D4 Titanium!!!
126 posts / 0 new
jon_slider
jon_slider's picture
Last seen: 4 hours 21 min ago
pony wrote:
It doesn’t matter if Copper is 69% more conductive than Alu, because you can’t use pure Copper just like you can’t use pure Aluminium (too soft). And when alloyed to make it stronger, Copper actually becomes less conductive than alloyed Aluminium.
I agree the copper alloy called Brass is much lower conductivity than aluminum, but, I don’t think the D4 Ti is using a low conductivity alloy. If you have facts, please share, otherwise, your generalization may not apply. afaict, the copper head IS more conductive than Aluminum, since its Copper, not Brass
JamesB
Last seen: 11 hours 20 min ago
jon_slider wrote:
I dont quite understand your post
are you agreeing that copper is more heat conductive than aluminum?
you seem to be focused on convection, if by that you mean heat transfer to AIR, that is not the primary cooling mode for a flashlight. Holding it in the Hand moves heat away by conduction, much more than still (no fan) air convection. Or maybe I misunderstand your terminology.
I didn’t quite see what you were arguing before you edited your post, now my answer seems off.
Seems reasonable to think that most of the heat transfer goes though the skin rather than the air granted one don’t wear gloves, but the useful surface area of exchange with the skin on the copper pill whatever way you hold the flashlight is teeny tiny compared to the one you would have holding the AL one with the full body being a vessel for heat, and the whole heat being concentrated on those fins would surely be quickly incomfortable to touch.
I’m still not sure what we are arguing, semantics, physics ?
jon_slider
pony wrote:
How do you know it’s pure Copper? And if it is, do you really want a head that will deform when heated and dent at the smallest impact?
I have a lot of copper lights, and they have not deformed. If you believe the D4 uses a low conductive alloy, please provide evidence
else, I am happy to assume it is pure copper, and NOT brass. (and I do agree brass is a copper alloy with. very low heat conductivity.. almost as bad as Ti LOL
see https://intl-outdoor.com/emisar-d4ti-high-power-flashlight-p-927.html
_Features:
• Copper head (not brass)_
I was disagreeing when someone(s) suggested that aluminum moves more heat than copper (maybe I misunderstood, and the idea was meant to be that the aluminum D4 moves more heat than the Ti/Cu, which I do agree is possible).
I disagree that the copper used in the D4 has low conductivity
another perspective on the TiCuD4 heat management:
The Ti Body with the Copper Head is a major safety improvement. It allows the user to fire turbo without fear of burning their hand. Just hold the Ti Body, don’t touch the hot head, let the light do its thermal regulation thing. Smile
Since there is thermal regulation, the choice of metal is possibly less significant to the overall heat management of the D4.
JamesB
On a side note, i was replying to your last message (#67) and went back to read one sentence and the whole answer was completely changed again, this is very confusing for the sake of the train of though going though the thread, i agree (i don’t see the safety point though) with your post #67 22:46 UTC time 7 of january 2018 version Big Smile
saypat
saypat's picture
Last seen: 5 hours 10 min ago
sure are a lot of brainards in this forum! I love reading them!
chinooker
chinooker's picture
Last seen: 7 hours 5 min ago
I’m waiting for Mr. Peabody’s take on it. Grad
Hikelite
No.
The most common “pure” copper used for machining is TeCu, barely loses any proprieties with 93% conductivity of actual pure copper and it is well over aluminum alloys like T6061-T6 that are only 40%
http://www.shree-extrusions.com/pdf/c14500-tellurium-copper.pdf
https://www.nde-ed.org/GeneralResources/MaterialProperties/ET/Conductivi...
Even BeCu which are used in springs, can be had in 2 major alloys and on of them can be 45% of pure copper (the other one around 25% only)
hIKARInoob
hIKARInoob's picture
Last seen: 2 days 19 hours ago
P.S. There’s thermal and electrical conductivity. I think the original topic here is thermal conductivity (so second link is not applicable).
Jerommel
Jerommel's picture
Last seen: 1 week 6 days ago
These go hand in hand though.
Silver is the best both thermal and electrical.
Copper is second, i think aluminium is third. (correct me if i’m wrong).
Benefits of Aluminium is light weight and easy machining, and the fact that you can give it a strong(er) ceramic layer by anodizing.
2Q19
Jerommel
Jerommel's picture
If i recall correctly, it’s quite similar.
But brass has higher heat capacity (heat sinking properties) than aluminium, it is also heavier.
2Q19
JamesB
In most cases both are positively correlated, correct me if i’m wrong. Glasses
Edit: Jerommel was faster
hIKARInoob
Thumbs Up Funny as I’ve never thought about this before (edit: probably forgot about it). I have been told in high school that the electrons in metals are the primary carriers of thermal heat for conduction, and the electrons are covalent electrons. And covalent electrons should obviously result in good electrical conductivity.
Jerommel
Jerommel's picture
Thumbs Up Funny as I’ve never thought about this before. I have been told in high school that the electrons in metals are the primary carriers of thermal heat for conduction,
They never told me that, or maybe i wasn’t paying attention.
Makes sense. I did know heat through metals behave somewhat similar to electricity. A good example is a thermostat with a rather thin copper wire to the much larger ‘sensor’, like you find in gas heaters.
2Q19
hIKARInoob
Heat/temperature is basically kinetic energy (= energy) of the masses, i.e. protons, neutrons and electrons. The protons and neutrons are stuck in their places, whereas electrons they can go wherever they feel like going. So although electrons have very small mass compared to protons and neutrons, it is their extreme mobility that makes metals good thermal/electrical conductors.
Hikelite
I was talking about electrical conductivity, in that case is applicable.
In any case the amount of theories are astonishing for a 2cm piece of material.
This is a super tiny body in 18350 that because of the titanium electrical resistance should not even output as much power as the
aluminum versions, thus the heat produced by the LEDs will be less, all theoretical.
Not sure exactly as how much the very low electrical conductivity of titanium alloy will impact current as the walls are not that thin to start with so the resistance cannot that high, still.
hIKARInoob
Hikelite wrote:
This is a super tiny body in 18350 that because of the titanium electrical resistance should not even output as much power as the aluminum versions, thus the heat produced by the LEDs will be less, all theoretical. Not sure exactly as how much the very low electrical conductivity of titanium alloy will impact current as the walls are not that thin to start with so the resistance cannot that high, still.
My guess is that it's not going to matter that much. So yes in theory, no in practice. There will be an increase in electrical resistance, but this will be so small in absolute resistance term due to quatitative reason (size of the battery tube) that ΔV will remain small/negligible. That's my guess.
Hikelite
http://budgetlightforum.com/comment/1262500#comment-1262500
A very interesting post, real life test on the D4Ti 18650 vs D4 Aluminum both NIchia 219C
It is not monumentally worse compared to full aluminum as theorized by some, starts with 8% less theoretical output comparing the 226 number to 209, but as the runtime goes on keeps a higher output for longer than aluminum.
Now that smoother stepdown that keeps the output much higher for longer time could also be due to randomness in the MCU temperature sensor, just a pessimistic speculation, rather than a optimistic one (which would be, copper does that)
That initial lower output can be due to actually more than one reason, optic now matching 100%, higher electrical resistance of the titanium, LED manufacturing tolerance, MOSFET manufacturing tolerance, etc.
JamesB
Now i’m torn between bare Ti and cyan, might go with Ti so i don’t have to care about scratches and dings they look good on Ti imo.
moderator007
moderator007's picture
Last seen: 9 hours 36 min ago
From my younger days when we use to overclock cpu’s, the heatsinks were most important and a lot of RD was done by heatsink manufactors to achieve the best cooling. They were made using a cooper core to absorb the heat and a aluminum exterior to get rid of the heat. It was always my understanding that cooper absorbed the heat the best but aluminum shed’s the heat quicker, the best properties of both metals.
hunter1
hunter1's picture
Last seen: 19 hours 36 min ago
Hi.
Got my EMISAR D4 Ti from Hank at intl-outdoor.com yesterday.
It is a very nice light, like all the other D4 models.
Mine version is the RAW (A) model:
Nichia 219C 90 CRI 5000k
Optic 10623 floody
+ 18350 tube.
D4 Ti
Weight w/batt : 170.9 g
Weight wo/batt : 126.7 g
Head (alone) : 70.7 g
18650 tube : 46.1 g
18500 tube : N/A
18350 tube : 24.2 g
Tail cap : 9.8 g
D4 Alu
Weight w/batt : 110 g
Weight wo/batt : 66 g
Head (alone) : 30.6 g
18650 tube : 28.5 g
18500 tube : 20.9 g
18350 tube : 14.4 g
Tail cap : 7.1 g
mortuus
mortuus's picture
Last seen: 17 min 15 sec ago
shame its so expensive, u land at around 112$ no matter what emitter more or less unless u want the nichia which doesnt cost extra, the other emitters are +18$ and color choices +15$ just too much…
...where Frugal meets with Flashlight!
JamesB
Thanks Hunter1, could you tell us how the threads feel on your TI ?
Is there any gritty or galling feeling ?
hunter1
hunter1's picture
Hi JamesB
It feels just like what you say, like “sand” in the threads.
That said, threads go butter-smooth into the head – nothing there.
(..also when I put the wrong end of the tube into the head.)
In the “tail-cap” I think the “problem” is. You cant see anything
but you can feel it when you put it on – all way till you tighten it down.
I lubed the threads on the tail-cap, cleaned it all off again.
Did the same thing over again a few times so I could say that
it was “all clean”. It got better, but still a little “sand”-feeling.
This goes both for the 18650 and the 18350 tube wich tells me that the “problem” is the tail-cap.
I will leave it as is for now and hope it will wear out to the better.
All that said, it is a very nice little light..
djozz
djozz's picture
Last seen: 56 min 44 sec ago
Titanium-on-titanium always shows some ‘galling’.
JamesB
Yep that’s the nature of Ti/Ti, but i saw some variability in the phenomenon although i’m not sure what the main factor was (Ti alloy, surface finish, thread profils…)
redsuns
Last seen: 8 hours 8 min ago
I’m so excited!!! My preference is A or D
Northshore
Northshore's picture
Last seen: 7 months 2 weeks ago
For Ti on Ti I use NEVER SEEZ
Firelight2
Firelight2's picture
Last seen: 2 hours 3 min ago
Received my D4 TI today. I chose version F, with the 18350 battery tube and 5D XPL HI.
Very nice. the light looks absolutely gorgeous and feels great in the hand. the knurling on the 18650 body tube really helps. Output and tint are great.
Biggest drawback for me is the extra weight. I can feel it bouncing around in my pocket, unlike a lightweight aluminum light. Time will tell if this light gets relegated to a drawer or if I end up EDCing it a lot.
Firelight2
After using this light for a week, I’ve come to the conclusion that the aluminum version is much more practical.
The biggest problem with the titanium version is heat. Run it on a fresh VTC5A, with the light cold and it gets hot and begins rampdown within 10 seconds. Within 20 it is too hot to comfortable touch and output has ramped down to probably 1/10 its original output (at default temp sensor settings). It also becomes very uncomfortable to hold. The copper is where you naturally want to rest your index finger and thumb and this becomes awkward when the light gets toasty.
My aluminum D4s take much longer to heat up to this point and they shed the heat much faster. Aluminum in this light seems much more practical. Dark anodizing has much higher emissivity than shiny copper, and the aluminum version radiates heat from the entire light, not just part of the head. I’m not positive this will improve over time either. After a week of use, my copper head is still shiny. No sign its going to oxidize anytime soon to a duller state that would radiate heat better. I suspect it has a coating or polish on it to keep it shiny.
As much as I love the look and feel of the titanium D4, I suspect for EDC I’ll end up going back to my modded S2+ triple or an aluminum D4. It’s not a good sign that my shortened S2+ triple on a FET driver with basically no heatsinking at all can maintain high output considerably longer than my titanium D4 before it gets too hot to touch and ramps down.
Gunga
Gunga's picture
Last seen: 4 hours 20 min ago
Is the button any more recessed than the aluminum version? Does it have tailcap lockout? I want a ti but am worried about accidental switching in the pocket. You can sell me yours if you want.
