FOLOMOV EDC-C4 & A1 magnetic charger
28 posts / 0 new
steel_1024
steel_1024's picture
Last seen: 1 day 17 min ago
FOLOMOV regarded as a new brand of flashlight? Never seen before
Checked on the Internet, turned out to be a new brand established by an old company.
Franchised outdoor sports lighting, chargers, batteries, EDC …. and so on
FoloMov = follow me to move on.
This EDC-C4 claims to be the shortest rechargeable 18650 flashlight.
The A1 is a magne usb discharger.
Currently only found in US Amazon.
color box packaging.
EDC-C4 flashlight
Shorter than 10cm, the maximum brightness of 1200 lumens, USB charge and discharge functions.
All English color box packaging
Features
Parameter
Side I
Side II
A1 magne usb charger
Provide charge and discharge functions, the maximum current 1A.
Overcharge, over discharge protection, over discharge 0V lithium battery repair, reverse polarity protection
and more……
EDC-C4 all accessories
With the original package comes with a 2600mAh lithium battery.
High quality
USB charge, discharge port
manual I
manual II
A1 charging, the green light flashes.
Charging voltage (using Apple original 2A plug power supply)
Charging current
Fully charged, green indicator light is Constantly bright I
Fully charged, green indicator light II
Can also be used as a portable power supply.
Pictured: iPhone is charging.
Flashlight USB port charging I (button flashing red light)
Flashlight USB Interface II
Flashlight USB interface III
CREE XPL LED visual about 6000K
Tail spring
Smooth reflector
Body texture
Rubber buttons
Driver
The middle is a rechargeable EagleEye X5R much higher
From left to right
XHP35 Hi (NW), XML2 3000K 90CRI, EDC-C4 XPL
USB power supply, with no body & battery, all operating functions are fine.
Sorry for my poor english.
Edited by: steel_1024 on 01/11/2018 - 10:32
Finnno
Last seen: 2 weeks 1 day ago
Nice!
Spread love, it pays off
Finnno
A coincidence – just received my A1 charger today, can’t wait to try it out Smile
Box
Your photos are always beautiful. Thanks mate!
RobertB
RobertB's picture
Last seen: 1 hour 31 min ago
The DQG Tiny 18650 is 88mm long
Box
I don’t think the Tiny is rechargeable
RobertB
RobertB's picture
No, it’s not. But it is small
Box
Folomov claims this light is the shortest rechargeable 18650 light. Not shortest 18650 light.
RobertB
RobertB's picture
Heard you the first time
sunny24
sunny24's picture
nice flashlight and awesome pictures
wle
wle's picture
Last seen: 1 hour 27 min ago
dqg tiny is smaller – 87mm, but - not rechargeable = – and i had 2 out of 2 fail.
manker u11 is 105mm, almost same size , it is rechargeable, and i had 1 out of 1 fail.
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Agro
Agro's picture
Last seen: 2 min 57 sec ago
You can put a battery with a built-in charger in Tiny. It won’t work as a powerbank, but that’s probably the smallest 18650 light with a charger included.
Mine has not failed (so far)…what kind of problems did you have with it?
wle
wle's picture
yes the dqg tiny is still the smallest 18650 light .
how did it fail ?
(i’ve posted this before, i am still mad at dqg for this)
light 1: switch broke loose from board, leading me to take apart [hard due to glued driver] and discover a fragile switch, a bad mounting method, and poor soldering, not user replaceable even though i can solder, for many reasons..
light 2: became intermittent, light would not come on, light would come on then fade out randomly, finally it would not come on at all
wle
-Greg Lemond.
Agro
Agro's picture
I see a M4DM4X code for Folomov EDC-C4.
It seems very good to me, but I’m not sure.
Can anyone help me with the following questions?
What price is considered very good for this light? What’s the historical low?
Agro
Agro's picture
Anyone…
wle
wle's picture
I think it would be good for $35, that is what a manker u11 costs, it is about the same more or less.
-Greg Lemond.
Agro
Agro's picture
Thanks for the input…this is not the same though. Manker has a buck driver, Folomov – not sure. Folomov has bad UI. And overall quality may be worse than Manker. However, it can be used as a powerbank and I believe it’s still the best flashlight-powerbank on the market.
Gunga
Gunga's picture
Last seen: 16 hours 22 min ago
I have one. The UI is not great. My main issue is that it won’t charge the newest iPhone (8/8+ or X) unless they have changed the charging chip.
d_t_a
Last seen: 2 hours 51 min ago
For flashlight-powerbank, isn’t it there’s also the Fitorch P20R and the Vollsion which looks very similar. Am wondering what aspects is the Folomov EDC C4 consider as better?
(we’re not considering the Xiaomi lower-powered powerbank-flashlight and the Xiaomi FZ101 zoomable flashlight-powerbank)
Agro
Agro's picture
Frankly, I have forgotten about them. I did so because they are simply uninteresting for me. Why?
Because for flashlight-powerbank I consider size and weight to be of critical importance and they seem to disregard it.
Fitorch is 41% larger and 38% heavier (battery weight included).
Xiaomi is 21% larger and 55% heavier. And has smaller capacity, compounding the size deficiency.
Agro
Agro's picture
Got my C4. It’s quite a bit larger than DQG Tiny, both when it comes to length and diameter. Nevertheless quite small. Quality is OK. UI is OK, the kind of a ramp works for me and I like how blinkies are out of the way. Though mode memory bugs me. As always. Wink
The charging cable is way longer than needed. Like 4 times longer.
Lens seems uncoated, I’d like to find a replacement. I will seek GITD o-rings as well.
The light is not glued, replacing the LED with one that suits me better should be easy.
Has anyone tried to do a resistor mod?
BTW, for those who haven’t noticed:
Thanks to Folomov, EDC-C4 is no longer the smallest 18650 flashlight-powerbank.
DQG Tiny 4th is. How?….Folomov has released an 18700 battery with a built-in powerbank. Should be DQG-compatible. Smile
ADDED:
After some use I don’t like the ramp.
Mode memory means that when I turn on the light I don’t know what mode to expect.
Ramp means that if I change mode I don’t know if it will become dimmer or brighter. Facepalm
So I have to downgrade my UI rating to “bad but passable”.
AlexGT
AlexGT's picture
Last seen: 11 hours 39 min ago
I have been using the Folomov as my EDC, The only thing to make this light perfect is if it came with a Narsil interface, BTW. I switched the LED to 3A tint and just love it!
GIVE US A NARSIL INTERFACE FOLOMOV!!!
Agro
Agro's picture
I second that.
Some more comments:
I was surprised to learn that this light accepts protected cells. And even more so to learn that it actually comes with a protected cell.
Also, it requires cells to be button top.
wle
wle's picture
*_narsil - hear hear! or is it here here!? wle _*
-Greg Lemond.
wle
wle's picture
Agro wrote:
: After some use I don’t like the ramp. Mode memory means that when I turn on the light I don’t know what mode to expect. Ramp means that if I change mode I don’t know if it will become dimmer or brighter. Facepalm So I have to downgrade my UI rating to “bad but passable”.
==how did you get ramping? mine doesn;t do ramping….
do you mean the thing where it steps up til you get to the top then back down ? (L M H T H M L…)
give me narsil!
i hate mode memory too, you never know where it will start. plus you never know if it will get dimmer or brighter as you press
wle
-Greg Lemond.
Agro
Agro's picture
It’s what you wrote wle, modes going up and down. Like a ramp, but stepped.
wle
wle's picture
right, i hate that too… 7 presses to change one level.. uck
wle
-Greg Lemond.
Agro
Agro's picture
I complained about the cable being long…
I invested a whooping $0.16 in a shorter/lighter one:
Works great. Now C4 is very comparable in size to my single-18650 powerbank.
OTOH the stock cable has its special uses too: it enables you to connect 2 devices to a single outlet and charge them simultaneously.
