Enogear AA Stainless Steel (AA/14500)
311 posts / 0 new
shirnask
shirnask's picture
Last seen: 1 hour 7 min ago
14500 is all that I have used in mine – no problems
toddcshoe
toddcshoe's picture
Last seen: 8 hours 51 min ago
I have never run mine on anything but 14500. Never a single problem. Think I tried a NiMh in it one time just to see the difference. Worked just fine. Just down on brightness a little of course. If it’s bright enough for you with NiMh then buy a pack of Eneloops and turn off all the lights in the house tonight. Use the flashlight, and flashlight only as your only means of illumination. Tail stand it for taking a shower or using the facilities. Tail stand in the kitchen for cooking. Just use it for everything you do for a whole night. I have never made it a whole night. The kids yell at me and the wife calls the doctor and he shows up with needles and then next thing I know I wake up the next morning. I think my wife is pulling a fast one on me. Not sure though.
"Everywhere I go, there I am"
DB Custom
DB Custom's picture
Last seen: 6 hours 35 min ago
Y’all got me to look into EnoGear and I bought the little 18500 Brass Beauty. I had modified it with an X6 Bistro driver and XP-L HI emitter for some 1300 lumens but a friend was wanting me to modify his and he was wondering how the SST-40 would perform in it, so this afternoon I stuck an SST-40 in mine, pulled the cheap switch and put in a mini Omten and soldered the small berryllium spring to the switches contact pad.
On moon it makes 0.61 lumens, on Turbo it makes a whopping 2350 lumens from a flat top Efest 1000mAh 18500 cell. Big Smile
Oh, and it get’s hot. Really hot. Really quick!
toddcshoe
toddcshoe's picture
Nice. I was thinking of getting that light as well. How does it perform in stock configuration? I have a few of their lights. The Stainless AA is a great little light. The Titanium 18650. Not so much. It’s begging for a modding.
LightUpTheDark
This screams buy me…. heck for less than a US Jackson and in stainless steel… but 2 months wait..hmmm I’ll think about…
I’ve got a thrower, a flooder, and an EDC too. Still looking for a bigger thrower, flooder, and a new EDC, give or take a few. I’m a flashaholic.
toddcshoe
toddcshoe's picture
Got mine in three weeks but it seems some people are waiting that long. You should order one. Even if it takes 2 months you will most likely forget about it after a month and then a month later you will get a nice surprise in the mail. Smile
DB Custom
DB Custom's picture
Stock it has L-M-H-Strobe-SOS like most Chinese lights. Makes around 780 lumens on an Efest 1000mAh 18500. Very compact build, brass pill with a very thin retaining ring for the driver. The brass pill is hollow, has a wider shelf than most of this type though, so I re-flowed a copper MCPCB with DTP directly to it and it works quite well.
I think the material is a type of bronze as they don’t really blacken like brass would, my wife has carried the 18650 version in her purse for years now and it still has a golden look to it, so all in all it’s a pretty nice light that holds up well. It’s also a favorite of ToyKeeper’s. Wink
This is one that would fare well with a Biscotti driver from Simon…
LightUpTheDark
Pulled the trigger and bought one. Now for the wait… Will report back when I get it….plan to run it on NiMh first (IkeaLoop 2540 mAh).
toddcshoe
toddcshoe's picture
I think you will be happy with it. Still works very well on NiMh.
Nicolicous
Nicolicous's picture
Last seen: 17 hours 29 min ago
Received my copper AA light two weeks ago. However I’ve been sick with flu so I will need time to do a review this coming weekend.
stay tune and be patient Big Smile
Nico -.-
SKV89
Last seen: 1 hour 20 min ago
Are you going to try putting in a 14500 cell? My genuine Sanyo 14500 fried it in a few seconds.
ChibiM
ChibiM's picture
Last seen: 9 hours 30 min ago
Maybe people should post some pictures of the driver.. Maybe we can see a difference between the ones that can handle lithiums, and the ones that can't...???
toddcshoe
toddcshoe's picture
ChibiM wrote:
Maybe people should post some pictures of the driver.. Maybe we can see a difference between the ones that can handle lithiums, and the ones that can’t…???
I can do that. Kinda bound up today with stuff to do but, this evening I will take mine apart for a few pictures.
Henk4U2
Henk4U2's picture
Last seen: 6 hours 43 min ago
Apart from some design flaws I really liked the little light. The head is screwed to one side of the pill, and the body to the other side of the pill. The PCB can not be fixated on the pill. A loose centering ring around the LED has no control over the TIR lens. One could say that things are pretty wobbly on the front side of the light. So it was quite possible that the LED was already damaged when the light was assembled. Caused by a misalignment of LED and TIR.
I wanted to give it one more shot. So I ordered some LED’s from FT. These arrived three weeks later. This time I put in a XP-G3 S3-1A and glued the centering ring over the dome. Then is was time to screw in the pill. I made slots in the pill, and put a drop of glue on the threads on the frontside in order to screw the pill really tight into the head. All trial and error, of course. Gave the threads at the backside of the pill an ample dose of grease. Put in an XXX Eneloop. And presto, fiat lux! So the driver was still OK. After a few minutes I put in a 14500. And that also went OK!
ATM the light is on (medium), with a 14500, tail standing on my desk. And it is getting luke-warm. That’s all.
I think the LED was pretty much DOA when I fired it up first time. Let’s see how things work out from now on.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
LightUpTheDark
It’s beginning to appear as if we are basically buying a nice stainless steel AA host rather than a actual light at the rate of these reported failures or bad QA/QC in the light engine department (LED, Driver, head assembly).
pennzy
pennzy's picture
Last seen: 5 hours 30 min ago
Seems like luck of the draw . Mine has been ok with 14500. Hasn’t been used much though .
Geuzzz
Geuzzz's picture
Gave my enogear some colouring, posted it in the “what did you mod today thread”. Think I will get some more to play with.
http://budgetlightforum.com/comment/1338987#comment-1338987
SKV89
SKV89 wrote:
pennzy wrote:
SKV89 wrote:
I put a EVVA Sanyo 14500 800mah protected cell in there and fried it Facepalm
It started flickering and just turned off. Now even with AA eneloops it flickers like mad and turns off.
That’s not a good thing . Let us know how CS is.
They agreed to ship me the replacement head. Will probably have to wait a month for it to come.
It’s been two months already and I still haven’t received the replacement head. Jackie just ignores my emails now. Crying
Update: Got this email from Jackie:
_I must appologize that we forgot to send out the head part.
Now we will send you a new flashlight registered post . Sorry for my carelessness.
Do you like to use 14500? If so , we can send you 14500 USB version to try. It’s good_
toddcshoe
toddcshoe's picture
Jackie really is good people. I think he gets overwhelmed at times and has a hard time with shipping. I in no way think he would do you wrong. I understand it’s quite aggravating at times with the speed of the transaction. I hope you are eventually happy with your purchase.
LightUpTheDark
Finally received mine in the mail on Friday. Photos don’t do it justice. It feels good and looks good in hand. One of the best tail switches I have used in a while (Good job Jackie at Enogear). It is the shortest AA light in my collection.
Almost looks like it is a Poor man’s version of a Haiku (it is a budget stainless steel light, afterall)…. I was hoping the head screwed into the body a little more (like another 2mm, or at least another 1mm). The exposed brass could compromise the moisture proofness of this light.
Overall I like this light and think it is a nice light for what I paid for (less than $15).
Geuzzz
Geuzzz's picture
Congrats LUTD. It really is a nice light. Still use mine regularly and probably are going to order an other one to mod.
LightUpTheDark
Been EDC’ing mine during the day (IDEAloop 2450 mAh) and using it as a “ambience” night light (joule thief – AA Alkaleaks from kids toys that have less than 1.2 volts) to keep eyes on my two little boys. I’ll wait for more reports and reviews before throwing in a 14500. The knurling is just right aggressiveness (it’s there but doesn’t bite too much??). In comparison, my Eagtac D25A Ti Clicky is on the aggressive side.
Henk4U2
Henk4U2's picture
Has been my primary EDC ever since I revived it. Four weeks on 14500 batteries, and no problems.
pennzy
pennzy's picture
Mine has been fine for awhile with 14500.
SKV89
Ever since I burnt the driver in my Enogear AA by using 14500 batteries, I requested a replacement head from Jackie Zhang at Enogear. It’s been several months and nearly impossible to an answer from him so I thought it was a goner. However, several months later to my surprise I just received a brand new entire AA flashlight (not just the head) and also a 14500 usb rechargeable version for free. I took lumen measurements with my TA lumen sphere calibrated using Maukka calibration lights:
Enogear AA 163 lumens
Enogear usb recharegeable 14500 259 lumens
Enogear AAA 123 lumens
The AA version has the same nice rosy 4000k tint from the last batch making it a perfect EDC for use inside the house. However, this time the AA version doesn’t turn on when I insert 14500 cells. But I rather it not work with 14500 then burn the driver running on 14500 like the previous one I had. The 14500 usb rechargeable Enogear does not work with AA batteries. The tint is also noticeably cooler and whiter with much more noticeable tint shift and not as rosy. The tint is no where near as nice as the AA version but it’s still not bad. The AAA version appears warmer than the AA version. Probably 3500-3800k and not as rosy as the AA version. However compared with the 4000k 219C Reylight, it is more orange and not as yellow so it is still a decent tint. I’m actually surprised the AAA version can get 123 lumens with such warm tint, which makes this one of the brightest NW/WW AAA flashlights in existence. The only thing I don’t like is that it goes from Hi – Med – Low, whereas the AA version goes from L – Med – Hi.
I highly recommend anyone looking for a budget, yet nice AA light consider the Enogear AA stainless steel flashlight. It also makes for a great gift.
ActiveAl
ActiveAl's picture
Last seen: 1 day 16 hours ago
SKV89 wrote:
I took lumen measurements with my TA lumen sphere calibrated using Maukka calibration lights: "Enogear AA":http://www.enogear.com/pd.jsp?id=81#_pp=0_455_5 163 lumens "Enogear usb recharegeable 14500":http://www.enogear.com/pd.jsp?id=258#_pp=0_455_5 259 lumens "Enogear AAA":http://www.enogear.com/pd.jsp?id=257#_pp=0_455_5 123 lumens.
 Thanks for this well written post. The links made it easier to follow exactly what you were talking about. Would it be possible to get TA lumen spere measurements on the AA Stainless Low and Med modes? Are you using alkaline, primary lithium, or Ni-MH batteries?
Are the Maukka calibrations lights worth the investment? Thanks!
I'm still waiting on my two Enogear AA Stainless lights ordered a month ago (July 11th)!
SKV89
ActiveAl wrote:
SKV89 wrote:
I took lumen measurements with my TA lumen sphere calibrated using Maukka calibration lights: Enogear AA 163 lumens Enogear usb recharegeable 14500 259 lumens Enogear AAA 123 lumens.
I’m still waiting on my two Enogear AA Stainless lights ordered a month ago (July 11th)!
Enogear Stainless AA using Eneloop Pro
Low = 9 lumens
Med = 53 lumens
ActiveAl
ActiveAl's picture
Enogear Stainless AA using Eneloop Pro Low = 9 lumens Med = 53 lumens
Thanks again! Looking forward to receiving mine!
Geuzzz
Geuzzz's picture
Received a new SS enogear. Again very nice. Only this time no 14500 support and no clip.
Nihm only is fine for me with this light, but I do need a pocketclip. I contacted Jackie from enogear, will see what happens.
Anyone got a good source for ss pocketclips as backup?
TheOnlyDocc
TheOnlyDocc's picture
Some of their light are really beautifull! The 14500 Brass & Copper lights. And especially the TC8 Titan is a absolut beauty (i do not need another one, I do not need another one, i do not need another one. My new mantra, but unfortunately it is not working most of the time Ughh ).
My question is, if there is a driver out there that would run with Anduril and AA & 14500 or AA only (for the Enogear Stainless Steel AA light)? Because the original driver with a lot of PWM flickering and this beautifull mod spacing is absolut no option!
We have 2018! ! ! And you still see a lot of lights from 5-300$+ with: lo-mid-high-strobe-sos-becon (even Nitecore and other expensive Brands).
If you check reviews out there for some of the new BLF lights with Narsil you will find that they all have one thing in common. All are praising the UI. Easy for Muggle and “all you need” for enthusiasts.
If i buy a light today 95% of the time i am checking if there is a Narsil/Anduril compatible driver out there. I did driver/emitter swaps in the past to hotrod lights. ‘Today i do it most of the time to get a UI that makes a light more usefull and userfriendly.
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
