Test/review of Lloytron AAA 550mAh B014 (Green-black)
1 post / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 37 min ago
DSC_3482
Official specifications:
  • Capacity: 550mAh
  • Chemistry: Nickel Metal Hydride
Lloytron%20AAA%20550mAh%20B014%20(Green-black)-info
Maximum temperature raise at different discharge currents: 1A:+3,2°C, 2A:+6,6°C, 3A:+8,8°C
This is low capacity AAA NiMH cells.
DSC_3480 DSC_3481
DSC_3483DSC_3484
DSC_3485
DSC_3486
DSC_3487
Lloytron%20AAA%20550mAh%20B014%20(Green-black)-Capacity
The discharge curves looks fairly normal for NiMH cells, the small capacity also means the batteries are worse at high loads.
Lloytron%20AAA%20550mAh%20B014%20(Green-black)-CapacityTime
Lloytron%20AAA%20550mAh%20B014%20(Green-black)-CapacityTimeHours
Lloytron%20AAA%20550mAh%20B014%20(Green-black)-Energy
Lloytron%20AAA%20550mAh%20B014%20(Green-black)-PowerLoadTime
Lloytron%20AAA%20550mAh%20B014%20(Green-black)-CurrentTest
Lloytron%20AAA%20550mAh%20B014%20(Green-black)-Charge
Conclusion
The capacity is fairly low on these batteries as the rating specifies, this may mean they are better at handling over charge in equipment that spend a lot of time on the charger.
They look acceptable, but for normal usalge I would prefer batteries with higher capacity.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
My website with reviews of many chargers and batteries (More than 1000): http://lygte-info.dk/
