LED test / review – Lumileds Luxeon MZ 5700 K min. 90 CRI (3V) – Finally! High CRI, High power, beautiful light
76 posts / 0 new
Agro
Agro's picture
Last seen: 10 hours 44 min ago
led4power wrote:
BTW 5000K 70CRI variant is available in T flux bin (full reel), which is about 30% higher that LED tested above, I calculated ~3500+lm at 14-15A is possible (I’m considering to buy 1 reel for some time).
How did you get 30%? T bin is 970-1040 lm. Here we have 867.8. So the difference should be ~16%?
led4power
led4power's picture
Last seen: 1 day 7 hours ago
Agro wrote:
I wonder what's the relation between Luxeon MZ, Luxeon M and Luxeon MX... Is M the same as MZ, but with a dome and larger package? If yes, dedoming should bring the same performance at low currents and better at high - due to larger thermal pads. MX is an upgraded variant of M. Eyeballing photos it seems to have about the same die sizes. And doesn't look flip chip. And emission profile looks the same too. Is there a chance of it being better than MZ?
They all have same MZ core (4x4.2mm,4x Z ES chips), M and MX have full dome and white ceramic 7070 frame, footprint is the same for all leds, MX is basically updated flux bins Luxeon M, I don't see other differences.
Agro
Agro's picture
Lower max soldering temperature, higher max current, higher Vf. Though slight differences may not actually mean a different product…
I had troubles reading the pad specs…thermal pad is the same. Good for compatibility, bad for performance. Wink
Anyway, if that’s the case, dedomed MX should reach about XHP35 HI luminosity. Maybe even higher.
led4power
led4power's picture
Agro wrote:
led4power wrote:
BTW 5000K 70CRI variant is available in T flux bin (full reel), which is about 30% higher that LED tested above, I calculated ~3500+lm at 14-15A is possible (I'm considering to buy 1 reel for some time).
5700K 90CRI has 770lm typ. @85C, T bin has ~1005lm typ. @85C -> 1005lm/770lm=30% higher
led4power
led4power's picture
Agro wrote:
Lower max soldering temperature, higher max current, higher Vf. Though slight differences may not actually mean a different product... I had troubles reading the pad specs...thermal pad is the same. Good for compatibility, bad for performance. Wink Anyway, if that's the case, dedomed MX should reach about XHP35 HI luminosity. Maybe even higher.
Thermal pad is big enough anyway, performance gain with bigger pad would be hard to see (I'm not saying that 7070 pad would be bad,but Philips did this for compatibility reasons).
PH_Oton
PH_Oton's picture
Last seen: 3 days 11 hours ago
Currently probability of finding higher flux QW(3V bin) of MX is second to none, for small quantities at least. There is higher chance of getting 3V M but just in 3000K and maybe 4000. I made few quotes on taobao asking for availability of LXR7-QW57/QW65 versions of M and they are out of stock everywhere.
I will keep searching for them but meanwhile if someone find reasonable source I would greatly appreciate sharing it with me and others Smile
koef3
koef3's picture
Last seen: 1 year 2 weeks ago
Important notice:
I updated the luminance values for all LEDs shown in test chart except Luxeon MZ (due to irregular light distribution)!
To ensure more realistic values for 'real-life' conditions (flashlight use / secondary optics) I established a new testing method to determine the luminance with a SMO reflector. All upcoming and already existing tests will use this method!
Updating of my other tests will be done in the next hours / days.
My LED tests: Cree SC5 based LEDs (WIP!)  ---  Nichia 319AT 83 CRI - Optisolis (3000/5000 K) - Lumileds Luxeon LXML-PWD9 - Luxeon MZ 5700 K (90 CRI, 3 V) - Luxeon V (CSP) 4000 K 70CRI - Luminus SST-40-W (+ dedomed) - Cree XP-L2 (+ High CRI variant) - XHP35 HI - XHP70.2 - CXA1304 COB - OSRAM OSLON Black Flat HWQP - SYNIOS DMLQ31.SGLE UW Q8WP - unknown 5050 LED ---- finished: JAXMAN M8 (Mini C8) HighCRI Triple
Agro
Agro's picture
Well well…we see significant re-shuffling of the top performers, not just Synios.
Thank you for the update!
BTW, would it be possible to get the raw data that you use to draw the charts?
koef3
koef3's picture
Any idea to make this without too much effort? For all emitter tests it would be way too much work to make this...
Now I can provide light flux / Vf at certain temperature Tj, at same test current Lumileds using in the official datasheet (2,800 mA). Smile
The manufacturer Lumileds doesn't provide any data regarding changing Vf at rising temperature Tj, so these data are very new for all of us.
Barkuti
Barkuti's picture
Last seen: 27 min 10 sec ago
Quite good output thermal stability, with ≈91.92% (728/792 lumens) relative light flux at 145°C (+60°C) and ≈103.283% (818/792 lumens) at 25° (−60°C). Thumbs Up
Cheers Party
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Agro
Agro's picture
koef3 wrote:
Any idea to make this without too much effort? For all emitter tests it would be way too much work to make this…
The manufacturer Lumileds doesn’t provide any data regarding changing Vf at rising temperature Tj, so these data are very new for all of us.
You surely have something you generate the charts from….spreadsheet(s)? csv? Something else?
For me just dumping it directly would work. It doesn’t need to be nice and clean and easy to work with.
koef3
koef3's picture
Okay, I'll check this out. Maybe I put the raw data in an extra post below every new test written in the future...
Tj    Tsp
0    -11,4
5    -6,4
10    -1,4
15    3,6
20    8,6
25    13,6
30    18,6
35    23,6
40    28,6
45    33,6
50    38,6
55    43,6
60    48,6
65    53,6
70    58,6
75    63,6
80    68,6
85    73,6
90    78,6
95    83,6
100    88,6
105    93,6
110    98,6
115    103,6
120    108,6
125    113,6
130    118,6
135    123,6
140    128,6
145    133,6
150    138,6
Would be this 'formatting' example enough for you?
Agro
Agro's picture
Yes. Though when it comes to raw data I’m more interested in output / Vf vs. current. So I can convert them to lm/W vs. luminance charts.
koef3
koef3's picture
Raw data
Lumileds Luxeon MZ 3V 5700 K 90CRI
Amps    lm    Vf
0,20    80    2,67
0,40    159    2,71
0,60    234    2,74
0,80    298    2,76
1,00    359    2,78
1,20    419    2,79
1,40    482    2,81
1,60    542    2,83
1,80    598    2,83
2,00    650    2,85
2,20    705    2,86
2,40    762    2,87
2,60    813    2,88
2,80    868    2,90
3,00    917    2,91
3,20    964    2,92
3,40    1013    2,93
3,60    1063    2,94
3,80    1117    2,95
4,00    1161    2,96
4,20    1207    2,97
4,40    1252    2,98
4,60    1295    2,99
4,80    1345    3,00
5,00    1383    3,01
5,20    1426    3,02
5,40    1470    3,03
5,60    1512    3,04
5,80    1555    3,05
6,00    1595    3,06
6,20    1640    3,07
6,40    1686    3,08
6,60    1727    3,09
6,80    1769    3,10
7,00    1802    3,11
7,20    1843    3,12
7,40    1876    3,13
7,60    1926    3,14
7,80    1959    3,15
8,00    2000    3,16
8,20    2033    3,17
8,40    2066    3,17
8,60    2099    3,18
8,80    2132    3,19
9,00    2174    3,20
9,20    2198    3,21
9,40    2231    3,21
9,60    2264    3,22
9,80    2289    3,23
10,00    2322    3,24
10,20    2355    3,25
10,40    2380    3,25
10,60    2413    3,26
10,80    2438    3,27
11,00    2471    3,28
11,20    2496    3,29
11,40    2521    3,29
11,60    2545    3,30
11,80    2570    3,31
12,00    2595    3,31
12,20    2620    3,32
12,40    2636    3,33
12,60    2661    3,34
12,80    2678    3,34
13,00    2702    3,35
13,20    2719    3,36
13,40    2744    3,37
13,60    2752    3,37
13,80    2769    3,38
14,00    2785    3,39
14,20    2802    3,40
14,40    2818    3,40
14,60    2826    3,41
14,80    2843    3,42
15,00    2851    3,42
15,20    2860    3,43
15,40    2868    3,44
15,60    2876    3,44
15,80    2884    3,45
16,00    2893    3,46
16,20    2901    3,46
16,40    2901    3,47
16,60    2901    3,47
16,80    2909    3,48
17,00    2909    3,49
17,20    2909    3,49
17,40    2909    3,50
If you create diagrams / comparisons with this data, I would ask you to publish these charts in this topic and also to specify the source of the data used. Smile
Raw data of more emitter tests will follow in the next time. Stay tuned!
snakebite
snakebite's picture
Last seen: 5 days 7 hours ago
feit finally found one of these in a flashlight.
its a feit electric 3c zoomie.
i doubt its hi cri but its about 5000k with good color rendering and no odd tints.
clean pure white.
