Haikelite MT09R Test/Review Beam video footage.
164 posts / 0 new
jasonxding
Last seen: 10 months 6 days ago
Phil_84
jasonxding wrote:
!{width:25%}https://i.imgur.com/tjvY91r.jpg!
Thanks for the shots, the beam looks pretty tight. Any chance for a shot in a darker environment? We are all eagerly waiting for some images of the 35 hi…
Thank you!
hIKARInoob
hIKARInoob's picture
Last seen: 6 min 29 sec ago
That’s a tight hotspot! Thumbs Up
jasonxding
Thank you!
The sun has not set Big Smile
The hotspot size is as big as my Olight M31. But the brightness from the hotspot to the end of the spill is more gradual.
NOT Haikelite U...
Last seen: 7 months 2 weeks ago
Like I mentioned only 5 MT09R's in 35 high left the factory with that driver and those still had a light output of 5k lumen...
And the chances of 2 of those 5 lights ending up suddenly being talked about on tje same day in just a couple of hours of each other.
The first one has no means of testing anything but still somehow named a lumen output. Which is pretty close to the 5k that particular driver was pushing out. The secobd one we are not seeing and those must be some close and shiny cillings.
I will wait a few more days and get one from the production run and test it with actual measuring equimpment and see how well it performs.
All sarcasm aside. If you have an MT09R 35 high Dale has asked where they were acquired from.
The 5 samples should not be easily available and they want to locate them so they can have the correct driver installed.
If you will contact Dale he will arrange for tthe driver replacment.
Thanks very much
He Said She Said Sales
Skype Terrywhite1@live.com
Nicolicous
Nicolicous's picture
Last seen: 24 min 12 sec ago
yeah hot spot look tight.
i wonder how much throw compare to MT07
Nico -.-
jasonxding
Haikelite USA Official wrote:
Like I mentioned only 5 MT09R’s in 35 high left the factory with that driver and those still had a light output of 5k lumen…
Thanks very much
https://i.imgur.com/rBPoGfk.jpg
https://i.imgur.com/g69nHtb.jpg
I got it from a China supplier and they are sending me another one with updated drivers. Thanks for clarifying.
NOT Haikelite U...
[quote=Nicolicous]yeah hot spot look tight. i wonder how much throw compare to MT07[/quote
With the corrected driver it should throw about 400 meters more...
I'm still trying to figure out where these came from..
I don't even have any yet and I have a lot more than 1 ordered.
Contact Dale... Haikelite Original is his username on here and he will get that driver swapped out.
hIKARInoob
Care is required when doing a ceiling bounce test for output measurement. The D4 is a significantly floodier light than the MT09R XHP35, which could result in non linear relation between lux reading and lumen output.
Contact Dale… Haikelite Original is his username on here…
I think this should be “HaikeLite Official”. Beer
jasonxding
hIKARInoob
Thanks for the video Jason! Thumbs Up You’ve got an amazing view there! Big Smile
… And yeah, that hotspot is tight! Beer
Pok
Pok's picture
Last seen: 2 days 16 hours ago
Taken from smart phone auto mode.
MT07 CW sliced dome 4S version
MT09R 3 x XHP35 Hi CW
hIKARInoob
^^^ Looks pretty much identical to me (unfortunately).
Hold on:
Is this OK? Shouldn’t you have fixed settings for both shots? With auto mode your camera is going to correct for the brighter light (if it’s brighter).
mortuus
mortuus's picture
Last seen: 11 hours 6 min ago
wow looks awesome thanks for the pics and video!
...where Frugal meets with Flashlight!
Phil_84
jasonxding wrote:
Thanks for the video, dont tease your neighbors too much, hehe.
Pok
Pok's picture
I on out bounds , not have a good camera.
mortuus
mortuus's picture
Pok maybe u can do some beamshots with your phone ?
Phil_84
Hold on:
Yeah, im not sure about those shots either, but thanks anyway Pok!
Both shots should have the same fixed settings, otherwise you cant compare it really. So we have 5000 MT07 lumen vs 7500 MT09R lumens. The light intensity (beam pattern) isnt comparable cause of the cameras auto mode, but range is at least a bit. In the distance, i think, the MT09R is just a bit brighter than the MT07, which is rated at 750m. So maybe, if this MT09R also uses the old driver and puts out about 5000 lumens, this would explain the pictures. And you are from China, so maybe you got one of those samples with faulty drivers?
Otherwise, if the light is fine, im not impressed with the range yet. But we have to wait for pictures made with fixed settings in manual mode first.
@ Pok: Maybe, if possible, could you repeat those shots with manual camera mode?
maukka
maukka's picture
Last seen: 3 hours 54 min ago
jasonxding wrote:
That packaging is atrocious. Hope the box was well protected but judging by the condition, it wasn’t. The light itself looks magnificent.
Pok
Pok's picture
My smartphone cannot set in manual.
ceiling bounce
MT07 CW sliced dome 4S version : 750lux
MT09R 3 x XHP35 Hi CW : 740lux
Phil_84
Pok wrote:
My smartphone cannot set in manual. ceiling bounce MT07 CW sliced dome 4S version : 750lux MT09R 3 x XHP35 Hi CW : 740lux
Ah ok, but thanks for taking a look!
Hm is this sliced dome from the factory or did you do it yourself? I think those two lights should not be comparable by lux values. The MT09R should have way more lux, it should throw over 1000m, compared to the 750 from the MT07.
Pok
Pok's picture
No way for MT09R XHP35 Hi over 1000m
my MT07 sliced dome is around 120,000cd. (If I remember, I sliced it myself )
I have all my database flashlights over 500+ .
I on out bounds, no tools .
Phil_84
Pok wrote:
No way for MT09R XHP35 Hi over 1000m my MT07 sliced dome is around 120,000cd. (If I remember, I sliced it myself ) I have all my database flashlights over 500+ . I said I on out bounds.
Hm then you maybe have on of the faulty units (with only about 5000 lumen, would match to the pictures you have shown, both look to have the same brightness there) or Haikelites range information for the light is incorrect.
If i may ask, where did you get your light from?
hIKARInoob
Phil_84 wrote:
Hm then you maybe have on of the faulty units (with only about 5000 lumen, would match to the pictures you have shown, both look to have the same brightness there).
I think this is the case. I’m pretty sure Pok knows what he’s doing. But of course we all should wait for more shots and measurements.
Phil_84
If he can shave his own LEDs, im sure he knows what to do Big SmileThumbs Up
So i guess Terry will be very interested in this…
hIKARInoob
If this is a sub performing light, then Terry/Haikelite USA already acknowledged this. First small batch of 5 lights (XHP35) have sub performing drivers.
Phil_84
I know, i meant interested in where Pok did get his light from. Smile
Pok
Pok's picture
I got my MT09R from dealer in my country Thailand.
Phil_84
!https://i.imgur.com/xcKhxqi.jpg!
Thanks for the pictures. And sorry that i associated “the land of smiles” with china, now i know better :).
Haikelite USA Official or Terry is looking for those few lights with a faulty driver that only have about 5000 lumens, maybe yours is one of them. But i dont know how to find out if the driver is the old one. Those few lights were samples for dealers, but never meant to be sold.
Newlumen
Newlumen's picture
Last seen: 5 hours 37 min ago
Thanks jason for the quick beamshot video.. your camera skill is great too.. by the way, i enjoy city lights too. Which country are you in?
