Hi everyone - this is my first post here. I know that officially, you guys are big time into flashlights, but since they are led related, I would like to ask this - I have a question about “led flex neon”. I have 2 two meter lengths and would like to make a sign of some kind with these. I would like to find a supplier for the ends that have to connect/jumper to the next tube, and clear heat shrink that would be used to waterproof these connections and end terminations. I would like to know what parts you would use, and I’m looking for reasonable prices. I have seen a few ads, but all that I’ve seen are really expensive. I only need a few pieces of each. Would anyone here know what I’m talking about, and know somebody ? thanks in advance - BW
Are these the connectors you need?
And instead of heat shrink tubing you might opt for waterproof silicone glue.
If you want to use actual tubing instead you would need to know inner diameter requirement.
Could always use clear tubing…and see if you can run clear silicon I down in the tube…make it a solid but flexible and clear
(now getting the bubbles out of the silicon might be difficult)
Hey Angler - thanks for the reply. Those are close, but the parts I’m looking for are called mini connectors. They have a pigtail coming out of them. They are a two pin connector that plugs into the end of one tube, a plate/cap that snaps on, and a pair of wires that would lead/connect with the next tube. The end plate is sorta siliconed on after the end plate is snapped in. I was watching a youtube video that shows these, but they don’t have info on where to buy them.Could I possibly send you a picture ?
