Hi all,
These two drivers from KD that fit the 22mm driver space on my Jaxman x1 seem very similar to me other than the fx6 is older and this LD-22s (or LD-33s?, its labeled as both in KD's description) seems to be recently released. Links below:
Can anyone tell the differences between them other than the UI and output levels from looking at the boards? Kd's descriptions are a crap-shoot at best, but I can only tell that the LD-22s states that it's "constant current" and the fx-6 doesn't claim that. Also, it looks like their low voltage protections might be different, and the fx-6 does not state that it has mode memory while the ld-22s does. They both appear to be two-cell only buck drivers with similar max output. Really wish they could handle 3s cells too. Why is there variation in their max current? For example, the fx-6 says its 4500ma or 5000ma, and the ld-whatever is 4800 or 5000.
I plan to swap in an xhp50.2 with the driver at the same time, but both the drivers are labeled for the older xhp70/50/mt-g2's with higher Vf. Do two cells provide enough overhead voltage for a buck driver at 5a with any of those emitters? Just trying to make some sense of these before ordering if anyone has experience with them or can tell from looking at the close-up pics.
As a side note, the stock Jaxman driver seems very high quality and puts out 3a on high already to the xhp50, but I don't know if it'll handle resistor modding for 5a or not. I can't exactly remember what resistor value I used without taking the light apart, but I think it was an r300 or r250 on top of the original r150, so I think it's putting out about 4a now. It gets warmer a little quicker, but not alarmingly so, I just don't want to toast the original driver for no reason when for under $10 5a drivers are available. I used the valuable info in this thread on post #58 from WolfA to help me with the modding: jaxman z1 discussion
