wires, and built a MTN FET driver with ToyKeeper’s ramping firmware from last century. Smile
Grabbed a rested Sony VTC4 cell and saw 8.25A pull at the tail, with the cell at 3.7V! lol This should be interesting when the cell gets charged up…
Edit: On the fully charged VTC4 it pulls 12.15A at the tail for 3860.55 lumens out the front. Pretty decent, I’ll take it. Big Smile
DB Custom
DB Custom's picture
Replaced the tail pcb with a copper disc, soldered a heavy gauge berrylium spring directly to this disc. Then put 20 ga bypasses on the two like springs top and bottom. The result? Same VTC4 cell, fresh off the charger, 4115.85 lumens.
Now we’re talkin! Big Smile
Flashy Mike
Flashy Mike's picture
Last seen: 2 weeks 2 days ago
Nice. I’m curious to know how long it lasts until it get’s to hot to hold. Haven’t touched my host yet. Too busy with programming drivers …
DB Custom
DB Custom's picture
I held it for 3 minutes in a 73º ambient setting.
Mike C
Mike C's picture
I got six of these hosts to play with. The driver retaining ring’s inner diameter is a little too small for my double sided drivers though. I could file it out but I’m too lazy to do it six times, I’ll just design a new dedicated driver and let OSH Park take care of it Smile
