Tell Us When Your GT Arrives (or is on the way)! [Formerly: BLF GT DHL Delivery Logistics Discussion]
329 posts / 0 new
teacher
teacher's picture
ARsee wrote:
Just in from DHL. My 2nd GT w/batts arrives Monday. Thumbs Up
Good deal….. looks like I was wrong about them both coming at once. Facepalm
Oh well… Big Smile
Glad your getting them.
On another note. Are you going to take your bezel off to do your ‘LED burn in’ OR just split the head, exposing the LED (but leaving bezel, lens, & reflector intact??)
I am gonna do it the second way mentioned.
ARsee
ARsee's picture
I was eyeballing the area in front of the switch. I noticed a little o-ring grease and thought about taking it apart there. Honestly, I think taking it apart there is a better approach, and leave the reflector alone.
While I was at it, the carry strap attach point on this one is sitting at about 11:10 . So while I had it apart I could maybe align it a bit better. The connections don't need to be so dang tight anyway.
Time for me to get outta here. I been awake for 22.5 hours!!
Gj
Gj's picture
Last seen: 9 hours 50 min ago
I didn’t receive any text, email, or phone call. GT was here when I came home yesterday. (DHL w/ cells)
Everything looks perfect except for a hard to turn rear lanyard ring, perhaps need to re-seat and lube the o-ring.
It’s too darn cold to go outside, but it sure looks impressive indoors. Big Smile
teacher
teacher's picture
While I was at it, the carry strap attach point on this one is sitting at about 11:10 . So while I had it apart I could maybe align it a bit better. The connections don’t need to be so dang tight anyway.
Yeah… I’m thinking that will be the better option. That way the reflector, lens, & bezel can remain intact as a unit.
If you figure out how to change the alignment of the front strap attachment point, do let me know. I do not see anyway at all to do it.
Mine is at 6:30……. Facepalm .. Wink
ARsee
ARsee's picture
teacher wrote:
Yeah... I'm thinking that will be the better option. That way the reflector, lens, & bezel can remain intact as a unit. If you figure out how to change the alignment of the front strap attachment point, do let me know. I do not see anyway at all to do it. Mine is at 6:30....... Facepalm .. ;)
I wonder if you can add an o-ring of some kind as a rotation spacer? Like adding material back to the tube and have the light still work as it should?
In your case it may be more effort than you want to mess with?
teacher
teacher's picture
ARsee wrote:
teacher wrote:
Yeah… I’m thinking that will be the better option. That way the reflector, lens, & bezel can remain intact as a unit. If you figure out how to change the alignment of the front strap attachment point, do let me know. I do not see anyway at all to do it. Mine is at 6:30……. Facepalm .. Wink
Hmmm…. you could probably do that but i think it will change the focus… So that is no good.
Yeah….. mine is a lost cause. Big Smile
ARsee
ARsee's picture
Hmmm.... you could probably do that but i think it will change the focus... So that is no good. Yeah..... mine is a lost cause. :D
 I get ya. I think. I'll give it a go and you tell me if I'm on the right track. LOL!
If a ring spacer is used for alignment of the strap connection point, that spans the MCPCB/LED that distance away from the reflector.
So then maybe a slug of copper the thickness of the spacer ring, could be put under the MCPCB to regain the focus parameters. Yeah?
teacher
teacher's picture
ARsee wrote:
Hmmm…. you could probably do that but i think it will change the focus… So that is no good. Yeah….. mine is a lost cause. Big Smile
 I get ya. I think. I’ll give it a go and you tell me if I’m on the right track. LOL!
Yep… I think that would work just fine….. Smile
Good thinking…… Thumbs Up
ImA4Wheelr
teacher wrote:
Good deal..... looks like I was wrong about them both coming at once. Facepalm Oh well... Big Smile Glad your getting them. .... On another note. Are you going to take your bezel off to do your 'LED burn in' +OR+ just split the head, exposing the LED _(but leaving bezel, lens, & reflector intact??)_ I am gonna do it the second way mentioned.
I like the idea of the approach you intend to take.  The reflector and lens will be more protected from dust, etc.  I just tried to unscrew the top part of the head off, but couldn't get it to budge.  I used a strap wrench for the big section and my hand for the finned section.  I'm going to put some oil on the joint and give it some time to work it's way to the oring.  Hopefully that and another strap wrench on the finned section will break it loose.
thijsco19
Last seen: 7 hours 1 min ago
Its definitely on there real tight, couldn’t unscrew it either. Had to put it in the vise and used 2 hands. Probably the oring that’s a little on the big side.
teacher
teacher's picture
ImA4Wheelr wrote:
I like the idea of the approach you intend to take.The reflector and lens will be more protected from dust, etc. I just tried to unscrew the top part of the head off, but couldn’t get it to budge. I used a strap wrench for the big section and my hand for the finned section. I’m going to put some oil on the joint and give it some time to work it’s way to the oring. Hopefully that and another strap wrench on the finned section will break it loose.
Yeah I think this way is best.
If you have a vice you can remove the battery tube & put the flats where the switch & tripod mount in the vice (pad jaws) and unscrew the top portion by hand.
Works well…. just be sure to pad jaws. Wink
This is what thijsco19 was referring to also.Thumbs Up
g_sintornillos
g_sintornillos's picture
Last seen: 2 weeks 1 day ago
Smittymojo wrote:
Got my GT and 8 batteries on 1-6-18. DHL handed it off to the USPS and it was sitting on my door step when I arrived home that evening. Never received any tracking info, not complaining just saying.
It is shipped, when it is shipped
Every time I read that you have received the Giggles without them sending you the tracking info I worry more and more
I hope to receive the tracking code before the Giggles arrives in my country with enough time to make the correct customs declaration, otherwise I will have many problems
I see big bureaucratic problems on the horizon $$$$$$$, it’s really worrying
Sorry for my bad English (gogole transtorla)
Texas_Ace
Texas_Ace's picture
Last seen: 5 hours 49 min ago
We have not heard from Neal in several days. I am guessing that having a new wife have not allowed him spare time to deal with the GT for the last week.
Hopefully he will be back on track for the lights going to other countries.
Plus for the USA it really doesn’t matter for 98% of US buyers if they have the tracking number besides trying to be home for the signature but they will come back if no one is home.
JasonWW
JasonWW's picture
Last seen: 9 hours 2 min ago
You have dhl, right?
You can call them once a day and they can check for any shipping labels created going to your address. It is a little extra work, but maybe this will ease your mind.
JasonWW
JasonWW's picture
Since no one reported any new tracking notices, I guess Neal was not able to ship out that 3rd order at the end of last week. Maybe it will be this week.
dhsvcs
Last seen: 8 months 5 days ago
Received mine with batteries Saturday…charged em up, works great…
Impressive, nice work..
Thanx
g_sintornillos
At this time I am in no hurry for shipping
My only concern is to know the tracking code with enough time to correctly make the customs declaration
The tracking is essential to present the customs declaration
Thank you
I’ll try
ImA4Wheelr
teacher wrote:
ImA4Wheelr wrote:
I like the idea of the approach you intend to take.The reflector and lens will be more protected from dust, etc. I just tried to unscrew the top part of the head off, but couldn't get it to budge. I used a strap wrench for the big section and my hand for the finned section. I'm going to put some oil on the joint and give it some time to work it's way to the oring. Hopefully that and another strap wrench on the finned section will break it loose.
Yeah I think this way is best. If you have a vice you can remove the battery tube & put the flats where the switch & tripod mount in the vice (pad jaws) and unscrew the top portion by hand. Works well.... just be sure to pad jaws. Wink *_This is what thijsco19 was referring to also._* ... :THUMBS-UP:
Ha!, wish I had read your or thijsco19's above post before tackling it the second time.  A vice would have been very helpful.  I got it apart after many full force attempts with 2 strap wretches.  My wretches have short handles, so they didn't give me much leverage.  I didn't get some smoke or steam during the "burn in".  I think it was just steam because I didn't detect any burning smell.  Either way, I wouldn't want it condensing on that beautiful reflector.  Thanks for the suggestion.
EDIT: fixed error.
ARsee
ARsee's picture
2nd GT arrived today
USA, West coast side of the globe
borealis
Last seen: 4 months 1 week ago
The duties you can expect for the GT + batteries, delivered by DHL to the Netherlands (hint: it’s taxes all the way down):
Value added tax: €31,92
Administrative costs: €14,50
Value added tax on the above administrative costs: €3,05
For a total of €49,47.
My Paypal payment was $143.28. With US$1 = €0.835764 , US$143.28 = €119.748. If I naively use the maximum VAT from https://www.belastingdienst.nl/wps/wcm/connect/nl/btw/, I get 119.748*0.21 = €25.15, but the invoice gives €31,92. It would be interesting to find out how they arrived at their value.
troisanh
Last seen: 1 year 1 month ago
Light and batteries arrived this morning, thanks team.
akoposilester
akoposilester's picture
Is it correct to assume that all US address will be shipped first reagrdless if it was on 1st or 2batch?
For example US 2nd batch will be first before malaysia 1st batch.
FL Newbie
JasonWW
JasonWW's picture
Batches? What do mean?
teacher
teacher's picture
Most likely. That seems to be how it has gone so far.
I am assuming by “batches” you mean the First 555 Payment PM & then the next Payment PM that was sent???
teacher
teacher's picture
ALABAMA
  • College Football National Champions
  • National Championship # 17
  • 8 January 2018
Good game Georgia. Smile
Blane
Last seen: 2 years 1 week ago
GT arrived today With batteries.
DHL, Paid 12/09/2017
Eastern Washington, USA
Compared it to my MF 02 and GT out performed it no problem.
Many people are complaining about 4000k emitter, I took it out even in the fog and it cut through the fog better then cool white of the MF 02.Very happy with the result.
akoposilester
Yes the 1st batch is 555 payment.
Are all the US GT already sent? After the US what country/contine nt will be shipped next?
FL Newbie
teacher
teacher's picture
OK ….. Thumbs Up
I’m not sure but I think most have.
As far as what/who is next… that is unknown as far as I know.
Any information or updates will be in the first post of the main GT THREAD by Team Giggles.
Here is a link……. http://budgetlightforum.com/node/50303
Smile
JasonWW
JasonWW's picture
Now I understand.
No, you are assuming incorrectly. There are no first or second batches any more. The first and second group to pay did that before the lights shipped so they are all grouped into one now. From #1 to #1039 on the sign up list. These numbers are useless now. So forget your #84.
Neal is now going by a new list by the order of who paid which is about 850 people. You are now #140.
When Neal grouped together USA, DHL lights with no batteries he did not include all of them. He only went up to the 576th person.
When Neal grouped together USA, DHL lights with batteries he did not include all of them. He only went up to the 740th person.
So there are still several USA people who have not got their lights yet.
These first two shipments were on pallets as there were so many all going to the same country. I don’t think Neal can use pallets any more since the rest of the shipping locations are so scattered around the world.
I don’t know how Neal will choose who gets shipped on the next shipment, but he does start at the front of the list and work his way back. If it is just a bunch of small boxes going out all over the world, then you will probably be one of them since you paid so early.
JasonWW
JasonWW's picture
teacher wrote:
ALABAMA
  • 8 January 2018
Well great. I guess I can just delete it from my dvr now that I know the results. Angry
Just kidding. I don’t watch football. You might be spoiling it for others, though.
