New Sofirn K6 – [NO LONGER ACTIVE]
121 posts / 0 new
Persechini
Persechini's picture
Last seen: 3 weeks 1 day ago
no problem
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
leaftye
Last seen: 1 month 1 week ago
Lightbringer wrote:
leaftye wrote:
4 emitters aims it at the Q8, and that’s a battle it’s going to lose. 6 emitters might be 50% better on paper, but barely perceptible by eye.
Bah. Too many emitters on a crowded reflector means that most of the reflectorlets will have so many cutouts on the side as to make them more for flood than throw.
I’d say stick with fewer but intact reflectorlets.
That’s why I suggest eliminating the reflectors and using Carclo optics like the Emisar D4 has, although to fit it’d have to be the 16mm 3 emitter version like in the Convoy S2/S3 triples. Other than parts, all it needs is a spacer, and the machining on that could be kept very simple.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
PBWilson
Last seen: 1 hour 24 min ago
I think Sofirn adding a larger light into their lineup is a good idea.
That said, I think differentiating it from the Q8 is a wise idea.
I love my Q8 lights and use them every chance I get but they’re on the large size. If Sofirn chose a slightly smaller (3×18650) size, it might be just that much more easily carried.
To piggyback on other’s ideas, I like something different in the led department, with a warmer to neutral tint with a nice balance of flood and throw. How that is done is up to them or others with more experience than I have.
Ramping would be great, but I personally wouldn’t need all the bells and whistles that the Q8 has. I leave it in ramping and love it that way.
All said, I’d love something a little different than the Q8, perhaps a little smaller and simplified for an even more affordable cost. Not sure if Sofirn is looking that way, but that’s my $0.02.
I’d also like to be considered for testing out a prototype.
Serp
Serp's picture
Last seen: 1 week 1 day ago
In 6 LEDs there is no practical sense. Blinds close. In the distance it shines badly.
I agree with the proposal to make a normal deep reflector for 3 LEDs. If you want a very large power – put XHP50.2
Need 3-5mm base with a direct heatsink to the case.
Do not do another skyrayking. There are already so many of them on aliexpress.
Make a cartridge for 4 batteries, buck driver for xhp50.2@12v
Look at Niwalker MM20EB
kiriba-ru
kiriba-ru's picture
Last seen: 7 hours 17 min ago
Lightbringer wrote:
kiriba-ru wrote:
Change this f#cking SRK style extruded tube with simple tube with big bore inside. With parallel connection it will allow to use 3×21700 or 4×18650 with same tube.
Big-bore tube with a dummy spacer to keep the cells properly positioned? Yeah, that sounds good, and a contact ring for the (+) ends is easy, but how would you position the springs for the (-) ends? Especially 3 vs 4?
You dont need any spacer. Maybe just solid central rod with thin tube for 21700.
Yes, I dont have decision for negative end springs. So let it be 3×21700.
Need a vlogger for machine accessories reviews
Jaded
Jaded's picture
Last seen: 3 weeks 2 days ago
I would like to see another successful triple design from Sofirn. IMHO, they did a solid job on the C8F. I think a Q8-inspired, C8F hybrid has a good potential, provided the design is nailed right. I think a triple design would make a good sweet spot. Plus, the cost–performance ratio would be desirable, as far as Sofirn is concerned, which means better pricing for the K6. By triple design, I mean three (3) strong LED emitters that can really deliver. As suggested above, XHP 50.2 makes sense considering the cost. The only problem, I think, is containing the heat. Maybe three (3) XHP 50.2 in 6-volt configuration at half of their max forward current?
Also, it would be superb if they could make the K6 host available for sale, in the same spirit and continuing the tradition of their C8 versions.
MascaratumB
MascaratumB's picture
Last seen: 2 hours 43 min ago
Suggestions above added! Wink
BTW, seeing some suggestions, I remind that Sofirn has a 3×18650 / XHP50 flashlight, reviewed here by Lexel .
Maybe this helps on thinking the design/functions of the K6 as well Wink
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 ///
 Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7   TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
 MY GIVEAWAY (FW3A)
suratyu
Last seen: 1 day 16 hours ago
Interested I want 3 xhp70.2 emitter and 4×18650
MascaratumB
Suggestion added Wink
 MY GIVEAWAY (FW3A)
Andybibbville
Andybibbville's picture
Last seen: 1 hour 45 min ago
Interested I want 3 xhp70.2 emitter and 4×18650.
John 12:46 “I have come into the world as a light, so that no one who believes in me should stay in darkness.” Genesis 1:3 And God said, “Let there be light,” and there was light.
MascaratumB
Suggestions added!
BUT:
PLEASE NOTE that this is NOT a groupbuy !
This is a discussion thread about the possible specs of the new Sofirn model!
I listed your names (suratyu and Andybibbville) under the interest list for reviewers/testers, not for a “group buy!!
 MY GIVEAWAY (FW3A)
PBWilson
I had forgotten about that.
After re-reading the review, it might be a worthy venture for Sofirn to address the shortcomings and produce a great performing light, even if they go with a different platform (4×18650 and different emitter setup).
I wonder what pricepoint they’re going after. If it’s going to be less expensive than a Q8 or similar 4×18650 lights that have been released recently, what options are they willing to lose? Simpler UI? Less machining? Less involved emitter setup? No spring bypass?
I’d say that dealing with heat and having an up to date UI are the most important features. Ramping is popular right now and I’ve got four lights with it and don’t really want anything else. I love my D4, but it makes me a bit nervous with the amount of heat on tap and the risk of melting/burning something (especially me!). XHP70 emitters put out a lot of lumens, but dang they get hot! I know practicality isn’t on everyone’s agenda, but I’d rather have a light that put out a good amount of lumens with a good balance of throw and flood instead of a hot rod. Making it moddable (no glue!) would satisfy those who want to tweak it and still keep it usable and safe for those who don’t.
Since Sofirn came on the market as a budget priced light, are they going to follow that model or is this going to be in the $80-$100+ price range? If it’s going to be less expensive, drop any ideas of changing ports and box candy. A few extra o-rings should do it.
MascaratumB
Comments and questions added Wink
 MY GIVEAWAY (FW3A)
MascaratumB
NOTE
To the members that have already posted and that may post from now on, please do not update your previous posts if I already added the given suggestions.
You can “quote” yourselves on a new post and add the information there!
Or, if you want to update/edit the posts, please make a “EDIT” note so that I can easily spot what you’ve written recently!!
The only posts I wanted to be continuously updated/edited are posts #1 , #2 and #3, where emerging information is being added from the member’s posts or from other relevant things for the discussion/organization!
Sorry folks, but it is better for me to follow your suggestions this way! I hope you understand! Blushing
Thank you Glasses
 MY GIVEAWAY (FW3A)
Jerommel
Jerommel's picture
Let me show you why i think 7 is best:
It uses almost all of the front surface, without dramatic cutting of the cups.
So no dramatic petals in the spill and decent throw.
(Yeah, i photoshopped it myself, couldn’t find a suitable picture…)
The difficulty with XHP LEDs is the voltage.
You’ll need expensive buck or boost drivers.
The .2 versions of these LEDs have some serious tint shift issues in aluminium reflectors.
You need more complicated battery contact boards too.
I don’t know what Sofirn wants to make, but it looks like a simple 1S4P battery set up, they’re thinking of 6 LEDs.
So why not 7? Smile
Either way, you don’t have to have a buck or boost driver to drive multiple LEDs in parallel.
I do hope they will choose a current limited FET driver though.
But this light would be awesome with 219C, but the beam pattern and tint shift problems would be better with TIR optics.
If they want to go for BIG output, they should use the new Luxeon V LEDs, have them run on 4.5 Amperes each, which means 31.5 Amperes in total, divided by 4 batteries is 7.875 (let’s say 8) Amperes per 18650.
Shouldn’t be a problem. Smile
Luxeon V is quite good in regular aluminum reflectors.
And with their low Vf (forward voltage) you can run them current regulated for a good part of the battery charge, unlike with FET DD drivers (which is why i don’t like DD drivers, they’re actually not even drivers…)
understand this:
FET DD driver lights usually have high Vf LEDs like XP-L and XP-G2, because they don’t draw too much current on a freshly charged cell.
Batteries and low Vf LEDs can get into trouble with DD drivers, unless you use lossy springs and thin wires, which is just a lame solution.
I don’t know if Sofirn is into driver design, but it’s only a few more parts from and FET DD driver to a FET regulated driver.
Probably they want a LED board with all LEDs in parallel config, only need two fat wires (16 or 18 AWG should do).
But i’m no driver expert either..
2Q19
Jerommel
Jerommel's picture
With 7x Luxeon V it is quite possible to reach 14000 Lumen (before optics) on freshly charged (high drain!) cells.
2Q19
RobertB
RobertB's picture
Last seen: 5 hours 6 min ago
Here’s a good example. DQG Tiny 26650. Even though it’s TIR
Jerommel
Jerommel's picture
Thanks.
But the DQG leaves a lot of space unused.
I should have looked harder though Facepalm
That’s from Sofirn store on AliExpress…
So they have the reflector already. Thumbs Up
The one with 8 LEDs looks well spaced too.
You could run LEDs in pairs or fours with that.
With 8x Luxeon V it’s easy to get 8000 lumen, regulated for the most part of the battery charge.
Turbo could be 16000 lumen. Silly
2Q19
Jerommel
Jerommel's picture
Hmmm… Quite nice i.m.o.
(searched for “8T6”)
2Q19
Gerrit
Last seen: 11 hours 16 min ago
why not what looks like the acebeam x80 configuration?
Look at https://www.youtube.com/watch?v=fhqgBXU7G8I
Created by scannerguy1968
Jerommel
Jerommel's picture
There’s not much left of the reflector cups, and with those big LEDs, it’s flood only.
But if that’s what you want, sure.
2Q19
ZozzV6
ZozzV6's picture
Last seen: 5 hours 34 min ago
I also vote for 7 as most efficient reflector or TIR lens usage. Then don’t need to push every led so hard and they can work more efficient.
And I think battery carrier is better than fixed tube because it is easier to mod 2S2P and replace the leds with 6V ones
Andrew_Debbie
Last seen: 1 week 5 days ago
Thank you Sofirn for the opportunity to make suggestions.
The BLF Q8 UI is too complex. Three weeks with the Q8 and I still need to refer to the documentation. I’m about ready to reflash a cut down version of the firmware.
The K6 is a better balance between complexity and flexibility. I especially like the side switch battery indicator. The lack of strobes is another plus.
I’d like to see a 90+ CRI 4500K option.
Batteries should be 18650 or 26650. I don’t want to invest in another battery size.
4× 18650 is a bit too fat. How about 2 × 26650 in parallel? An oval cylinder battery tube might be easier to hold.
Is a single emitter possible? If it is I would prefer a single emitter in a flood pattern.
MascaratumB
Hi there and a Happy 2018 for all of you Wink
Thanks for the suggestions, only today I had the opportunity to update the post #2 with your words! If I missed something important, please let me know. Thumbs Up
There are some things that are “shorter” others that are longer on the suggestions, because it is hard to understand if I cut the text in pieces. So I copy and paste more text!
Tracy Wan and Cissy are probably following this thread, so despite the texts are being “cut” they are able to see what is being said along the thread.
I don’t know (yet) if there is a deadline to give the suggestions. So, feel free to give your contribution here!
Also, please remember this if you want to update your posts Wink
Next updates, if needed, will probably arrive later today or tomorrow!
Best regards to all! Thumbs Up
 MY GIVEAWAY (FW3A)
Lightbringer
Lightbringer's picture
Last seen: 49 min 9 sec ago
Yes, please, for the love of God and all that’s Holy, NO STROBES.
Barkuti
Barkuti's picture
Last seen: 1 hour 25 min ago
I believe Sofirn got a reel (or more) of XP-L emitters and wants to put 'em to good use. You know, the ones used in their recent C8F. Other emitter types could also be utilized, of course, but I think they'd like XP-L setup for the main breed.
Proposed emitter setup: 7 units, all regular circular reflectors, center plus six surrounding. No reflector bastardization with great use of available area. Sort of what Jerommel said:
I like properly designed regulated drivers, a great driver allows for better product customization. My take is for a boost driver with 7S emitter output voltage window (at least up to 28V) and 3S/4S input voltage, with 4S_18650 and 3S_21700 battery carriers. Driver can be designed to detect battery carrier type and adjust battery input voltage cut-off accordingly: down to ≈11V for 4S and down to ≈8V for 3S, for example.
Since all is in series current losses are minimized, allowing both high efficiency and the possibility to implement a ludicrous beam mode by pumping ≈6A to all XP-L emitters in series. For high bin XP-Ls this would mean 14Kilolumens before stepdown (or fire Big Smile in the forest).
Cherry on the cake is the ability to (factory) switch emitters with minimum to no driver reconfiguration.
Cheers
Sofirn C8T and C8F reviews of mine
PMme for a tip Wink thanks
MascaratumB
Comments added Wink
 MY GIVEAWAY (FW3A)
JudgeDredd
JudgeDredd's picture
Last seen: 6 months 22 hours ago
If they agree with 7 emitters, please remind them to change the name to K7! Big Smile
MascaratumB
 MY GIVEAWAY (FW3A)
Lazy-R-us
Last seen: 1 day 13 hours ago
Let me preface this by saying I don’t know what I’m talking about. I’m still working on fully understanding how different LED’s create different patterns of light. That said…
Would it be possible to make a light with Jerommel’s 7 LED configuration and have the center LED be a thrower, and the six surrounding LED’s be floods? Perhaps with independent control of them. Or is this a bad idea given the way lights get used in the real world?
Lazy-R-us
