Test/review of Soshine 14500 900mAh (White-yellow)
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 19 min ago
DSC_4646
Official specifications:
  • Color: yellow & white
  • Size: 50*14mm
  • Brand: soshine
  • Model: ICR 14500
  • Capacity: 900mAh
  • Standard voltage: 3.7V, 3.3WH
  • Max pulse discharge current: 2.7A
  • Charging voltage: 4.2 V
  • Battery type: ICR 14500 li-ion rechargeable battery
  • Operating temperature: charging: 0°C ~ +45°C, discharge: -20°C ~ +60°C
  • Storage temperature: -20°C ~ +30°C
Soshine%2014500%20900mAh%20(White-yellow)-info
AA sized LiIon cells from Soshine, depending where I read the specifications says 0.9A or 2.7A continuous discharge.
DSC_4569 DSC_4570
DSC_4647DSC_4648
DSC_4649
DSC_4650
DSC_4651
Soshine%2014500%20900mAh%20(White-yellow)-Capacity
The discharge curve is fairly good, especially below 1A and it looks like the 2.7A rating is optimistic.
Soshine%2014500%20900mAh%20(White-yellow)-Temp-3.0
Soshine%2014500%20900mAh%20(White-yellow)-CapacityTimeHours
Soshine%2014500%20900mAh%20(White-yellow)-Energy
Soshine%2014500%20900mAh%20(White-yellow)-PowerLoadTime
Soshine%2014500%20900mAh%20(White-yellow)-TripCurrent
Soshine%2014500%20900mAh%20(White-yellow)-Charge
Conclusion
The cells have good capacity and works fine at lower current drain, for high current drain use some other cells.
Notes and links
Comparison to other LiIon batteries
Henk4U2
Henk4U2's picture
Last seen: 1 hour 40 min ago
Thanks Henrik, for yet another nice thorough test. The outcome is that for my X5-CU I’ll stick to my trusted Windyfire(s).
Wish you and your loved ones a happy and blessed 2018.
I always think long and hard before I say something really stupid.
tatasal
Last seen: 3 hours 15 min ago
l have two Soshine 18650. 2900mAh ptotecteds and have used them about 4 years already and their capacity has retained over the years and their protection never failed to activate every single time .
This is the only Chinese brand that has surpassed my expectations very highly.
NikolaS
NikolaS's picture
Last seen: 1 week 2 days ago
Thanks HKJ, these are the cheapest 14500 cells with good capacity,and will work fine with most flashlights like Utorch UT01.
I have tested them and they indeed pulling 2.7A without a problem.
Happy New year !
Best
Nikola
patmurris
patmurris's picture
Last seen: 19 hours 11 min ago
I received today from GB a set of four Soshine ICR14500 Yellow-White as reviewed here.
I did a quick ceiling bounce/luxmeter test with a few 14500 i have around. Here are the numbers (in lux) at startup on an Astrolux K01 (direct drive):
  • Trustfire “flame” 14500 900mAh – 64 (those are probably 4 years old anyway)
  • Keeppower 800mAh black – 72
  • Efest IMR14500 V2 700mAh red – 76 (those are probably 4 years old too)
  • Sanyo UR14500P 840mAh – 78
  • Soshine ICR14500 900mAh – 89
These cells outperform everything i have – for a third of the price i paid the Sanyo!!! Thumbs Up
At least at startup…
Edit: i just ordered 8 more. Facepalm
NikolaS
NikolaS's picture
Gret to hear that good results!
So far best 14500 for the buck Big Smile
