Still burning after 35 years
35 posts / 0 new
WillyD
Last seen: 1 month 1 week ago
We just replaced our bedroom dressers this week as well as the reading lamps. When I was probably around 5 years old, my aunt gave me a small brass lamp that was touch activated with a 3-way bulb. That was over 35 years ago. I used that lamp in my bedroom as a kid, when I moved out, and up until this week.
Was getting ready to throw the lamp out when it occurred to me that I have never changed the bulb. What is even more amazing is that it probably cycles on/off several times every day, and this has been going on constantly for at least 35 years. Reminded me of a bulb I saw in one of those Guinness’ Book of World Records that’s been burning for over 100 years. They say the reason is that it’s never been turned off. http://www.centennialbulb.org/
Edited by: WillyD on 01/06/2018 - 23:00
DoubleA
DoubleA's picture
If they used less power I would never replace incandies.
and on the first day he said "Let there be light"...
Lightbringer
Lightbringer's picture
Last seen: 22 sec ago
Every now and again, my grandmother’s ’50s-era fridge would start “fading”, ie, not keeping things as cool as usual. Lightly sanding the prongs on the power plug, and a few ins’n‘outs in the outlet, would scrape off the oxidation and get it working again just fine.
From so long ago, it’s likely some oxidation grew on the connection, too, causing some extra resistance, dropping some voltage, and making that bulb act like a “long-life” bulb (eg, 130V-rated bulb used on 120V).
niraya
niraya's picture
Last seen: 2 weeks 13 hours ago
I never did replace any, I stocked up on incandies while they were very cheap. The little more energy they take is worthy – the light can still be pleasant here despite all government regulations. Innocent
FmC
FmC's picture
Last seen: 1 week 9 hours ago
I think I’ve changed more CFL & LED bulbs in the last few years than I’ve ever changed Incans…. I don’t think the power saving of switching over to energy conscious bulbs is working out from my point of view Cash
Jtm94
Last seen: 1 week 2 days ago
I’m just new to LED bulbs so I can’t speak on them, but everyone leaves lights on all over our house and I got so tired of replacing incandescent bulbs I just bought up a bunch of CFLs a while ago. Everyone complains about how they are dim and off-colored at first, but I’m the one that replaces them. Angry These large globe bulbs that go above the bathroom mirror are the only incandescent bulbs left and these 40W bulbs burn out every 2 months. Facepalm
aremihc
Last seen: 4 months 1 week ago
Philips Classic Glass Soft White are beautiful, efficient, and seem to last well.
DoubleA
DoubleA's picture
That little more energy they take makes a big impact on my energy bill. LOL
Replaced 40W incandies with 4W LED WW and now the bill is substantially cheaper. Sure the LED costed 4 times as much as an incandy but looking at the reduced energy bill I think it was worth it since the energy bill is slabbed so crossing a certain limit will further increase per unit cost..
Heard something about incandies making a comeback with nanotechnology or something. If that works out I might switch to them new incandies.
doubleone44
doubleone44's picture
I thought there was at least ome research that showed that the inefficiency of incandescent lights did not actually matter, as the heat produced made it so less energy was needed for heating
DoubleA
DoubleA's picture
Incandies make a lot of IR which nobody can see anyways, but there are places that need cooling instead, like the tropics..
Speadge
Speadge's picture
Last seen: 10 hours 23 min ago
Government banned sale/import, not usage of remaining stock anyway Smile
I bought around 70+ bulbs before EU regulation came into force. It was like 0.40 cents/piece that time.
It’s still possible to get them, but expensier under some “industrial use only” declaration or something like that I heard.
Zulumoose
Zulumoose's picture
I put 8w spiral CFL globes in our outside fittings 5 years ago, and have maybe replaced 2 out of 6, they run all night every night and 4 of them run 24/7/365 they are cool white and put out at least as much light as a 60w incandescent
Beam me up!
NeutralFan
NeutralFan's picture
Last seen: 3 days 3 hours ago
I bought 9.5 watt warm white LED bulbs from Costco last year on sale for 50 cents each. They are even dimmable. I replaced all the incandescent bathroom bulbs which had a mixture of 60, 75, and 100 watt bulbs. So in total I replaced 19 bulbs and went from 1,250 watts down to 180.5 watts. Amazing! They don’t dim as well as the incandescent bulbs, but appear brighter and still have a nice tint. None have failed yet.
I’d rather use my flashlight around the house than turn on the lights.
Lightbringer
I got a 100W bulb blazing bright 24/7 under the patio to keep the pipes from freezing in this coldwave.
The inside valve is cranked shut as tight as possible, but still “trickles”, ie, opening the outside valve to drain the pipe still leaves a constant trickle that never stops.
So, a 100W heater should help…
pellidon
Last seen: 1 week 8 hours ago
When I lived in the woods, I had to replace incans every month or two. Power fluctuated enough to hammer them. I bought a CFL when they were very expensive and I don’t think I ever had to replace it. Probably 7 years or so till I moved.
My problem is I use incans to keep pipes from freezing. Getting harder to find high wattage lamps now.
ARsee
ARsee's picture
Most problems with bulbs not lasting are spikes in voltage (AKA dirty power) coming into your home. Usually bulbs rated for 130v alleviates it
Dirty power, effects every electrical item connected to your main feed power source.
Bad wires, loose connections, overloading, also contribute to voltage fluctuation.
WalkIntoTheLight
Last seen: 3 weeks 2 days ago
I’m surprised you like the tint in a bathroom. I replaced our incandescent bathroom lights with warm-white LED bulbs, but they made us look like we had a liver disease. I went back to incan lights.
DoubleA
DoubleA's picture
I had that problem when I used 2700K LED bulbs. Switched to 3000K and now it looks much better. To match my incandescent I guess 3200K or so is needed.
MtnDon
MtnDon's picture
Last seen: 56 min 22 sec ago
Of course that is true, but dependent on where you are located. Where I live excess heat is the enemy. The A/C runs many hours, uses more energy, than our furnace. The thought of operating an incandescent with an illumination efficient of no more than 3% while operating the A/C to remain cool is abhorrent to me. We have 98% LED’s which are better with maybe a luminous efficiency of up to 20%. Still a long way to go, so that new technology is of interest.
RobertB
RobertB's picture
Last seen: 1 day 4 hours ago
You can buy the high CRI Hyperikon bulbs. Won’t make you look like you have liver disease
NeutralFan
These are the LED bulbs I got. Apparently 90+ CRI. No complaints from the family.
Edited to replace a picture.
MtnDon
MtnDon's picture
FEIT also makes an LED household lamp with a built in small battery that gives 2 or 3 hours of use if the power fails.
spinynorman
Last seen: 5 hours 49 min ago
I read somewhere (pre internet) that lightbulbs made in the communist bloc countries lasted for ages as there was no incentive to give them a shortened lifespan other than to give the workers in the Glorious Soviet Lightbulb Factory something to do.
DoubleA
DoubleA's picture
Could be true, but I’m pretty sure as time went on their quality of manufacturing degraded tremendously as well. As it is easily seen with Soviet era vehicles and weapons the earlier ones were well built with the good manufacturing and quality materials but several decades later the same vehicles/weapons were being made with poor quality materials and failed more often. No incentive works both ways, no incentive to keep producing top of the line products anymore Crazy .
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 51 min 58 sec ago
Freezing pipes you say lol. It was 42 degrees Celsius here yesterday i am happy i changed most of light to LEDs less power usage and less heat. Most of the LED bulbs for sale here are 90+ CRI. I was probably one of the last people to change from incandescent to LEDS i didn’t like the CFL bulbs so i kept using the incandescent for a lot longer and the price of LEDs was to high. I have been able to get 1000+ lumen bulbs for under $5 on sale here. Bonus i also get more light output in a 60w socket before it would be around 800 lumen max now i have lights running 1400 lumens. Plus considering that incans may cost $3+ here and on sale comparable LEDS are $5 or $6 each its well worth the investment.
In my house incandescent dont last that long seeing as some lights stay on all night i have seen an improvement with LEDs in life spans.
Incandescent bulbs have advanced slightly they fill the bulbs with different gases to get better life spans and better wattage and use different filament materials.
Sums up how the heat has got me lol!
Asbestos
Asbestos's picture
Last seen: 3 days 11 hours ago
We have 8 can lights in our kitchen, they had 75 watt halogen bulbs in them when they were put in. They lasted about a year.
8 × 75=600 watts
8× 12=96 watts
so for a little more than one bulb we light the whole kitchen, and actually it’s brighter because the 12 watt bulbs I got put out more light than the halogen ones. the cost for the bulbs was about the same. The thing with LEDs is to get decent ones with good color. It is even more so than with flashlights. A lot of off brand ones have bad drivers and crummy leds and give some sort of bad light. Also they have been up there for about 4 years now with zero replacements. One has started to blink on occasion. So between the electricity and the $12 for the bulbs I figure I have saved at least $100 probably more. Of course these are the larger reflector bulbs. My choice had zero to do with any sort of government thing.
I point to others in this group to justify how many flashlights I have.
pennzy
pennzy's picture
Last seen: 7 hours 29 min ago
Replaced every light in the house last year when local power company partnered with Home Depot . Dropped the price to a buck a bulb .Never realized how many bulbs in a house . I think it was about 75 and I don’t have a overly large house. I guesstimate my bill dropped $10-$15 a month .
MtnDon
MtnDon's picture
We’ve done the same. We’ve been in this house for 30+ years. The power bill is now for fewer kWh but more dollars. Pretty much everything that uses power has been replaced with more efficient units, but the cost per Kw has risen more.
gravelmonkey
Last seen: 1 day 19 hours ago
Given the choice, I would rather a small electric bill and heat with piped natural gas, I realise not everyone has it but to go from gas>electricity>heat seems rediculous in my opinion when you can just burn gas>heat in a central heating system.
zespectre
zespectre's picture
Last seen: 1 year 6 months ago
Oh DO NOT even get me started about the electric bills (LOL).
But my primary start to an LED shift was the “Ladder” lights in the house, in other words the 7 bulbs that require a ladder to change.
Then I swapped all the outdoors floodlights to LED which was cheaper to run AND almost twice as much light as before. I think about the farm I grew up in where we had a 90 watt incan by the back door and you’d turn it on and you could still barely see the barn out back so you still walked with a flashlight (Rayovac Sportsman anyone?) As I get older and the eyes start to get weaker at night I’m very VERY happy for the improvements in lighting!
Tonights forecast, 100% chance of dark.
klrman
klrman's picture
Last seen: 3 hours 33 min ago
FmC wrote:
I think I've changed more CFL & LED bulbs in the last few years than I've ever changed Incans.... I don't think the power saving of switching over to energy conscious bulbs is working out from my point of view $)
Never used CFL's but swapped out quite a few LED bulbs until I discovered that the $1.50   leds from Walmart were the ones I should have been getting as they never seem to fail.  All mine that failed in the past were the more expensive GE leds.
