LED test / review – Lumileds Luxeon MZ 5700 K min. 90 CRI (3V) – Finally! High CRI, High power, beautiful light
76 posts / 0 new
EasyB
Last seen: 1 hour 27 min ago
This LED looks like a great way to get a lot of light from a single cell light. I did not know about it. I guess the non standard footprint has kept it from seeing more use by flashlight modders.
Jerommel
Jerommel's picture
Last seen: 1 week 1 day ago
Nice LED for pebbled TIR optics. Thumbs Up
koef3
koef3's picture
Last seen: 1 year 2 weeks ago
The use of XP boards is possible, though. I’m own a flashlight with the MZ already.
But this LED was called ‘power hungry’ to get 2800 lumens of high CRI light, which is true in some point.
Because that there are not much boost driver or compact modding hosts for multi battery use out there the needed amperage is a problem indeed because the current is way too high which ‘traditional’ drivers for single battery can handle. In my JAXMAN M8 the Luxeon MZ is powered by the A17DD_L and the FET gets really! hot at Turbo (approx. 13 Amps with more than 100 deg C on FET!) which should lowers it’s lifetime rapidly.
For building a triple I would recommend the 12 V variant of the MZ (LMZ9-SW57) and a hypothetical high power buck/boost driver with 4S battery config. Because of the needed diffusor or matte optic bigger reflectors of the also bigger host would also increase the throw.
My LED tests: Cree SC5 based LEDs (WIP!)  ---  Nichia 319AT 83 CRI - Optisolis (3000/5000 K) - Lumileds Luxeon LXML-PWD9 - Luxeon MZ 5700 K (90 CRI, 3 V) - Luxeon V (CSP) 4000 K 70CRI - Luminus SST-40-W (+ dedomed) - Cree XP-L2 (+ High CRI variant) - XHP35 HI - XHP70.2 - CXA1304 COB - OSRAM OSLON Black Flat HWQP - SYNIOS DMLQ31.SGLE UW Q8WP - unknown 5050 LED ---- finished: JAXMAN M8 (Mini C8) HighCRI Triple
EasyB
I just ordered a couple of the 3V 70cri type from digikey. I’m thinking it might work well in an EE X6 maybe with ledil iris TIR.
djozz
djozz's picture
Last seen: 2 hours 43 min ago
Good luck with the triple tricky reflow! Innocent Smile
The_Driver
The_Driver's picture
Last seen: 8 hours 28 min ago
I think that will make a great light!
EasyB
led4power wrote:
Some triples and quads can have higher lumens/efficiency, but even with mild OP reflector, this LED should have much better throw.
Do you have any throw numbers from the testing you’ve done?
led4power
led4power's picture
Last seen: 1 day 2 hours ago
Soon I'll make few builds, but theoretically light with this led (T bin) should have ~2 times the throw of domed XM-L2 or domed XP-L in same reflector at close to max. power (14-15Amps).
EasyB
led4power wrote:
Soon I’ll make few builds, but theoretically light with this led (T bin) should have ~2 times the throw of domed XM-L2 or domed XP-L in same reflector at close to max. power (14-15Amps).
That would be great, but is that taking into account the cross between the dies? In reflector lights the cross reduces throw because when you look into the reflector there is always some area reflecting the dark cross.
I will also report my findings when I test the LED in a C8.
led4power
led4power's picture
There should be no cross/donut if OP reflector is used, of course this reduces throw, but it still should be way better than any triple/quad. Gap between dies is smaller than XHP-50 or XHP-70, and should be similar to dedomed/shaved XHP-50.
EasyB
I did some testing of this LED in a supfire L6 (26650 light with C8 head). I purchased the LMZ7-QW57 (3V 5700K) emitter from digi-key. I reflowed on a 20mm Tpad XP footprint MCPCB (I got it on the first try Cool ). With a fully charged 30Q I measured 11.7A by measuring the voltage across a 10mOhm shunt in place of the tailcap (this cell is old so the current might be higher with a new cell).
The results are a bit disappointing. I measured 69Kcd at 6.78m (with smooth reflector, reading taken at point with highest lux), and less than 2400 lumens OTF (ceiling bounce test).
The_Driver
A XHP-50 4500K 90CRI de-domed will do 2000 otf lumens at 6V and 5A (10A for the Luxeon 3V). So in this regard it’s actually quite similar. This shouldn’t come as a suprise as the Luxeon M and MZ are also from 2015. They aren’t new.
How do you like the tint?
EasyB
Mine is the 70 CRI version. I would say the tint is fine. It is definitely on the cooler side but not noticeably blue like a cree 1A.
The_Driver
Ok, then it really isn’t that efficient. Sad
gravelmonkey
Last seen: 3 days 6 hours ago
Does luxeon make a domeless emitter with a single one of these dies?
I considered upgrading my BLF Q8 with 4 of the HCRI MZ’s but realised something would probably melt if I tried!
The_Driver
Luxeon Z ES (German test here)
gravelmonkey
Thank you!
Looks like it wouldn’t work for a Q8, I misjudged the size and thought the dies were “XP-G” size.
Back to the drawing board. A 6V MZ in a convoy L6 looks like it might work!
The_Driver
They are basically dedomed XP-G size, very similar.
A 6V variant would definitely work in the L6. The only one that is not so great is the XHP-50 because of the rather high Vf.
PH_Oton
PH_Oton's picture
I am wondering WHO will be the first lunatic to put 3 LMZ7-QW65/QW57s under 10507 with VTC5A and witness quickest step down/throw out of hand/deflow/melt optics in history Party
EDIT: I forgot about poor little omten 1288 Tired
The_Driver
That would indeed be glorious! Evil
I think a FETie switch would make sense :).
I wonder if there will be a donut hole when using clear optics and three LEDs.
led4power
led4power's picture
Below ~8Amps per LED, there is no sense to use MZ instead of Luxeon V, and MZ is much less compatible with small optics.
PH_Oton
PH_Oton's picture
Well about FETed switch I am not feeling a need for one. That would be making a whole built “sensible and safe” which by all means it is not. For the sake of care and longevity for sure but I would love to see omten in action Innocent I am wondering the same about hole, especially with potential one inside of trousers pocket Big Smile
The_Driver
High-cri Wink
PH_Oton
PH_Oton's picture
I Agree with this one although I am highly concerned that if I decide to build one with S2+ in a month or so Lumileds will maybe release HiCRI Vs and then I will regret?
Carclo stated efficiency of 92% for 10507 with MZs.
zespectre
zespectre's picture
Last seen: 1 year 6 months ago
Very interesting.
Tonights forecast, 100% chance of dark.
Agro
Agro's picture
Last seen: 5 hours 57 min ago
Yes, there would be a hole with clear optics. In fact according to carclo frosted gives more throw.
You can see beam shapes on the carclo site.
The_Driver
Agro wrote:
Yes, there would be a hole with clear optics. In fact according to carclo frosted gives more throw. You can see beam shapes on the carclo site.
Yes, that’s actually just what I did after posting Wink Facepalm
They haven’t tested the Luxeon V yet, though. I know it wont be good but actual numbers and beamshots are still a nice thing.
PH_Oton
PH_Oton's picture
LMZ9-QW57
Power at rated maximum: 14.40 W (peak: 16.72 W)
Efficiency at 4,800 mA: 93.4 lm/W (peak: 89.3 lm/W)
L1V1 led4power sample
Power at rated maximum: 16.42 W
Efficiency at 4,800 mA: 96.9 lm/W
If LMZ7-QW57 is about 30% more efficient than 90CRI verson it WOULD make sense to use it instead of V under 8A?
led4power
led4power's picture
MZ would be brighter of course at any current, and Vf is crazy low,CC regulation would be maintained ~100% of time even at high mode, I'm just not sure how well it would work with small optics, total die size is bigger than tir entrance holes. Since I got 20mm mosDTP boards,I will build M1 with 5000K 80CRI  MZ, just to see how they look in flashlight, XHP50.2 was total disappointment because of terrible tint/coronas.
Agro
Agro's picture
I wonder what’s the relation between Luxeon MZ, Luxeon M and Luxeon MX…
Is M the same as MZ, but with a dome and larger package?
If yes, dedoming should bring the same performance at low currents and better at high – due to larger thermal pads.
MX is an upgraded variant of M. Eyeballing photos it seems to have about the same die sizes. And doesn’t look flip chip. And emission profile looks the same too. Is there a chance of it being better than MZ?
