Sofirn C8F host. 21700 C8F Available
1397 posts / 0 new
ZozzV6
ZozzV6's picture
Last seen: 14 hours 29 min ago
Then there is the SP33.
I talked Sofirn again. They told me that talk with the engineer and will think about the songle led 21700 version. I said that make it like C8F so same double switch just change the front end to single led.
JasonWW
JasonWW's picture
Last seen: 1 hour 28 min ago
Satan@103TFS wrote:
Hey Sofirn next let give us C8F 26650 and the single emitter throwy version either 21700/26650 .
Like ZozzV6 said, the old SP33 was a single emitter 26650 light. I’m not sure why they changed it to xhp50.2 with boost driver. Maybe low sales? It might have been better to have 2 seperate models.
Satan@103TFS
Last seen: 3 hours 7 min ago
ZozzV6 wrote:
Then there is the SP33. I talked Sofirn again. They told me that talk with the engineer and will think about the songle led 21700 version. I said that make it like C8F so same double switch just change the front end to single led.
That good I like the 2 switch with forward click tail of 21700 C8F , hope for bigger head (55-60 mm.) with XHP35 for better throw and please make the light switch to stay on as locator .
JasonWW
JasonWW's picture
Now your asking for a completely different light. Big Smile
You want Sofirn to make a light like the thrunite catapult v6 or lumintop odl20c, but with 2 switches?
Satan@103TFS
Yes that I mean Jason but with Sofirn price. Wink
LEDtec
I recently received 2 C8F 21700 hosts, along with a driver kindly sent by Sofirn, and today I found the time to assemble 1.
I used 2 pieces of 16AWG wire (about 4-5cm each), 3x XP-L2 V4 4500k 80CRI 3-step, and the Sofirn driver.
And I was really amazed by the result, I measured 17.8A max at the tailcap, with a 30T @ 4.2V
THANKS Sofirn.
P33
Last seen: 7 hours 2 min ago
That will be just under 5000 on-LED lumens, right? Crazy
contactcr
Last seen: 7 hours 37 min ago
Anyone know if the 21700 host will show back up in aliexpress store?
LEDtec
From a test to ceiling bounce, I estimate about 4700-4800 lumens.
P33
Not too shabby!
Tom E
Tom E's picture
Last seen: 6 hours 5 min ago
I modded up a C8F 21700 host with 3 351D 4000K 90 CRI's and also measured 17.8A at the tail! Mine does 4150 at start, 3750 at 30 secs, but that's not ANSI lumens, more like manufacturer lumens. Measured 33 kcd throw. I used 20 AWG LED wires (long to re-program), and swapped the tail bypass to 20 AWG.
I got one more 21700 host on the way (hope so), and got in 3 C8F 18650 hosts, 2 modded up.
One C8F with XP-L2 V6 5000K actually read 19.1 amps on a VTC5D cell, 5640-5050 lumens, 42.5 kcd.
I hope they get in more - doesn't sound or look good. They don't seem to sell the 18650 versions any longer as well.
ZozzV6
ZozzV6's picture
I forgot to mention:
Sofirn said they will make a single led Version 21700 C8.
It will be the same design and driver and firmware and double switch as the triple but with single led with smooth reflector. The led options not clear yet but XP-L HI is definietly on the list.
Satan@103TFS
ZozzV6 wrote:
I forgot to mention: Sofirn said they will make a single led Version 21700 C8. It will be the same design and driver and firmware and double switch as the triple but with single led with smooth reflector. The led options not clear yet but XP-L HI is definietly on the list.
That sound great … with bigger head for +150 kcd will be nice.
ZozzV6
ZozzV6's picture
No other changes just single C8 reflector. I tb nk it will be the same as C8T and C8A
Tom E
Tom E's picture
Hope not - hoping it has a side switch w/LED's..
ZozzV6
ZozzV6's picture
Tom E wrote:
Hope not – hoping it has a side switch w/LED’s..
Sorry if I was misunderstoodable. Reflector same as C8A C8T. Switches stay same as C8F 21700 dual switch with leds.
Sofirn
Sofirn's picture
Last seen: 5 hours 17 min ago
How many people like C8F with 3* SST20 4000K 95CRI?It will be quicker and easier.
I know some say a single XHP family + bigger head + 21700 tube or 26650 tube light gives 15k+ cd, it’s a new light which takes longer time to fulfill.
Furthermore, there is already a light such as thrunite Catapult V6 like that, how could Sofirn makes it better?
Note:
If you guys want tell new ideas for Sofirn light, please just PM me, but contact aliexpress sales only for order related topics. Simple and clear communication helps us making acurate plan.
d_t_a
Last seen: 57 min 58 sec ago
Note:
I think quite a number of people have modified or built their Sofirn C8F to have 3x Samsung LH351D (4000K 90CRI or 5000K 80CRI), maybe could also have that as an option?
skinny_tie
skinny_tie's picture
Last seen: 20 hours 59 min ago
I think both the SST20 4000K 95CRI and the LH351D 4000K 90CRI would be a great emitter choice for the C8F. I’m weighing up which of these two options to put into my own C8F.
I can’t say I’d defiantly buy another C8F just because they became available with SST20 4000K 95CRI emitters, but I would choose the SST20 over the current XP-L.
contactcr
3x white flat LED since you guys like cool white so much. Stand out some, Nightwatch just released what you are proposing anyways.
SKV89
Last seen: 53 min 33 sec ago
Yep I have the Nightwatch NA40 SE with SST-40 emitters and it measure 3,970 lumens at 1s. I love the usb-c recharge being separate from the head so you can swap the driver and still retain usb recharge. They are now offering SST-20 3000k and 4000k option. The SST-20 3000k they are using has a very good below the BBL tint. I think it is most likely the HD2 tint bin.
Sofirn, do you have any idea what tint bin and flux bin you are getting with the SST-20 or LH351D?
Also putting in the CSLMN1.TG or CSLPM1.TG in the C8F would be good. Usb-c recharge would be very nice to have.
Anthon
Last seen: 59 min 10 sec ago
xpl hi makes ugly rings around the hotspot
I haven’t tried with sst20
I put 3 LH351D 4000k in mine and the overall result is great, I love the tint, and the rings can only be seen when pointing to a white wall (the rings exists also with the stock leds)
pc_light
pc_light's picture
Last seen: 2 days 13 hours ago
I liked SSt-20 4000K cri95 so much I built my own from 21700 host!
… oh and added SS bezel too.
Seeking the light.
contactcr
Yours looks way more centered than mine. I used the older 18650 host and did 3x SST-20 4K sliced dome. I would probably leave dome on if I did it over again but I was re-using LEDs from another build.
pc_light
pc_light's picture
@Contractcr, centering rings did all the work, ALTHOUGH I did have to slightly widen the MCPCB-to-Reflector screw hole slightly (~0.4mm) because it was not aligned with reflector (thanks to DJozz for first pointing this out.)
Hopefully Sofirn can correct this problem and/or improve QC.
Seeking the light.
Anthon
Could you post a photo of the beam in a wall?
netprince
Last seen: 12 hours 59 min ago
pc_light wrote:
I liked SSt-20 4000K cri95 so much I built my own from 21700 host! … oh and added SS bezel too.
Nice build.
pc_light
pc_light's picture
Don’t know if this helps with what you need to see but here ‘ya go. Both about 4-feet from an off-white wall.
I don’t have a reflectored triple XP-L Hi for comparison (I do have TIR triple but that’s too floody), so I grabbed a single reflector XHP35 HD for comparison.
Haikelite SC26 w/XHP35 HD warm/neutral for comparison (on Left), Sofirn C8F w/SST20 4000K (on Right);
FWIW, at longer distances my C8F config continues to appear even tighter (~30%) than my SC26.
EDITED – added a short distance beamshot
Both about 40-ft from a white fence
Seeking the light.
Anthon
!{width:80%}https://imgur.com/rH5jWrs.gif!
Thank you, I wanted to see if the beam was clean
With XPL HI there are ugly rings around the hotspot, but your beam appears clean
blueb8llz
Last seen: 14 min 28 sec ago
[quote=Sofirn
Note:
If you guys want tell new ideas for Sofirn light, please just PM me, but contact aliexpress sales only for order related topics. Simple and clear communication helps us making acurate plan.[/quote]
Easy. Make turbo in the mode sequence and so that turbo can be memorized.
