Sofirn C8F host. 21700 C8F Available
1397 posts / 0 new
ZozzV6
ZozzV6's picture
Last seen: 18 hours 35 min ago
Brainsick67 wrote:
Hmmmm..how do u check the amps?
Another light but you get the idea.
Brainsick67
Brainsick67's picture
Thanks..but doesnt help me..no offence..but not good at this..lop..i just have mine set at Voltage..
I'm ThatCrazyFlashaholic 67
ZozzV6
ZozzV6's picture
Show a pic of your multimeter and I will tell how to set it and use very short leads.
Brainsick67
Im insure how..never uploaded photo on here. Keeps asking for URL
shirnask
shirnask's picture
Last seen: 2 hours 42 min ago
Open an account at Imgur and post your pics there and link them
KawiBoy1428
KawiBoy1428's picture
Last seen: 15 min 47 sec ago
ZozzV6 wrote:
Mine with the stock Sofirn battery made 3100 lumens. I also noticed that it is creeping up. And mine draws 8,5A
I ope Sofirn take a look at the drivers. I told them there are some issues.
What did you get for IR on the Sofirn supplied battery Zozz?
KB1428 “Live Life WOT
JasonWW
JasonWW's picture
Last seen: 3 hours 28 min ago
Do you have a clamp meter?
ZozzV6
ZozzV6's picture
I need to check but if I remember correct it was around 40 mOhms
Brainsick67
This one. http://imgur.com/4TcGrXL
ZozzV6
ZozzV6's picture
turn the switch to the 10A position. 180° from this. And plug the red wire to the empty hole next to 10A position. Put the red probe to tube edge and the black to battery and then turn the flashlight into turbo and read the numbers.
BTW with long wires you will reading low numbers because at over 4-5A the wires act as a resistance in the circuit. So the best way to measure high power flashlights is a clamp meter.
Brainsick67
Ok thanks..i prob wont do it then.
LEDtec
I replaced the original MCPCB of my C8F 21700, with one I had purchased a few months ago from Sofirn on which I put 3x XP-L2 (UU640H) ,
Now I get almost 3300 lumens(@CRI90) , and almost 13A at the tailcap.
BOMBAY
Last seen: 1 min 18 sec ago
my c8f 21700 also has a brightness climb, but it does not bother me is a bit like HID
with the sofirn 21700 battery, I measured about 2,900 lumens
I also observed that the maximum power at the top of the ramp is a bit higher than the turbo with a double click
JasonWW
JasonWW's picture
Brainsick67 wrote:
This one.
If you are interested in measuring amp loads I would recommend a meter like the UNI-T UT210E for about $25-$30. Measuring the amp draw is a good way for people to compare outputs.
Nowadays we have homemade lumen tubes and integrating spheres to measure actual lumens.
Lightbringer
Lightbringer's picture
Last seen: 2 hours 43 min ago
Where you see ‘em for that little? Amazon has ‘em for 45, AX same, GB 54(!), nothing below 40.
I was meaning to get a clampmeter that could handle DCA, and this one seems to be pretty popular here, so…
ZozzV6
ZozzV6's picture
M4DM4X has coupon code for it from banggood.
Lightbringer
Kewl, tnx!
the4ds9
the4ds9's picture
We love it! Beer
contactcr
Last seen: 1 hour 5 min ago
We can use that debit card in Brainsick’s picture to buy new clamp meters for everyone. 12345678900000
ZozzV6
ZozzV6's picture
I checked the IR in a miboxxer C8 and in an Opus BT-C100.
The C8 measured 34 mOhms and the Opus measured 23 mOhms.
KawiBoy1428
Thanks Zozz, my SKY RC3000 measured 24 mOhms.
d_t_a
Last seen: 25 min 24 sec ago
KawiBoy1428 wrote:
ZozzV6 wrote:
I checked the IR in a miboxxer C8 and in an Opus BT-C100. The C8 measured 34 mOhms and the Opus measured 23 mOhms.
This is my result (lowest IR achieved after rotating the batteries and pressing the batt-IR check several times)
the4ds9
the4ds9's picture
Another thing I love about my Sofirn C8F 21700 is that it can run the cheap Tuofeng 18650 2600 mAh and still be very bright. The brightness with the Tuofeng batteries still reminds me of the Olight SR90 in terms of lighting up a room brightness.
Sofirn is number one for me. Cash Solid budgetlight. Above and beyond. Thumbs Up
the4ds9
the4ds9's picture
I had a chance to compare the Sanyo UR18650NSX 2600mAh against the LG MJ1 3500 mAh. The runtime is definitely solidly longer with the LG. This means that if I want long runtime at a good brightness level in my Sofirn C8F 21700 torch, I should purchase the Samsung 50E 5000 mAh battery which is currently $9.95 from Battery Junction or $9.99 from IMR Batteries.
Hope this observation helps.
JasonWW
JasonWW's picture
Ah, it’s good to see the 50E is now being sold at more places. Other good high capacity 21700 are LG M50 and Samsung 48G (the 50E is designed to replace the 48G).
the4ds9
the4ds9's picture
Thank you for making me feel like part of the group. Flashlight prices are out of control. Back in 2011, you could pay $334 to Amazon and have a pristine Olight SR90 in top quality casing delivered to your door guaranteed. The thing was 2200 lumens and most importantly over 100k cd throw, with long sustained runtime because of the 8 × 18650.
Sofirn is the only cutting edge LED torch technology that I can afford. I don’t think I could pay more than $300 and change for the biggest and baddest but that is what they are nowadays $500+. Plus they are not sold on Amazon, but Sofirn is sold on Amazon. God bless Sofirn. Thank God for BLF.
JasonWW
JasonWW's picture
I would say flashlight prices are falling left and right. New leds and new batteries are giving better performance for a fraction of the price compared to a few years ago.
The BLF GT is 1800 lumen and 1,200,000 cd throw and sold for either $120 or $160 depending on the group buy.
The GT70 is like 7500 lumen and about 600kcd and $220. Both are 8 × 18650.
Party Beer Party
DB Custom
DB Custom's picture
Last seen: 2 days 11 hours ago
That’s a nice thought Jason, brace yourself for the new wave of technology and it’s inflated price margin… Wink
JasonWW
JasonWW's picture
If it’s worth it, people will buy it. If not, it will sit in a warehouse.
Give me an example of what your talking about. Do you mean the laser excited phosphor mini throwers or something else?
the4ds9
the4ds9's picture
Thanks for bringing the BLF GT70 to my attention. I may take a risk and try it out, based on the numbers on paper and design. In the meantime, I will keep using my Sofirn C8F 21700. Beer
